Author Topic: Stripped M6 holes on fork lower  (Read 3041 times)
« on: September 25, 2013, 04:43:49 AM »
What do you do with those?  Drill it and tap it for M8?  Or hellicoil?
There are three holes for brake bracket, the bottom is M8, the top two are M6 and the M6s I trust for now, but I would like to fix them before too long.
I have a left lower in good shape, but it is also a problem of inspection sticker.
Ideas/solutions?
Re: Stripped M6 holes on fork lower
« Reply #1 on: September 25, 2013, 06:10:26 AM »
Can you tap up to the next non metric size or don't you want to mix that in.
« Reply #2 on: September 25, 2013, 06:30:39 AM »
Neat idea!  SAE could be right there in between M6 and M8, I will check it when I get home.
I could also replace the lower and get a new inspection or carry the paper with me :)  - anything is cheaper than brake bracket getting loose while breaking.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: September 25, 2013, 06:35:30 AM »
1/4 BSF will tap straight into the M6. Have used this fix on the odd camtower bolt thread with success in the past.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #4 on: September 25, 2013, 06:41:50 AM »
Regular coarse 1/4"-20?
Looks like that's the easiest way to go with some flanged bolts.
Thank you!
« Reply #5 on: September 25, 2013, 07:27:41 AM »
Why not helicoil? Fix it right.
 The difference between 6mm and 1/4 inch is only 16 or 20 thousandths.  ..a 1/2 mm or less, so that will not be strong enough.
Offline Ewan 500K1
    • Adams Bros Probe 2001
« Reply #6 on: September 25, 2013, 07:43:23 AM »
got the same issue here .. I'm helicoiling ... got the M6 kit for 8.50 UK poundsoff ebog
jings, crivens, help ma boab
500 four K1 cafe racer build thread at :
http://forums.sohc4.net/index.php?topic=100883.0
Offline Fritz
« Reply #7 on: September 25, 2013, 07:51:27 AM »
Had the same problem.
V-Coil might be a cheaper alternative to Helicoil. I've used both and have not seen any difference in quality:
http://www.newark.com/v-coil/04010/thread-repair-kit-m6x1-0/dp/74M7201?in_merch=Popular%20Hand%20And%20Workholding%20Tools
1976 CB550F
Offline Ewan 500K1
« Reply #8 on: September 25, 2013, 09:41:23 AM »
This is the one I Used , cost £8.45 over here = $13.56
http://www.ebay.co.uk/itm/310678382294?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
It works fine
« Reply #9 on: September 25, 2013, 09:42:22 AM »
Thank you, I am pretty sure I can find it in our local hardware store.
Offline Tews19
  • I am no
« Reply #10 on: September 25, 2013, 11:40:19 AM »
I have 2 sets of K1 lowers that I don't use and an early K0 lower with the hard to find lip..
1970 Honda CB750 survivor.
« Reply #11 on: September 25, 2013, 11:42:28 AM »
Thank you, these are later forks, went that way for dual brakes - T bracket style.
Offline mysta2
« Reply #12 on: September 25, 2013, 03:15:24 PM »
The idea of mixing sae with metric makes me cringe, possibly showing my OCD.
Helicoil, re-thread, v-thread(which I've never heard of) is the only right way to do it. Here in Texas I've seen the kits at most chain auto parts stores. Aircraft are exclusively built with these things, there shouldn't be any strength concern. If you can manage it, get a preload-able installation tool instead of the split ones, but you should be able to manage with any, especially with ones as big as M6s. Pre-loaders just make them really hard to mess up.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #13 on: September 26, 2013, 01:36:04 PM »
helicoil works great. I've had to helicoil three of my exhaust studs all with great success. I bought a kit off of ebay that had all the stuff I needed, 6 helicoils, a drill bit and a set tool.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline LesterPiglet
  • 1977 CB550F2
« Reply #14 on: September 26, 2013, 02:07:06 PM »
Got mine welded (free) and retapped to original. Pity they were the wrong bottoms for my 550.
« Reply #15 on: September 26, 2013, 07:51:15 PM »
I would helicoil before welding..much stronger thread and less work involved.
  • 1977 CB550F2
« Reply #16 on: September 26, 2013, 07:52:50 PM »
There were cracks right to the outer Frank. Hey it was free.  :)
If the meat is there, yeah rethread. Doesn't matter what size as long as it works.
Offline robvangulik
  • Honda Fourever
« Reply #17 on: September 27, 2013, 05:46:31 AM »
I'd helicoil them, if you got parts from a PO with mixed SAE and Metric threads you'd curse him..... ;)
