Author Topic: Today's top tip  (Read 2280 times)
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
Today's top tip
« on: April 23, 2010, 08:11:10 AM »
When rebuilding a set of carburetors from parts, make sure you use the same needle in every carburetor. This improves performance.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline Tretnine
  • Prove it,
Re: Today's top tip
« Reply #1 on: April 23, 2010, 08:16:22 AM »
I've also heard this. I hear it also helps with idle.
Member of the AMA
Offline xfactor
Re: Today's top tip
« Reply #2 on: April 23, 2010, 09:09:56 AM »
Another tip is make sure you turn on the fuel at the petcock, tends to run smoother with it on! ;D
Offline 73nancy
Re: Today's top tip
« Reply #3 on: April 23, 2010, 09:37:46 AM »
also on first start up make sure you have gas in it. before you start tearing into it thinking of why it wont run ::)
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
Offline Alan F.
Re: Today's top tip
« Reply #4 on: April 23, 2010, 09:41:43 AM »
Engine oil will help keep things turning smoothly too.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Re: Today's top tip
« Reply #5 on: April 23, 2010, 09:54:41 AM »
If your headlight doesn't work, I wonder how many people initially overlook the possibility of a burnt out bulb.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline xfactor
Re: Today's top tip
« Reply #6 on: April 23, 2010, 10:24:18 AM »
Mine for today is this, check the weather and plan accordingly. Just because it was nice when you left dosent mean there wont be a down pour drenching you and all your school work.  ::)
Offline bozo4onion
Re: Today's top tip
« Reply #7 on: April 23, 2010, 10:33:27 AM »
Carb needles are overrated. Lighten the bike and run without them. Rock on.
Offline rebabal
  • DMoney
Re: Today's top tip
« Reply #8 on: April 23, 2010, 10:35:36 AM »
Why stop there?  Carburetors are pretty heavy, run WOT without them.
'90 CB-1 (CB400F)
'76 CB750k - '78 F Brake Conversion
'03 CRF230
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
Re: Today's top tip
« Reply #9 on: April 23, 2010, 10:44:36 AM »
ill take it a step further... engine - gone. dont need it.
just rig up some type of pedalling levers to another sprocket and run to your rear sprocket... less weight = more speed, right>?
i should get a patent on that
Offline Slams77
  • Naturally Aspirated
Re: Today's top tip
« Reply #10 on: April 23, 2010, 10:45:48 AM »
I’d also like to add….for better lean angle, and of course to avoid scribe marks in the asphalt, always ride with the kick stand in the up position!
    • My Album
Re: Today's top tip
« Reply #11 on: April 23, 2010, 10:48:45 AM »
i under stand this thread is spinning out of control... but quick story
hot neighbor girl comes down to check out the bike the other night as i was about to leave. i killed it so we could talk.... then when i had to kick it (#$%* battery) i leaned off, completely forgetting my kick stand was up. i barely managed to not drop myself and the bike. sad thing was she acted like she was going to catch us both (me and the honda)... anyways. nice to get taken down a peg when youre trying to look cool
Offline xfactor
Re: Today's top tip
« Reply #12 on: April 23, 2010, 10:50:12 AM »
did this one yesterday
Offline the technological J
  • deliciouso!
Re: Today's top tip
« Reply #13 on: April 23, 2010, 10:54:28 AM »
if you fill your tires with helium and attach some balloons to your belt u can lighten your bike some also...if you have the spare change hydrogen is even lighter and well worth the investment.... i would love to see someone with out an engine and ballons tied to thier waist pedaling down the road proud of their "lightness".. then they explode from the  hydrogen balloons
94 ST1100..Gone
72 750 K2 Stay tuned!
