Author Topic: CB750 K3F - AKA The Red  (Read 190780 times)
Offline Kickstart
Re: CB750 K3F - AKA The Red
« Reply #400 on: September 22, 2015, 07:40:58 PM »
Nice!
I have a bunch of the cheap ones in my tool drawer.  I should say I have a bunch of mostly broken cheap ones in my tool drawer as they never last that long for me.
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
« Reply #401 on: September 23, 2015, 02:51:32 AM »
With the oil change I also installed back the transmission Neutral arm, 800 miles without it definitelly smoothed things out, in fact the shifting was gettting clunky from low resistance.  It felt like gear jump in too fast and not smoothly because of the low resistance.
Anyway, took her out and she shifts like a charm, smooth, precise, Neutral is much easier to find.
Also adjusted rear brake, tried it very lightly at first but looks like the one piston F rear caliper is not capable of locking the wheel.  It is better brake than the drum, but only little bit.
« Reply #402 on: December 12, 2015, 10:33:56 AM »
Using F top bracket makes it hard to get key in and turn it.  I have one key with ground head to fit, but this new key I just made works and looks  better.
« Last Edit: March 14, 2016, 04:17:41 AM by 70CB750 »
« Reply #403 on: April 27, 2016, 04:56:40 AM »
I lost brake light, dang, that makes me nervous rider.
Rear brake and front brake are both using the same make of  pressure switch, the rear brake stopped working first, now the front is gonne too.  I guess it is time to try different brand, annoying.
Offline Kickstart
« Reply #404 on: April 27, 2016, 06:22:20 PM »
Surprising to hear that both failed... what brand/part?  Were they aftermarket repro's of the Honda part or just some other npt hydraulic pressure switch?
Might not be a bad idea to use an spring loaded regular mechanical switch for the rear.  At least something different so you reduce the probability of simultaneous failures.  I also like to set the rear pedal switch to light up the brake light before any braking pressure starts, so I can flash tailgaters  without any braking.
- Chris
« Reply #405 on: April 28, 2016, 04:10:51 AM »
You have a point there, Chris.  It was some sale at Superstore, not sure of the brand.    I am getting Goodridge to replace them, it was the brand I had on my list on the begining, I just went cheap.  I will see how they hold, technically I can use original K rear switch, since the pedal and frame are K3.
« Reply #406 on: June 07, 2016, 03:42:39 AM »
Replaced break switches with Goodridge, finally, both front and back.
« Reply #407 on: August 03, 2016, 03:02:19 PM »
I had a decent front tire from Dorothy with only 6000 miles on it, got a matching rear tire and put them on Red.
It sucks to have older sister, doesn't it?
Funny moment, took it for a spin to find out that I installed the speedo cable without the core, because the core was bathing in oil  ;D
« Reply #408 on: August 08, 2016, 05:53:23 AM »
The new rear tire is 110 unlike that old Dunlop that was 120.  Wow, how nimble she feels now.
After research and measurements I decided to run sans tubes on Comstar wheels.  I am using NAPA metal valves.  Even newly mounted tubeless tire is hard to unseat when deflated and other people reported many safe miles on Comstars without tubes.
« Reply #409 on: August 08, 2016, 07:13:55 AM »
I had a spare set of foot pegs - so I hacked them to fit to the frame for the passenger, much better than the original flimsy set.
« Reply #410 on: January 16, 2017, 05:13:39 AM »
Red's engine back on the stand.
« Reply #411 on: January 16, 2017, 07:11:24 AM »
Whats the plan, Prokop?
« Reply #412 on: January 16, 2017, 10:15:58 AM »
Replace the cam tensioner. It could be one  of those vintagecb750 bad ones.
Debating about the cam chain replacement.
What do you think?
Offline MoMo
  • Ride like you're invisible
« Reply #413 on: January 16, 2017, 05:13:18 PM »
What do you think?
that far apart, may as well
« Reply #414 on: January 17, 2017, 07:14:55 AM »
What do you think?
Agreed
« Reply #415 on: January 19, 2017, 05:00:08 PM »
Looks like this wheel is like new after 5000 miles.
« Reply #416 on: January 19, 2017, 05:01:59 PM »
She is getting fancy upgrade anyway :)
« Reply #417 on: January 19, 2017, 05:05:11 PM »
Red suffered from oil tank draining, used Elan's kit to rebuild the oil pump.  The shaft seal inside the pump, what a pain to get out  :(
« Reply #418 on: January 31, 2017, 04:17:51 AM »
D.I.D. cam chain from Kenosha Kid ;)
« Reply #419 on: February 19, 2017, 05:13:08 AM »
Replacing cam chain, ugh.
Offline MoMo
« Reply #420 on: February 19, 2017, 09:02:51 AM »
PITA but a worthwhile one ;)  Have fun with it Prokop....Larry
Offline JBCB500
  • Really enjoying this!
Re: CB750 K3F
« Reply #421 on: May 06, 2017, 09:14:02 AM »
The new shock mount to accomodate the wider F swing arm.  I used 3/4" 8 Grade bolt to make it, it still needs a washer beefore I weld it in.
70CB750:  I've been directed to your excellent build thread as I am attempting a similar build I have a K6 frame and a lot of F2 donor parts.  I plan to install F2 front and rear and F2 engine.  It has been suggested here and elsewhere that I'll need to do something to correct the fact that the F2 arm is wider than a K6 arm - the shocks will splay outward if I don't.  I've measured both arms and it seems the difference is only about 1/2" between K6 and F2.
I've attached a couple of pics of my mockup without any modification and I don't see that I'll have any problem.  Is the K6 frame different from your K3?  Am I going to be able to skip the step of moving the shock mounts?
Thanks,
JB
« Reply #422 on: October 26, 2017, 03:13:31 PM »
Not done yet?!
OR did you just buy another Jeep?
« Reply #423 on: May 04, 2018, 04:54:22 AM »
Sorry, JB, I took a break.
« Reply #424 on: May 04, 2018, 04:56:23 AM »
Based on the reports that vintagecb750 had a set of bad tensioner wheels, I replaced mine with the metal set.
