Author Topic: removing front chain sprocket cb550  (Read 9667 times)
Offline cb(r)
Re: removing front chain sprocket cb550
« Reply #25 on: March 27, 2006, 12:08:19 PM »
from the pic it almost looks like it the sprocket is flush with the  end of the shaft?
Offline crazypj
  • I'm brill, me
« Reply #26 on: March 27, 2006, 12:18:43 PM »
That really looks like the fixing plate is still on there. Can you see the groove in the shaft where it used to fit? She's a rusty one for sure. (or is it a really grainy picture?)
PJ
MetalHead550
« Reply #27 on: March 27, 2006, 12:23:41 PM »
Damn dude!  She sit outdoors unstarted for a bit?  That is rust Im seeing right?  Sure itll clean off fine but its probably fused that sprocket to the shaft to some extent.  You do realize the more rusted piece in the center has to be removed first, right?  Theres two tabs that line up with the splines on the output shaft which then line up with a groove just before the sprocket itself.  That center peice gets move clockwise (or counter) to line up with the bolt holes..so line those tabs back up with the splines and it should slide off allowing the sprocket to come off.  If you are past that point(didnt read the first page) then do as others suggested with heat.  Try torching it a bit, then pooring ice cold water over the problem area and that could contract the metals enough to break it loose.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #28 on: March 27, 2006, 12:35:27 PM »
I pulled copy of the picture down and cleaned it up some. The locking plate IS removed, actually. What we're seeing is sort of rust shadow where it has been in contact with the sprocket for so long, and presumably dry. I've never seen this before. Usually there is some lube around a sprocket. I'm guess that the splines are just so rusty they have a thin crust on the surface that is preventing the sprocket from sliding off. If he could move it back in some and use something to dress the spline surfaces, he might be able to get it off with the puller. Strictly stab in the dark here, never faced this in real-life.
MetalHead550
« Reply #29 on: March 27, 2006, 01:20:41 PM »
Good work bob. Definitly a deceiving picture.
Offline cb(r)
« Reply #30 on: March 27, 2006, 01:40:59 PM »
then how close to the edge is the sprocket?  canyou see the groove where the spacer used to be?  the shaft or sprocket could be rusted together and/ or there is bits of metal hanging you up.  you need to really clean and oil that things before trying to pull pry etc.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #31 on: March 27, 2006, 01:52:19 PM »
Here's the modified version of the picture, still a bit fuzzy, but it does not appear the sprocket is flush with the end of the shaft yet.
MetalHead550
« Reply #32 on: March 27, 2006, 02:03:43 PM »
Rust aside, that sprocket doesnt look very worn.  Strap a chain to it and run the hell out of it a few times. ;D  Torque and vibration from normal use, not to mention natural heating and cooling of the motor/sproket...plus ass loads of penetrating oil, would probably loosen it right up.  To me that just seems like the most enjoyable way of doing it! 8)
« Reply #33 on: March 27, 2006, 02:17:23 PM »
I think that sprocket IS worn.  I wouldn't want to put a new chain on it.  But, operational vibration WOULD probably help loosen the rust between splines and sprocket.
Anyone else want to chant with me?
Puller
Puller
Puller
Puller
Puller
Puller....
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #34 on: March 27, 2006, 02:30:45 PM »
                     I agree with TwoTired, you can tell that the sprocket is worn and I definitely wouldn't
      want to take a chance on the chain jumping off, causing damage to the case. I'd rather swap the
      sprocket out myself.
Member # 1969
chundy
« Reply #35 on: March 27, 2006, 03:24:04 PM »
Having just change front and rear sprockets I can tell you, she be worn, really worn.  Freakin ninja's would by that thing as a Hanzo sharpened death star.  My 2 cents.  That is some serious, serious corosion in there.  Protect you wiring and then douse the living bejesus out of it with penetrating oil.  When your done with that douse it again, then try to gently shimmy it of.  I you use a puller without this step you can, but not likely damage the drive shaft grooves.  Time, patience, grease and some new sprockets and a cahin are the order of the day. ::)
MetalHead550
« Reply #36 on: March 27, 2006, 04:13:53 PM »
....Theres this thing called sarcasm ;)
chundy
« Reply #37 on: March 27, 2006, 04:40:57 PM »
I get it, I'm a little slow sometimes :P.  I thought that somebody that uses this site so much would know better, I guess I lost the sarcasm in the writing.  Even though looking back you clearly illustrated it with the little smiley dudes.
MetalHead550
« Reply #38 on: March 27, 2006, 04:50:59 PM »
ha!  Mabey I just suck at sarcasm...thats highly likely.  Later
« Reply #39 on: March 27, 2006, 04:51:33 PM »
Yes, but only 10% of readers recognize it's presence.  25% don't understand it.  25% don't find it humorous.  25% are offended by it.  25% actually laugh inwardly.   25% encourage the practice.  And, 50% have problems with math, not counting those with bipolar syndrome.
 ;D ;D ;D
tommie
« Reply #40 on: March 27, 2006, 05:03:19 PM »
Apply penetrating oil. Wait 10 minutes. Tap it lightly with a small hammer. It will loosen right up and slide off..
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #41 on: March 27, 2006, 08:07:54 PM »
thanks guys. i swear i'll remember to pay attention to it next time i'm down there. spent all afternoon preparing for my upcoming paint job, and polishing my carb tops and bottoms and blowing everything back out while i had the float bowls off, for good measure. i keep forgetting to find my puller, but rest assured i have indeed oiled, tapped, and even pryed a little bit...i wouldn't come scratching my head without having tried to do the obvious first. like i said, i initially asked the question because i thought maybe it was the kind of thing where i was trying too hard.
demistifying the picture: what you're seeing is actually the sprocket covered in paint blow-by from when i painted my engine, but with the front plate removed showing the original rusty POS. no, it is not flush with the front. there is probably 1/16"-1/8" between the sprocket and the cog-looking thing in front of it.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #42 on: March 27, 2006, 08:14:06 PM »
I can't help with the sprocket removal, but my first thought when I looked at the picture was: 'what the hell disintigrated and coated everything with metal flake???'  Glad to see it was just paint.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #43 on: March 27, 2006, 08:44:16 PM »
Dude......You will rarely get this advice here, but I think sometimes, $60.00 spent at the Honda dealership is a good investment.
It allows you to meet the local dealers mechanics, "they really do want to help". And you just might learn what the problem was for future reference.  You just may find a mechanic at the shop who loves these old bikes and will continue to be a wealth of information to you. "I did". I call him when I really get stuck and he takes my call, and yes I take my bike in for #$%* I have no idea about.
Pick your battles....don't you want to ride that thing?
Sorry if I have broken the "I have to do every thing myself rule".
Ride it man.
Offline paulages
  • 1976 cb735
« Reply #44 on: March 27, 2006, 09:30:52 PM »
no, the local mechanics at my honda dealer HATE these old bikes. they call them mistakes. i certainly have my folx i take my problems to when i don't want to deal with them, hopefully a stupid sprocket aint one of them...that fender mounting stud that broke off in one of my forks and won't come out to save my life? that will go to someone else.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #45 on: March 27, 2006, 10:24:05 PM »
Cool 8)
Just hate to see someone including myself frustrated to hell
The fork thing, well.....that sucks too.  Good luck.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #46 on: March 28, 2006, 02:06:03 AM »
demystifying the picture: what you're seeing is actually the sprocket covered in paint blow-by
I wondered what all the spots were about. Mr. Adobe had to work hard to tone them down.  ;D
Hope you find that puller. I'm anxious to see if that does the trick.
Offline cb(r)
« Reply #47 on: March 28, 2006, 04:47:07 AM »
lube and then take a socket just big enough to fit over the shaft and  tap the socket with a brass hammer.   if it does not budge.
puller!
puller!
puller!
cmon everyone.  I am with ya two tired
MetalHead550
« Reply #48 on: March 28, 2006, 05:49:35 AM »
Puller!
Puller!
Puller!!
.........Put a chain on it and do giant burn-offs in your garage till it loosens up!
Put a chain on it and do giant burn-offs in your garage till it loosens up!  ;D
Offline paulages
  • 1976 cb735
« Reply #49 on: March 28, 2006, 12:29:20 PM »
why is it that threads like this always get the most attention? empathetic interest?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
