Author Topic: "The Basement Build!" 1973 Cb350F  (Read 67992 times)
Re: "The Basement Build!" 1973 Cb350F
« Reply #100 on: February 07, 2014, 07:23:01 AM »
+1  If you ever want to see how bad two steps forward, one step back can be, take a look at my 750 Nine Lives build thread.  Yikes!
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #101 on: February 07, 2014, 08:35:03 AM »
Get very used to it. You can not realistically expect to tear down a 40 year old bike on a very tight budget in your basement and have everything go "swimmingly".
It's kind of like losing weight- it took time to put it in, it will take time to drop it. The best advice you'll hear is to take breaks from the work when things go wrong. Tempers and frustrations derail more builds than money. Set realistic goals, manage the work load, and when you encounter something "dodgy" FIX IT. Then it's right for the next 40 years and you won't lose time re-doing things.
Even professional builders hit setbacks. And I dare say every member here has hit 1 or 2 on every build.
In fact, I just got my bike back from tuning, running like a scalded dog, painted, ready to go. Voilá! Gas tank leaks! Got strip it back, weld it, and re-spray. Talk about wicked bummed...
Yeah  guess i was due for something to go wrong.      Im going to try and solder the wire somehow and see how it works, if not ill try and find a used one on here or bit the bullet and buy one off Ebay for 80$  Thanks for the advice
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #102 on: February 07, 2014, 08:40:20 AM »
The good thing is that it will be fixed and you won't have  to worry about that part going south later!
Offline wowbagger
  • Not much of an
« Reply #103 on: February 07, 2014, 08:43:06 AM »
Yup, better for it to break now than in a parking lot somewhere in the rain.  ;D
« Reply #104 on: February 07, 2014, 08:47:02 AM »
I've broken down far enough from home to make it a pain in the butt.  AAA RV/Motorcycle tow service is good to have!
« Reply #105 on: February 07, 2014, 09:18:42 AM »
Yeah ill keep that in mind when i drop the money for such a little part! OH well its what you get with a rebuild! Still gotta figure out how to put new throttle cables, grips,and adjust everything after i get the new part! fun fun fun
« Reply #106 on: February 11, 2014, 04:20:16 PM »
Starting to use some of the parts from DCC.  Ill be down tonight trying to get the handlebar situation done tonight so ill update as it goes on.
Ordered some LED bulbs for my new gauges, installed them as well as gutted the wires and bolts from my previous pair.
Also starting to prep some parts for paint. More to come.
Oh yeah remember that switch incident? Girlfriends dad hooked me up with some small soldering, reheated the original and installed a new wire for me!  No reason this shouldn't work right?? My hands shake way to much for me to do this, now ill reassemble the switch and hope it works!
« Last Edit: February 13, 2014, 08:49:04 PM by 2strokeTRush »
« Reply #107 on: February 11, 2014, 08:23:37 PM »
Ah we are expecting a big snowstorm this week in Baltimore, so maybe i will get lucky and have some extra work time!
Didn't get the bars put together because of a bolt i can't free up.  But i test fitted them and it seems like something is a little off.  When i set the old bars down in the spot it fits perfectly, but the new bars do not go on as snug. I bolted them down tight, but it almost looks like there is some space still and I am wondering if thats safe!
I really do like the look though!
Also cleaned, pulled the rust off, and PlastiDip'd the rear fender the same way i did the front.
Also my new gauges are a little chipped up so i practiced painting the old ones to see how they would turn out after some light sanding, looks like i will be doing my new ones this way as well.
Also noticed something I hadn't seen before, on the bottom of my left sprocket cover, I have a hard time believing that is came like this fro the factory, looks chipped and broken. Maybe sometime through the years she threw a chain and snagged it. Just interesting
Offline bjbuchanan
« Reply #108 on: February 12, 2014, 07:49:09 AM »
Like Cal said, if it fits tight you are good. The center size/width of the bar could cause it to appear slightly undersized. Either way the tape would work nicely, I do that with cheaper bar end mirrors to help the grip.
That sprocket cover is definitely a tossed chain. You can source another from a WTB or clean it up with some files and run it. Weight reduction ::)
What Plastidip are you using? I want to do something similar and saw you mention something about it coming off easy if you want? I use the regular can stuff, you spraying?
I feel you on the storm, I'm considering moving the GF's 400f inside to get some blizzard work in
« Reply #109 on: February 12, 2014, 08:15:27 AM »
Yeah i plan on just smoothing the sharp edge over and tossing it back on! And yup plastidip is great stuff, clean your applied area with parts cleaner and spray it on, I do usually 4coats of it letting the first and last dry the longest.  And if you want to take it off just pressure sprayer works just fine, or you can peel it off to.
« Reply #110 on: February 13, 2014, 12:54:21 PM »
Well guys the storm hit us pretty good! 12 inches, so no school or work for me today, got done some prep and paint for now, ill be back down later to fiddle some more though.
roughed up the frame a little in some spots and hit her with the black paint, not everywhere but covered up some bad spots.
Also did the hanging parts paint box trick I learned from here:
Found something i hadn't seen before, not sure if this is from the factory, previous owner, maybe someone had this at a machine shop for work before me? Anyway anyone ever seen anything like this before? Looks like sharping reading "R21"
Offline bjbuchanan
« Reply #111 on: February 13, 2014, 03:20:15 PM »
It's production writing on the engine. i thought the same thing when I saw V-- on mine, I thought it was a swapper or something but nope, just factory marking.
Online Stev-o
« Reply #112 on: February 13, 2014, 03:45:33 PM »
Youre painting in the house??
« Reply #113 on: February 13, 2014, 04:07:54 PM »
Aaahh gotcha just funny i never noticed it.
Yes sir, had the side windows open and I wore a mouth mask, might smell for awhile tho ;D
« Reply #114 on: February 13, 2014, 08:47:01 PM »
Had planned on doing more then I actually got done tonight, but I found this little gem on the Local Craigeslist, so I threw the ole Toyota down in 4x4 to get through the 12 inches of snow we got plus plowing though the extra 5 still coming down and picked up this 48" Hi-Lift Jack, Basically a Really tall jack for lifted trucks like mine,used on trails.  Disassembled, Cleaned, painted and greased! Will come in handy!!
Also made a few brackets and painted them, Ill weld a few bolts on them an make a holder for the jack.
Anyway, back to my other hobby and what we are all here for:
hadn't really planned on planting these, but they were so sun faded I figured i would try!  Anyone know what kind of paint works best for these?
Still have to get that dang bolt off the throttle body, then I can put the handlebars and dash back together.
« Reply #115 on: February 16, 2014, 07:52:16 PM »
Sorry for no update on much recently guys, I took the test for the Maryland Transportation Authority Police so my nerves have been a little off, But my parents got me a new tach cable and some awesome tank knee pads for my tank for my Birthday! Pretty pumped!
« Last Edit: February 17, 2014, 06:41:22 AM by 2strokeTRush »
« Reply #116 on: February 18, 2014, 08:37:42 PM »
Got the new Taillight installed!  Took some modifying to get it the way I wanted, but it looks good I think!  Only thing is, the old one had 3 wires, and this one has 2.  What should I do here??
Still have some tiding up to do:
Just left with this huge hole, and the old mounts for the last light, I want to cover this up somehow.  I was thinking maybe JB weld over it, and smooth it down? or get a sticker to put over it?
Offline wowbagger
  • Not much of an
« Reply #117 on: February 18, 2014, 09:24:12 PM »
I've got the same tail light. I swapped the tip on the stock ground wire for a crimp on eye tip and connected it to one of the bolts. You don't actually need it though since the tail light grounds through the metal housing. I just added the ground wire to ensure I had good ground.
« Reply #118 on: February 18, 2014, 09:33:48 PM »
Awesome thanks!  I assume black wire on the new Taillight is Ground?
Offline bjbuchanan
« Reply #119 on: February 19, 2014, 06:18:52 PM »
No, the bike doesn't have a ground wire, it grounds through the housing. Me and wowbagger did the same thing, run an eye on the end of the stock green wire to a mount bolt. It is more confidently grounded that way.
The black and red are brake and tail. Ground it, and hook it up. If the running tail is brighter than the brake, switch the black and red around. Brighter is the brake light
« Reply #120 on: February 19, 2014, 10:23:05 PM »
Thank you!
« Reply #121 on: February 19, 2014, 10:47:52 PM »
Well I'm headed to Tennessee in the morning so I figured i would post this before I leave.
PlastiDiped my fork tubes, and headlight bucket ears, not sure how I feel about it yet,  I didn't want to take the forks off just to paint a few parts, I guess it looks good.
Picked up some small new turn signals, they are carbon fiber look.  Well see how they turn out.
You can't really see them in this picture, but you get it.
Complete with some new Birthday additions:
Offline dagersh
    • Photos
« Reply #122 on: February 20, 2014, 09:24:12 AM »
Nice progress and Happy Birthday!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #123 on: February 20, 2014, 05:01:37 PM »
Gersh
Thank you sir!  Time to tackle my 20's!!
Offline dagersh
    • Photos
« Reply #124 on: February 21, 2014, 03:40:14 PM »
Jeez - just a babe in the SOHC4 woods!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
