Author Topic: Wheel questions!  (Read 6179 times)
Offline ncstatecamp
Wheel questions!
« on: September 24, 2012, 07:45:10 PM »
In the process of renewing, revamping, updating and upgrading my wheels. The plan is to powdercoat the wheels and new shiny spokes.
I have the retainers out but I am having difficulty removing the bearings.
My current tools are a half inch steel rod and hammer. Starting with the rear wheel I am trying to drive out the bearing from the other side by going past the spacer and butting the steel against the bearing, all the while alternating sides.
Even with all this nothing's budging....
Any ideas please let me hear them?
And is there a different procedure for the front wheel as the hole is smaller? Do I need to remove this retainer too?(finger is point at)
O and on spoking does it matter which side of the rim attaches to the hub? The holes look mirrored to me...
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: Wheel questions!
« Reply #1 on: September 24, 2012, 07:52:46 PM »
There is a piece that sits between the bearings.  What worked for me was to take a narrower drift or screwdriver and try and push the center piece off to the side a little bit so that your drift will be able to catch onto the bearing and subsequently be able to drive it out.
Offline ncstatecamp
Wheel questions!
« Reply #2 on: September 24, 2012, 08:36:56 PM »
On the rear wheel I'm doing that and it ain't budging....
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: September 24, 2012, 08:45:56 PM »
Try a little heat on the aluminum as it will expand faster than the metal of the bearing....Larry
Offline ncstatecamp
Wheel questions!
« Reply #4 on: September 24, 2012, 09:29:42 PM »
Are there any seals I need to worry about?
Offline luap
  • LAWL
« Reply #5 on: September 24, 2012, 09:46:28 PM »
I would use a brass rod for the rear so you dont screw up number #14 scroll down a bit for the diagram
http://forums.sohc4.net/index.php?topic=36087.0
also remember to straigten out the 3 little teeth on the bearing spacer they seem to get bent pretty easy
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #6 on: September 24, 2012, 11:28:35 PM »
You will be replacing any bearing seals when you change the bearings. I haven't done wheel bearings yet and don't have my shop manual handy. Do inner races exist on the hubs? If so, you would be replacing them too, right? Brass drifts are the recommended tool for this job, less likely to mar up things if used correctly.
Harbor Freight carries a large (long) brass drift that is fairly inexpensive if you don't have one.
Offline ncstatecamp
Wheel questions!
« Reply #7 on: September 24, 2012, 11:46:17 PM »
Closest harbor freight is 3 hours away, but maybe lowes...
I take it aluminum would be to soft?
Offline ncstatecamp
Wheel questions!
« Reply #8 on: September 24, 2012, 11:47:48 PM »
Good question on the races, though I feel like they may be incorporated to the hub... Or I could be wrong
Offline fishslayeryo
« Reply #9 on: September 25, 2012, 09:29:17 AM »
There's no races in there, it's all part of the machined hub. Don't see a pic of the retainer out on the front hub, make sure that is out first. I used a big flathead to push the spacer to the side alittle so I could get an edge on the bearing, then used a blow and a metal rod to work it out, didn't have to heat them on front or back to get them out. Good luck!
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
« Reply #10 on: September 25, 2012, 09:35:16 AM »
+1
I picked up a cheap 3pk of drifts at a local hardware store.
whack'em hard. dont hit your knuckles  ;D
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #11 on: September 25, 2012, 01:32:18 PM »
Are you doing this on your workbench?  If so it probably is absorbing a  lot of the force.  Had the same problemo till i put some cardboard down and did it on the cement floor.  Heating it helps also.
Matt
Offline luap
  • LAWL
« Reply #12 on: September 25, 2012, 01:41:35 PM »
Cant remember which side Pretty sure its the retainer side you want to take out first so that way the bearing spacer falls out makes it esier to remove the other side. Also if you do lay it on the cement put the nuts back on the lugs so you dont screw up the threads
www.cb-town.com
Offline ncstatecamp
Wheel questions!
« Reply #13 on: September 25, 2012, 04:20:18 PM »
The retainer is definitely out. We've moved up to a 5 pound sledge and After heating the outside and standing on the table whacking the hell out of it, so much so it's bent the steel rod still getting nothing. In need of some more ideas..... Help?
Offline xruss
« Reply #14 on: September 25, 2012, 04:46:51 PM »
I went to Advance Autoparts and borrowed a bearing puller.  They have a tool loaner program that just requires a deposit.
1976 cb550k
Offline Harsh
« Reply #15 on: September 25, 2012, 09:51:08 PM »
I think the reason you couldn't get the spacer to slide over is because the rod you are using it too big diameter wise.  It just doesn't allow any "wiggle" room.
I have a set of brass drifts I picked up at Northern Tool.  I used the middle of the three drifts and pushed the spacer over.  I entered on the side without the retaining nut.  I stuck the drift in just far enough to clear the bearing and pushed it off to the side.  It took alittle force, but it moved.  I was then able to put the bigger drift in from the retainer side and knock the bearing out.
Using the tool loaner program is great, but I don't belive the bearing puller they have will fit into the front wheen bearing.  It might work on the rear bearing, but I am not sure.
Where in NC are you located?  You might be close enough to me that I could swing by and help.
Offline ncstatecamp
Wheel questions!
« Reply #16 on: September 25, 2012, 09:57:15 PM »
Currently in Boone but if I can get my other bike working then I'll be in Raleigh for the gentlemens ride.
I can get the rod on the bearing lip with what seems like room to spare (on the rear atleast) the spacer moves over plenty....
Offline ncstatecamp
Wheel questions!
« Reply #17 on: September 25, 2012, 09:58:18 PM »
I thought of that but what do you hook the puller to? With how tight together the spacer is between the bearings there's nothing to hook on both sides....
Offline Harsh
« Reply #18 on: September 26, 2012, 12:21:46 AM »
Yah Boone is a bit out of the way for me.
I had the same problem with my bearing puller.  With the spacer in there you don't have anything for the hooks to catch.
Offline disco
« Reply #19 on: September 26, 2012, 03:40:56 AM »
Mate, the rear wheel contains 3 ball races & 2 retainers. The retainer that you have removed is the one for the sprocket carrier. You've got to remove the sprocket carrier first. I would refit the sprocket (temporarily) & then lever the whole sprocket carrier off. Once this is removed it will reveal the retainer for the wheel bearing. Study the manual particularly the exploded diagram if you're not sure.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline ncstatecamp
Wheel questions!
« Reply #20 on: September 26, 2012, 11:16:05 AM »
Are you saying that small center ring is the sprocket carrier, or that I need to remove the section with the 4 bolts?
« Reply #21 on: September 26, 2012, 12:02:44 PM »
good catch disco!
That's it, the sprocket carrier has the 4 bolts on it. If that is still on your rear hub you need to take it off first. Easiest way is to put your old sprocket back on and put on the 4 nutts, put ur knees on both sides of the tires with it flat sprocket facing up and pull on the sprocket up & side to side to work it out. Keep track of that spacer in there, you need it for when u put it back together.
Offline ncstatecamp
Wheel questions!
« Reply #22 on: September 26, 2012, 01:25:31 PM »
Well now I feel retarded! Let's hope I didn't fick up anything to badly hammering....
Offline ncstatecamp
Wheel questions!
« Reply #23 on: September 26, 2012, 01:33:48 PM »
good catch disco!
Any other methods, as you see the tire and all else is off the hub.... I'm trying to knock it around with a block of wood, but it ain't budging
Edit: are there any spots I need to drill out around the large retainer like on the small center?
« Last Edit: September 26, 2012, 01:40:40 PM by ncstatecamp »
« Reply #24 on: September 26, 2012, 02:14:16 PM »
it wont spin!!! it just bangs the inside posts against the cush drives.
you have to pull it straight out/off.
put your sprocket back on.  hold your sprocket and have a buddy hold the hub.
tug o war style....
