Author Topic: A Bike Is Born....750/1000cc  (Read 45415 times)
Offline bear
  • Leeton in Australia
Re: A Bike Is Born....750/1000cc
« Reply #200 on: December 17, 2014, 03:55:51 PM »
That's OK, I confuse my self sometimes so what hope have you got? ;) ;D
We remove the GL clutch and use the 4 bolt SOHC clutch on the GL shaft.
The GL clutches can be used with a bit of work, but I would have to chase up what's required.
It's been some years since we have used GL clutches and l can't remember why we stopped using them. :o
Brian
Online dragracer
  • CB750F Dragbike
« Reply #201 on: December 17, 2014, 06:30:38 PM »
Brian
Alright, I'm a bit dense here. Let me repeat what I think I understood you to say: Its not the transmission shaft from the GL you are using but the internally splined shaft attached to the outer clutch basket?????
Offline Tintop
« Reply #202 on: December 18, 2014, 06:04:05 AM »
I was told you just swap in the GL shaft that has the correct HiVo teeth to match the 900 crank.  Everything else is still 750.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline POPS 911
« Reply #203 on: December 18, 2014, 07:06:09 AM »
FRANK-BILL - TREY:     E-BAY RC327 CAM  brand new right here in OHIO  $130 today BIDDING STILL GOING ON !
Online dragracer
  • CB750F Dragbike
« Reply #204 on: December 18, 2014, 10:06:48 AM »
Thanks Pops. I've got a feeling it'll go higher than its really worth.
« Reply #205 on: December 18, 2014, 10:55:24 AM »
Find me a new 315 Pops.
Online dragracer
  • CB750F Dragbike
« Reply #206 on: December 18, 2014, 01:58:04 PM »
Alrighty now, so its item #1 and 2 on this schematic that we need. And not a shaft.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #207 on: December 18, 2014, 03:08:03 PM »
Got to have a shaft for the Hyvo chain hook up. But don't know for sure what's needed. Bill
BentON Racing Website
BentON Racing Facebook
Offline kmb69
« Reply #208 on: December 18, 2014, 03:14:55 PM »
Frank, If you are talking about the primary drive modification to mate a CB900 crank, it's a little more complicated than just swapping some parts. The easiest way to get there is to take the HyVo gear off of the GL primary and replace the sprockets on the CB750 primary with the GL HyVo gear (#3 in the picture). Also, you should put some new dampers in there while you have it apart. There's a guy in France that sells the kits. Keith
Online dragracer
  • CB750F Dragbike
« Reply #209 on: December 18, 2014, 06:30:49 PM »
That's what I posted to Jon in Reply#197 and just needed confirmation. Thanks for verifying that for me. I keep hearing everyone say shaft, but to me that's a splined sleeve that the primary clutch gear is made onto and riveted to the outer basket.  All good now. I'm now on the same page with the nomenclature. Yes, I do understand there are a lot of other issues to work through for this conversion.
Offline bear
« Reply #210 on: December 19, 2014, 03:17:53 PM »
Sorry for the confusion Frank.
Keith and yourself have mail.
Brian
Online dragracer
  • CB750F Dragbike
« Reply #211 on: December 19, 2014, 06:01:44 PM »
Brian
Thanks Bear. You've been much help so far. Sorry if i keep asking questions. My desires may outweigh my pocket. I'm just trying to be clear on the level of complication before i get too deep in this conversion. . Nevertheless, be on the lookout for future PM's.
Offline jweeks
« Reply #212 on: December 19, 2014, 07:22:25 PM »
Frank,
     I build Hondamatics - stroker Hondamatics, not clutch versions. I can't give you what I've not done. You've got the right people here to give you the details.
     Other thoughts - You need to add a tensioner to the primary chain for the stretch that will be happening with drag racing. The primary hy-vo chain needs to be built or sourced for the application. There's no major surprise expenses here.
     Does using Bear's recommendations on the 1100F rods with the factory part number pistons allow you to not need any spacers beyond available head/base gasket thicknesses? I ran a spacer using steel cb750 rods and off the shelf (at the time) Arias 73 mm pistons. In my application it shifted the powerband down which improved my ET about 3 tenths. You'll go quicker so long as it shifts.... ::)
Online dragracer
  • CB750F Dragbike
« Reply #213 on: December 19, 2014, 09:08:04 PM »
Frank,
Jon,
Ahhh, you had to bring up the shifting didn't you?? Lol. I've got the shifting issue solved, at least for now.
Cometic can make any thickness spacer you need via special order, so using the longer rods is definitely in my plans for this engine. Since a cam chain has to be specially ordered, i'll be cognizant about the extra length required due to the spacer under the block. I'll need some more help from you on the  cam chain tensioner and guide. The cam gear modification should be straight forward. Will get some direction on the primary chain and tensioner. I do have a 750 DOHC under the shed. I'll be pulling the engine off and tearing it down to look at the factory parts to see if any can be modified for use in the SOHC motor. I know i'll be studying the starter clutch set up for adaptation on the SOHC motor.
I'm not familiar with the Matic set up so i'll be leaning on our over seas brothern for direction on the clutch/primary set up they used. I've been put on the right path- i can't expect to get spoon fed every step of the way.
I may end up using the new 73mm Aries pistons i have to build this engine. I can save myself some money by using what i have. I'll have a machine shop bushen the rods to 15mm on the small end for the SOHC wrist pins. That is IF i can find the 1100 rods. My research crossed over  to CB1000 rods having the same part number by the way.
Again, i'm in no rush, this is just something to keep me occupied over the winter time.
Offline bear
« Reply #214 on: December 20, 2014, 03:09:27 AM »
Your right Frank there a few Hondas using the MA3 rods.
Brian
Offline bear
« Reply #215 on: December 20, 2014, 04:01:36 PM »
Spacers still required Jon.
My thoughts on the primary chain.
The Morse chains we use are very durable, I've never had an issue with them........but.
We have had some problems with the DOHC tensioners we have used in the past.
We have broken a number of thesr units over the years.
These days we use a manual adjuster made by a bloke in NZ and have not had issues since "touch wood".
There are some drawbacks fitting a DOHC tensioner, it requires two lugs to be welded into the bottom crank case.
The welding can be a bit tricky.
Could I suggest an alternative for the application you blokes are using these motors for.
I think a nylon block bolted in place of the tensioner would be a simple solution that would do the job and save a lot of stuffing around.
I would go down this road if I had a brain snap and decided to build another one of these motors from scratch. :o
My reasoning behind using the MA3 rods are two fold.
They are a very strong rod and they are affordable,  if you can find a set that is. ;)
 They will give you an acceptable stroke/rod ratio.
I have run into problems when I've gone under 1.7/1 in the past.
Brian
« Last Edit: December 20, 2014, 04:09:54 PM by bear »
    • BentON Racing
« Reply #216 on: December 20, 2014, 04:26:23 PM »
Doesn't Kenny's primary tensioner resemble that description? Haven't seen one yet. Bill
Offline jweeks
« Reply #217 on: December 21, 2014, 02:22:44 PM »
     I had to use a spacer for the +6mm stroke with standard height pistons. Using a gasket for the base doesn't allow the o-ring that seals the bottom of the block to the upper case half on the Hondamatic setup. I'd assume that the clutch versions are the same. My metal spacer has two o-rings, one on each side of the spacer. I've stayed sealed well there. Unless anyone knows of a sleeve that can replace the o-ring for the application? I use the 900F cam chain tensioner in my stroker with some modifications for mounting as Bear has referenced. Could I get the NZ source of the manual tensioner for this setup? I'm still looking to improve.
     Still curious about how much air the Cycle X heads flow, especially their road racing head. That should have the velocity that Bear and I would like... ;)
« Last Edit: December 21, 2014, 02:24:36 PM by jweeks »
Offline bear
« Reply #218 on: December 21, 2014, 03:20:18 PM »
Billy,
Haven't seen the Cycle-X tensioner either mate but would assume it would be for a SOHC rather than the DOHC units required for these conversions.
Jon,
I was referring to the primary chain tensioner in the previous post.
I use a cam chain adjuster sourced from a Yamaha quad bike on my Hi-Vo's.
The gentleman's name is Brent Hyde.
He fabricates a re-profiled camchain adjuster foot that may be of interest as well.
I will PM his email address.
Brian
« Last Edit: December 21, 2014, 03:31:45 PM by bear »
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #219 on: December 22, 2014, 04:34:44 PM »
POPS! Now that I looked I have a bunch of spare cams and one of them is a immaculate RC 327. Going to use it this season..
Online dragracer
  • CB750F Dragbike
« Reply #220 on: December 22, 2014, 10:22:05 PM »
I like the way my RC327 performs in my motor. I need another one.
    • BentON Racing
« Reply #221 on: December 23, 2014, 05:18:43 AM »
Yeh, me too!  :D Got one, but got to put it back in Cobra engine! Bill I could sell several if I had 'em!
Offline cbr954
« Reply #222 on: December 23, 2014, 07:11:30 AM »
I am going to be running 327 cams in both of my motors also.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline BPellerine
« Reply #223 on: December 23, 2014, 10:56:56 AM »
they went fairly cheap!bill
1978 CB 750K ard and webers
another anfob
Online dragracer
  • CB750F Dragbike
« Reply #224 on: December 23, 2014, 02:14:56 PM »
Who makes a similar cam to the RC327???
