i carefully went over the bike on the weekend. here's what i found, front to back.
front fender a bit dented, but not too bad.
some roadrash on that stay. chrome is gone here, will develop some rust.
also a bit of roadrash on the front/left indicator light but nothing to worry about.
clutch lever is a gonner. rest of the left hand control is working fine.
a massive dent in the speedo holder. that must have absorbed most of the impact?
that thing is outta shape...
no suprise, lights in the speedo don't work either.
left mirror also got some scratches. looks like this will also be come a rust spot.
left grip has a bite taken out as well.
gear shift pedal is bent.
honda cover is ripped off.
left footrest has some scratches.
also rear indicator... just a little.
rear mudguard and light are chewed up.
i checked the fame and fork for alignment, they're fine. gears shift, engine runs, all the existing lights work...
then i took the speedo and tested it with a drill because if was concerned about the impact it received - needle doesn't move and it makes a funny noise. i think that might be the biggest damage in terms of repair or replacement.
anyway, it could be worse.
