Author Topic: WTF!!?? HELP!!  (Read 16140 times)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
Re: WTF!!?? HELP!!
« Reply #25 on: October 13, 2011, 02:26:46 PM »
SO i was wrong...if I put it in gear and pull the clutch IN....the rear wheel will turn...but its very labored.  It feels like when the brake is being applied.  But there is no sound of grinding gears or anything coming from the gear box...
« Last Edit: October 13, 2011, 05:33:43 PM by brycegp »
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline WarwickE36
Re: WTF!!?? HELP!!
« Reply #26 on: October 13, 2011, 04:41:22 PM »
Nah P.J. your a big mouth behind a keyboard.  Mind your manners.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #27 on: October 13, 2011, 05:28:41 PM »
Everything is fixable, just needs money or skill (or both)
 You were going to sell a bike without checking the oil first?
I really can't be sympathetic
Sorry, if you were trying to help someone out and it happened I would be
If you were trying to make a quick buck....................................
Woe is you, karma is a #$%*
Does selling one's bike now translate to trying to make a 'quick buck'?  ???
 If all you did was throw some clubman bars on and make it look shiny it does.
If chain was run too tight output shaft bearing could have broken or seized?
 If you fitted 'O' ring chain you could have destroyed crankcase?
 Clutch thrust washer could be in wrong place?
 You may have been screwed over by whoever you bought it off?
BTW,
 Warwick, I just say what others think but are too 'PC' to mention.
 Just stick to your dog suit
JP, please stop commenting on my thread.  Just go back to hunting gators and stop hijacking.  I'm here to find a solution to a problem not debate anything with you.
Respectfully, GET OFF MY THREAD!
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #28 on: October 13, 2011, 05:31:36 PM »
I pulled the valve cover off and here are the pics.  I don't really know what to look for.  What can i troubleshoot from these pics?
Offline WarwickE36
Re: WTF!!?? HELP!!
« Reply #29 on: October 13, 2011, 05:41:16 PM »
The chain is still there so that's 1 cause eliminated.  I would pull the ignition cover off and in gear, on the center stand, rotate the rear wheel and try and line up TDC 1/4 T" and then note the location of the timing marks on the cam shaft.  The mark should be in line with the top of the head on either side (doesn't matter which.)  This eliminates valve timing,  Pulling all 4 plugs will make rotation easier.  DONT force it, if there IS a clearance issue it will become apparent as all of a sudden it wont keep rotating.  If its a ring seizure issue it will be stiff and reluctant to move basically the whole rotation of the crank.
2004 SV650s
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #30 on: October 13, 2011, 05:53:29 PM »
After I took off the valve cover, the rockers came with it.  So doesn't that mean that none of the valves are depressed...all are close...so there should be no clearance issues with the valve cover off.  The rockers aren't there to push any of the valves open?
Offline WarwickE36
Re: WTF!!?? HELP!!
« Reply #31 on: October 13, 2011, 05:55:42 PM »
YES, sorry, I forgot to mention put the valve cover back on a torque it to spec.
2004 SV650s
Re: WTF!!?? HELP!!
« Reply #32 on: October 13, 2011, 05:58:32 PM »
BE CAREFUL PUTTING THE VALVE COVER BACK ON!!!!! YOU WILL BEND VALVES IF YOU DO IT WRONG!!!!
(sorry for shouting...)
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #33 on: October 13, 2011, 05:58:58 PM »
...rotate the rear wheel and try and line up TDC 1/4 T"...
the crank will not move AT ALL...even after removing the valve cover.  Doesn't this eliminate the "piston hitting the valve" question?  If that was the problem, shouldn't I be able to rotate the crank with all the valves closed?
I have penetrating oil in the cylinders trying to free them...so I can't line up TDC at this point.
« Last Edit: October 13, 2011, 06:00:47 PM by brycegp »
Re: WTF!!?? HELP!!
« Reply #34 on: October 13, 2011, 06:03:45 PM »
This is probably normal drag in the clutch. Does the rear wheel spin freely in neutral?
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #35 on: October 13, 2011, 06:07:36 PM »
yes.
Offline FuZZie
Re: WTF!!?? HELP!!
« Reply #36 on: October 13, 2011, 06:14:21 PM »
Does the rear wheel spin freely in first with the clutch "fully" engaged?
mrjack55
Re: WTF!!?? HELP!!
« Reply #37 on: October 13, 2011, 06:26:34 PM »
Removing the valve cover may not eliminate the valve to piston question.  If you floated a valve, it smacked the piston and may have bent in the combustion chamber.  You might not be able to see it from the top.  Although, I have to think that there would be a pretty audible thunk if you floated a valve at idle.  I don't know Bryce, you may be pulling that motor after all.  Even if it's a seized cylinder that frees up with lube.  I know I'd want to make sure there's no internal damage.  Good luck, I hope it works out for you.
Re: WTF!!?? HELP!!
« Reply #38 on: October 13, 2011, 06:28:10 PM »
yes.
Don't worry about it. It also means there is no problem with the primary shaft bearing. Looks like the top end was getting oil. For the time being, leave the cam cover off, and the spark-plugs out. Next thing I would try is removing the alternator cover and turning the crank directly with the rotor bolt. If it will move a teeny tiny bit back and forth, then stops solid, I would guess piston seizure.
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #39 on: October 13, 2011, 06:44:39 PM »
Good new OR bad news...??  The crank turns VERY easily with the rotor bolt.
Good news is that the motor isn't seized after all!!
What's the bad news???
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: WTF!!?? HELP!!
« Reply #40 on: October 13, 2011, 06:52:21 PM »
Your kickstarter could be knackered.
Re: WTF!!?? HELP!!
« Reply #41 on: October 13, 2011, 07:00:56 PM »
That's very good news! ;D Next, try putting the trans in gear, and see if you can still turn the crank. The rear wheel should be turning with it.
Re: WTF!!?? HELP!!
« Reply #42 on: October 13, 2011, 07:05:59 PM »
When you turn the motor from alternator side does the cam turn also? Does the points end of the crank turn too? Just not understanding what has happened yet.
Offline Eydugstr
Re: WTF!!?? HELP!!
« Reply #43 on: October 13, 2011, 07:18:12 PM »
Will the motor turn with the spark-plugs removed? You may have had a hydro-static lock, where a cylinder filled up with gas.
+1...That was my first thought.  Haven't heard of it with CB's but my other bike is a first generation Kawasaki Concours and that happens very often...What can happen is that a leaking float valve + suction from the piston on the intake stroke will fill a cylinder with gas.
EDIT NOTE...sorry didn't realize this thread had a second page already.  Glad to hear the crank turns free.
« Last Edit: October 13, 2011, 07:21:53 PM by Eydugstr »
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #44 on: October 13, 2011, 07:28:10 PM »
@scottly - dropped it into 1st...turn the crank via the rotor bolt...it turned easily and the rear wheel turned with it.
@Don R - yes the cam turns when I turn the crank.  And I haven't pulled the points cover yet.
Sounds like my kicker spindle is gumming up the works...???
Re: WTF!!?? HELP!!
« Reply #45 on: October 13, 2011, 07:32:09 PM »
It might not be so bad,
Re: WTF!!?? HELP!!
« Reply #46 on: October 13, 2011, 07:34:24 PM »
Yeah, sounds like your kicker is knackered, as Dukie suggested. My guess is that the battery was run down when you tried the electric starter, leading you to believe the motor had seized.
Offline FuZZie
Re: WTF!!?? HELP!!
« Reply #47 on: October 13, 2011, 07:35:14 PM »
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #48 on: October 13, 2011, 07:45:22 PM »
if I put it in first...pull in the clutch...the rear wheel will spin...but not what I'd call "freely".  its labored...
Offline FuZZie
Re: WTF!!?? HELP!!
« Reply #49 on: October 13, 2011, 07:51:28 PM »
check your clutch cable it may not be fully engaging (ie: stretched).
