Author Topic: wtf is wrong with my starter and motor?.......  (Read 12248 times)
Re: wtf is wrong with my starter and motor?.......
« Reply #25 on: June 28, 2011, 08:11:25 PM »
use your right leg to start it ;D
omg like actually physically start the bike that is crazy talk sir!!
Can you even turn the motor over with the kick start? Did you have the cam-cover off, and reassemble it without tying the rockers up with rubber-bands? Perhaps the only problem is that your starter is not up to producing the torque required to bend valve stems. :o :o
Offline xsmooth69x
« Reply #26 on: June 28, 2011, 08:14:22 PM »
i can kick start it fine
1975 CB550 (FINISHED?!?!?)
« Reply #27 on: June 28, 2011, 08:27:36 PM »
Cool. Just checking!
Offline xsmooth69x
« Reply #28 on: June 28, 2011, 09:57:47 PM »
na man good looking out im a newb soo every little bit helps  ;D
i even have a hard time with abbreviations u guys use
Offline xsmooth69x
« Reply #29 on: June 28, 2011, 11:50:40 PM »
so i guess im not going to use the starter for the initial first start of the motor and ill kick it.....
then check this motors compression and see if its good
if its not im going to take my points plate and alternator off this motor and put it on my parts motor and start that with the starter since that engine works with the starter and check that compression.....
if the parts motor is good ill use that one if not then ill have to re visit this thread and pull apart my initial motor and change out that starter clutch gear thing
Offline gnarlycharlie4u
  • Far from being an
« Reply #30 on: June 29, 2011, 09:32:34 AM »
Offline xsmooth69x
