Author Topic: Project Frankenstuffs bike - ANTI CAFE BASTARD BUILD *PARTS FOR SALE*  (Read 72471 times)
Re: Project Frankenbike - CB550 cafe bastard. (how about a new name?)
« Reply #200 on: February 12, 2011, 07:20:57 PM »
...those 550F side covers those work for a 75?
.: Scott :.
Yes, all model years had the same covers.
Offline rippy154
« Reply #201 on: February 13, 2011, 03:56:01 PM »
As soon as I am sure what parts arent going back on I am having a sale. You guys need anything? lol FFJMOORE, I have a stock Cb550 front wheel that I made some ALUMINUM brackets so you can bolt on a YZF600 dual disc set up....modern forks for that modern rear end on Atomic??? I will post a pic.
Joe
Is the 550 front hub the same as the 750 one I gave you???? Whats the diameter and thickness of the yzf rotors
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #202 on: February 13, 2011, 06:57:55 PM »
they look the same. The rotor is about 3/16" wide and 12 inches across. I have the calipers as well.
« Reply #203 on: February 15, 2011, 05:05:58 AM »
Yes, that is a 180 rear tire, and yes I am using a rear Harley wheel as my front wheel. 8)
Offline rippy154
« Reply #204 on: February 15, 2011, 05:27:09 AM »
GEARS ARE TURNING........... might be pulling a frankenbike and major design changes may be in the works HAHAHHAHA
« Reply #205 on: February 15, 2011, 07:05:48 AM »
You got it dude. We still need to do the swap. I have 3 switches for you, and my axle that needs dome TIG -er-izing
Offline rippy154
« Reply #206 on: February 15, 2011, 07:18:14 AM »
You want me to swing by tonight????  I'll grab a 6pack.
Offline rippy154
« Reply #207 on: February 20, 2011, 02:39:34 PM »
So Here is a few picts of the making of a 1" front axle with Kawi ends to fit an inverted fork....  a cb550,with a ZX1 fork, and a harley front wheel hahahaha if that was said anywhere but here people would be like WTF WHY hahaha
We used a donor Kawi axle and cut the end off, it was bored out to 1" to accept a piece of 1018 cold rolled steel, it was then tacked on and moved to the lathe for facing to correct lenth, and the end turned down to accept threads, The threaded end cap was also bored down to the threads to slide over the 1" stock as it threads on to the axle, once it was cut to lenth it was moved to the welding bench and fully welded
here is where the magic happens HAHAHAHA
in the lathe
fully welded
next to a stock axle for comparison and ready for some threads
Hopefully the die will come in Tuesday and it will be done
Thanks for the smitywicks Joe
« Reply #208 on: February 20, 2011, 07:38:10 PM »
Nice work there Rippy. Your shop is so frigging clean!! I am going to have a roller.
FYI - I ended up tearing down half of the walls in my house.
« Reply #209 on: February 22, 2011, 07:01:38 PM »
Well today I got good news on 2 fronts.
#1 Rippy finished a front axle
#2 Hotrodmetal has finished a seat cowl
This is going to be one hell of a summer.
« Reply #210 on: February 24, 2011, 06:44:53 PM »
Expanding your shop? Or just watching too much DIY channel?!!? Demo is fun!
« Reply #211 on: February 24, 2011, 07:08:28 PM »
Stevo I saw your kitchen project. nice. I am widening some door openings and adding arches as well as renovating the kitchen and bathroom. I have Rippy on speed dial for those questions like "Was that a load bearing wall I just removed?"
« Reply #212 on: February 25, 2011, 07:28:04 PM »
Got my new granite and appliances in, wocking on my stone backsplash now. Then lighting. Then hopefully SOHC's!!
What are you doing to your kitchen?
Hijack over.
« Reply #213 on: February 25, 2011, 09:30:08 PM »
Very nice Steve.... ;)
Offline rippy154
« Reply #214 on: March 05, 2011, 06:15:33 AM »
Forgot to upload the final 2 picts
here is the axle threaded
and here is the finshed Kawi- Davidson front axle 1' axle with 24 x 1.50 threads
« Reply #215 on: March 05, 2011, 07:33:22 PM »
Strongest thing on the whole bike.
Offline DarkRider
« Reply #216 on: March 07, 2011, 09:55:47 AM »
Killer build man! Just looked at your webstore as well. Doubt you would take on orders for side covers for something other then an SOHC right?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #217 on: March 07, 2011, 03:29:22 PM »
You are correct. I try to only make or alter parts for bikes that i own or......want to own.
« Reply #218 on: March 08, 2011, 08:23:26 PM »
OK, so I got my new seat pan from Hot Rod Metal. (thanks dude) It is 1/16" aluminummmmmmum. I was originall planning on upholstering it but think for now I want it all just bare nekkid-ness.
The pictures are showing how I am making a "bump" for the seat to sit over my suspension bracket. I just used a ball peen hammer and a piece of MDF, then clamped and hammered.
Offline Flying J
« Reply #220 on: March 08, 2011, 09:20:25 PM »
Im pretty sure you pounded that dent the wrong direction.  :o
« Reply #221 on: March 09, 2011, 07:09:40 AM »
No. It is a bump that goes over the top of the top of the monoshock mount. Just an illusion in the photo.
Offline Flying J
« Reply #222 on: March 09, 2011, 07:32:07 PM »
OHHHHHH its for the mono shock, well in that case it is going the right direction. I thought is was for "something" else. ;)
Offline Tintop
« Reply #223 on: March 09, 2011, 07:38:09 PM »
FrankenSTUFF - now it makes sense. :D :D :D :D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: Project Frankenbike - ANTI CAFE BASTARD BUILD (still with white walls)
« Reply #224 on: March 09, 2011, 08:19:12 PM »
I dont get it? You guys seem to be on the same wavelength, but I have no idea what your joking about?
