Author Topic: Captain Rats - CB750K1 Project  (Read 10885 times)
Offline captain rats
Re: Captain Rats - CB750K1 Project
« Reply #50 on: February 22, 2014, 10:16:27 PM »
Is the front wheel in temporarily? Seem to remember the disc being on the other side?
Hah! Yeah I am a goose, it had twin discs when I got it, lucky you mentioned it. I would have been annoyed later. Thanks mate. Always take your book outside to the garage to reference..
« Reply #51 on: February 26, 2014, 12:22:05 PM »
Did some inside work tonight. The PO of my bike had left the bike outside with a cracked speedo glass. Over time this filled with water and the internals got quite rusty. I opened them both up to lube and inspect and the speedo would not turn. In the meantime I ordered new faces, and a later K2 - K7 speedo. I swapped the internals over from the later speedo into the housing of the K1. I was surprised that they all fit so well and interchanged. New faces and used the better glass and surrounds from the other later speedos and they came out great.
Super stocked with the result.
« Reply #52 on: February 28, 2014, 03:29:32 AM »
Cal.
That's a great idea. I will look at the parts fiche. That will tell me. I usually look at the cmsnl site.
Thanks for the idea!
Online Stev-o
« Reply #53 on: February 28, 2014, 05:11:44 AM »
Just ran across this....subscribed.
Have you considered Ikon shocks?
http://www.ikonsuspension.com/content/application_lists/application_lists.shtml
« Reply #54 on: February 28, 2014, 12:50:26 PM »
Hi Rats, Ikon are in NSW as well....  ;)  I've used them for years, good shocks....
81 Boronia Street
Albury North
New South Wales
2640
Offline Hutch
  • 1982 CB650SC
« Reply #55 on: February 28, 2014, 01:06:11 PM »
At under $200, why consider anything other than the Progressive 12 series.
« Reply #56 on: February 28, 2014, 01:15:13 PM »
Because for a few more dollars, the IKONS are better!
Offline Hutch
  • 1982 CB650SC
« Reply #57 on: February 28, 2014, 01:37:43 PM »
For my application as an example, Ikon 76 series $380 vs. Progressive 12 $190, with a 50% increase in cost are they 50% better... dunno.  Law of diminishing returns.
« Reply #58 on: February 28, 2014, 02:15:54 PM »
In my opinion, YES they are worth it. I have owned both. I replaced the Progressives with the IKONS. Suspension and brakes are the most important things on your bike.  If you are happy with the Progressives, great.
« Reply #59 on: February 28, 2014, 03:11:40 PM »
Progressives are not as good as the Ikons, they are more of a replacement shock than a performance shock, I know guys that race Honda/4's with Ikons and Hagons, don't know any that race with progressives.. You get what you pay for...
« Reply #60 on: February 28, 2014, 05:30:41 PM »
A bit more work, got the 290mm shocks from Cycle X on by changing the configuration of the bushings. Its low and firm, not sure how much fashion to put before function. Will ride them and see how it travels, the ikons etc seem like a nice upgrade.
I am going to try run it stock looking and mocked it up a bit. The seat is a bit lower than standard and I think I will just run the rear guard. I have some alloy café seat that looks ok but I might swap it out after I get it signed off by the transport authorities.
Put the carb airpods on it, oil tank and kicked some oil around it. will get the wiring circuit up to a starting level and go from there.
its actually looking quite ghetto, I do prefer it to look a bit like its been dug out from behind a dumpster..
« Reply #61 on: March 01, 2014, 11:06:04 PM »
Trying to get my head around this wiring. It sucks!!
I mostly just want to get it started and then go from there. There seems to be a heap of connections that don't seem to match up. The PO had repaired wires over the years and added changed things beyond stock so I dont really know what should go where. The wiring diagrams are a bit of a help but the replacement harness is not exactly matching up.
One problem I am having is working out what this is? That cylindrical (aluminium) thing behind the coils. It looks factory, has 4 wires out, on the old bike one (Brown with red stripe)went to a red overspeed warning light the other came from a yellow wire that is only in a wrecked handlebar switch mechanism (not yellow with a red stripe) and the other two end up looped into each other. I can see this on any other bikes I have looked at photos of nor in any wiring diagrams. Is it because it is a Japanese bike?
« Reply #62 on: March 19, 2014, 03:55:35 AM »
Getting some where now.
Finally got enough stuff on it to get it started. I have a video which I will post up once I get it uploaded. I have two k1's and need to sell one, I prefer original/mostly stock looking bikes but i am resigned to the fact that one needs to be a cafe due to the parts I have. Here is a pic of it, I actually think it might be a bit of fun to ride around and be very hipster in my local city, might have to grow a beard and get some redwings.
« Last Edit: March 19, 2014, 04:41:02 PM by captain rats »
« Reply #63 on: March 20, 2014, 03:08:05 AM »
Ok, uploaded the video.
Obviously some bits are missing, I just wanted to get her fired up, seemed like a big milestone then I can sort out the rest. Love the sound of the pipe.
Cb750 k1 motogpwerks pipe sound
Online Stev-o
« Reply #64 on: March 20, 2014, 05:31:03 AM »
Yes, sounds great.
Offline tweakin
  • tear down
« Reply #65 on: March 20, 2014, 06:34:28 AM »
Congrats on getter her fired!
Offline Ford40
« Reply #66 on: March 20, 2014, 07:17:18 PM »
I like this seat, do you have any info on where its from.
« Reply #67 on: March 21, 2014, 02:31:07 AM »
Yeah thanks guys.
About the seat, I got it with a project bike. Think it was from California. I can prob find out if you really want to know.
« Reply #68 on: June 18, 2014, 01:09:15 AM »
Have been quietly working away. It is amazing how much you learn by working on these bikes. I am so glad I have a few other bikes in various states of array to steal parts from.
Carbs were a real pest to get set right. Its amazing how many times this forum combined with Hondamans book have helped.
Here it is as she sits. I still have to sort a few more things out to get rego. It is too loud so I baffled the sh!t out of the GPwerks pipe to quieten it down.
This is close to what it will look like, I have had to do some things for rego. Wish me luck to pass inspection and I will be on the road.
Online Stev-o
« Reply #69 on: August 23, 2014, 03:26:47 PM »
Good Luck....is it on the road?  Looks great...
