Author Topic: Project Red Headed Step Child ruh roh damage!  (Read 79241 times)
Offline MasterChief750
  • Detonation
« on: June 03, 2010, 06:03:44 PM »
well last year i got my endorsement so i sold my dirt bike and went in search of a street bike. the only thing i found that fit my budget was a 1978 CB750K i found i craigs list. it had mostly everything. was missing a mirror and that was about it. it puked gas when you turned the petcock on but that didnt stop me. i started by taking the airbox off and that took care of the puking gas problem but didnt fix it. it only worked because the excess gas was getting sucked into the motor. finally i bought float bowl gaskets and took the bowls off. figured out the floats were way off reset them and went on from there. riding in the summer i could never get the bike past 75 period. it had lots of oomph but died right at 75. figured out i had a leaking head gasket and the rings were bad on one piston. so this past winter i took it apart and got a little carried away and here i stand now ready to document putting it back together finally. no pictures yet but i will get some up of the carbs.
a list of what im doing/done:
replace rings* and head gasket*
paint frame*
paint tree*
bondo* and repaint tank*
new fork seals*
switch to superbike bars*
new brake bleederoem one was wrong using the original for now.
paint random parts*
fix rotting seat pan (glass and go baby)*
recover seat*
rebuild carbs*, paint carbs*, cuss a lot while reracking carbs*
new points*
double spring points*
switch to podsreinstall air box*
buy new headlight bucket*(dont use aircraft stripper on your headlight bucket)
new gauge faces* (p/o put a f model tach on it so it was really off)
cuss at gauges while putting back together*
replace idiot light cover* (broke tabs off by accident)
drool over the thought of a 850 kit.(not going to happen right now)
shoot guns instead of working on the bike at the lake house*
drink a lot of beer*
repair right side cover coming up with another option
find a left side cover (flew off on the e-way)
« Last Edit: March 24, 2012, 04:45:09 PM by MasterChief750 »
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Pinhead
  • 1979 CB652-ST
Re: Project Red Headed Step Child
« Reply #1 on: June 03, 2010, 06:39:13 PM »
If it's not a 650 it's not really the redheaded stepchild. ;)
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
  • Detonation
« Reply #2 on: June 03, 2010, 06:53:22 PM »
the 77/78 seem to be the least liked of the 750s and im doing a black and red paint job that will give it "red hair"
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #3 on: June 13, 2010, 11:29:08 PM »
heres a few pics of the progress. going to wait on refinishing the swingarm until next season as i would like to send it to hondaman and i want to get the bike on the road asap. working on polishing the valve cover. and i will do the other side covers over the sumer, i have a spare motor i can get most of them off of.
 i just need a master link for the chain and the rubber nickles for under the cam towers.
I AM THE STIG
Sam is THE STIG
traveler
« Reply #4 on: June 14, 2010, 04:19:46 AM »
very cool!
Welcome, and thanks for sharing.
~Joe
Offline HedNut
  • Underwater Basket Weaving
« Reply #5 on: June 14, 2010, 05:24:41 AM »
Excellent!!! I'm working on the same bike!  What kind of paint did you use on the frame!?...It looks like a wicked finish in the picture.   I'll be watching this one!
Cheers!  And keep the goods coming!
  • Detonation
« Reply #6 on: June 14, 2010, 06:09:23 PM »
the paint on the frame is a base coat of self etching hi build rustoleum primer covered with rustoleum flat black(2 coats) covered with rustoleum flat clear enamel.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #7 on: June 14, 2010, 06:34:48 PM »
i got one problem i need help on. i cant seem to get the top tree clamp back on the stem. i remember it coming off pretty easy, too much paint in there? should i sand it out. i dont want to wedge it on with a screwdriver or anything. im tired of painting.
I AM THE STIG
Sam is THE STIG
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
« Reply #8 on: June 14, 2010, 09:41:43 PM »
Instead of sanding you my try getting a *very* small paintbrush and using some aircraft stripper on the inside of it where the stem slides through. Either that or get a stiff scraper to spread the sides apart a little bit.
Offline HedNut
« Reply #9 on: June 15, 2010, 09:14:51 AM »
Looks Slick man! I didn't know they had flat enamel! COOOL
About your top tree not sliding on....myself, I'd do a little finger sanding until it wasn't too tight?...maybe wrap it around a lil' pipe or broom handle and do circles.....  but the stripper sounds good too!  I'd just be careful with it.
CHEERS! and thanks!  Love the build!!!
  • Detonation
« Reply #10 on: June 16, 2010, 11:50:58 AM »
the flat clear can be hard to find sometimes home depot usually has it here
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #11 on: June 17, 2010, 06:50:12 PM »
got the body work done today on the tank. its not perfect but im pleased with the results. id get pics up but photoshop is being a pain and wont open so i can crop em. primer tomorrow hopefully. how long should i wait to sand each coat of paint.
heres some pics.
« Last Edit: June 17, 2010, 06:59:00 PM by masterchief1112 »
I AM THE STIG
Sam is THE STIG
Offline Roach Carver
« Reply #12 on: June 17, 2010, 07:30:43 PM »
sand the paint off the area that slips on to the stem. dont use stripper!!!! it will bubble the paint beyond the area you applied it to.
traveler
« Reply #13 on: June 17, 2010, 08:49:13 PM »
You really don't have to sand between each coat.  If you go with 3 thick coats of clear, and bake it on....you can wet sand/cut the paint with 1500 grit wet paper and buff it out.  The paint will have the wet look....and it will show off any bodywork that wasn't done perfectly.  The key to nice body work is in the work done under the paint.  a GOOD paint job will show all the flaws....especially a dark color.
~Joe
  • Detonation
« Reply #14 on: June 18, 2010, 02:12:01 AM »
good to know. the body work isnt perfect but i will live with it. first attempt at it and i wasnt about to try and hammer out some of the raised areas.
I AM THE STIG
Sam is THE STIG
traveler
« Reply #15 on: June 18, 2010, 04:32:14 AM »
Then I suggest a light color, since the bodywork won't be perfect.  White?  Silver?
~Joe
  • Detonation
« Reply #16 on: June 18, 2010, 12:03:54 PM »
i would but ive already started with black and red
I AM THE STIG
Sam is THE STIG
traveler
« Reply #17 on: June 18, 2010, 01:33:04 PM »
Well, then if you wnat it to actually look good, and are going to paint it black....then you need to get real about getting things perfectly straight.  Any little dents sticking up need to be tapped down and filled...and the whole tank block sanded....then primed...add a black tack coat, and block some more....any areas with black paint still on them are areas that need to be addressed, and you do that until it is MINT.
Your call....but if you don't, and you paint it black, it will look like $hit, IMHO.
~Joe
« Last Edit: June 18, 2010, 01:36:13 PM by traveler »
  • Detonation
« Reply #18 on: June 19, 2010, 02:12:12 AM »
will red show it as much? i can just flip my scheme
I AM THE STIG
Sam is THE STIG
traveler
« Reply #19 on: June 19, 2010, 06:28:27 AM »
no....not as much........I didn't mean to be rude in my last post.....but BLACK is the Hardest paint to get bodywork to look good.  Black shows everything....it's a bodywork magnifying glass.
The bodywork I'm talking about isn't hard......just takes some time with a sanding block.
~Joe
  • Detonation
« Reply #20 on: June 19, 2010, 12:57:15 PM »
hows 25 hours sound? i spdent a lot of time on it. and i really dont care if its a show piece because i did it and thats wha matters to me.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #21 on: June 21, 2010, 12:15:19 PM »
my nos headlight bucket came in and it is beautiful. i dont want to put it on the bike. more pics to follow. fillin the tummy right now.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #22 on: June 25, 2010, 06:31:22 PM »
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #23 on: July 12, 2010, 05:49:06 PM »
ive been a little lax on the pics but i got the front suspension back together with the rear swingarm back on and most of the front end put together. tank is coming along. it will be a 5-10 foot looker wasnt looking for perfection, just something better than what the stock tank looked like before i fixed her up. put super bike bars on upside down, thought they looked better that way, will have to get seat done so i can do final adjustment of those and see if they hit the tank that way. if they do ill flip them up like normal bars but i like how they look this way i have a crappy cell phone pic il throw up. didnt have the good camera with me today.
edit here are the pics
handle bars
roller
« Last Edit: July 12, 2010, 06:36:13 PM by masterchief1112 »
I AM THE STIG
Sam is THE STIG
Offline HedNut
« Reply #24 on: August 18, 2010, 08:57:59 AM »
I'm excited to see some updates on this MC!~  Anxiously awaiting....lol
Good projects take time!...I've been on mine for over a year now.....wowooooooo
