Support the site. Your contributions keep this site running.
A couple of observations:The right side brake line needs a retainer wire to prevent the tire from rubbing through the sheathing on the line. It will only take a few miles before you're replacing that lines otherwise...Your battery NEG needs to be routed to the motor case and between the frame (fully bare metal). Factory route was upper right rear motor hangar bolt and frame bracket. Failure to involve the motor can create charging problems and deplete your battery very promptly. If you opt to not re-route the ground, then you'd best at least remove the paint where you have it. That thin metal bracket is about the worst place to tie into, by the way.
