Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 213672 times)
Re: 1975 CB550K1 - Stock-ish Restomod - More Mods
« Reply #650 on: April 13, 2021, 04:44:37 PM »
Jeff aka Godffery back at it!  Sight Glass and Slave Cylinder mount all tig-welded in place.
Untitled by Donald Leonhardt, on Flickr
Next comes Glyptal sealing.
« Reply #651 on: April 14, 2021, 09:48:44 AM »
Look really good!
Fine craftsmanship to admire! ;)
« Reply #652 on: April 16, 2021, 06:51:11 PM »
Hydraulic Clutch Cover from Godffery complete!
DSCN3913 by Donald Leonhardt, on Flickr
New silver glyptal coating
DSCN3914 by Donald Leonhardt, on Flickr
Can't wait to install this and see how it works!!
Online grcamna2
« Reply #653 on: April 16, 2021, 08:19:01 PM »
Don,that turned-out very nice.I hope it is as smooth and progressive as can be and makes shifting great.  8)
« Reply #654 on: April 17, 2021, 12:55:36 AM »
Me, too!!
« Reply #655 on: April 17, 2021, 04:14:55 AM »
Very unique bit of kit and nice work.
« Reply #656 on: April 17, 2021, 04:55:44 AM »
I like that too, will look as stock for non CB550 people.
A bolt on kit for more bikes would be fine. Or a gearing mechanism making a hard clutch softer.
« Reply #657 on: April 18, 2021, 08:13:44 PM »
With the Barnett springs on my 550, it's a pretty stiff pull.  It's manageable but not as easy to feather.
Online grcamna2
« Reply #658 on: April 18, 2021, 08:41:00 PM »
These are installed on your bike with the 550 engine,do you have that engine pumped-up ?  :D
« Last Edit: April 18, 2021, 08:42:54 PM by grcamna2 »
« Reply #659 on: April 18, 2021, 08:49:19 PM »
This motor is fairly stock.  I was getting some clutch slip at higher revs.
Offline algophobe
« Reply #660 on: April 18, 2021, 09:16:16 PM »
nice one Don, always taking it a notch or two up!
Ducati Hypermotard 950 SP 2020 "Percolo"
Honda cb750 café 1972 "Satmui"
Kawasaki zx6r 2005 "Garuda"
Kawasaki zx7r 1998 "Dharma" (stolen)
Honda Magna V4 1982 (sold)
« Reply #661 on: April 19, 2021, 01:24:53 AM »
-Slip with motorcycle wet clutch oil?
I often used car oils in the 80's.
It got Mobile 1 I thought should be good.
When I slammed in 5th gear at WOT, it slipped. Reduced throttle a little, WOT again it sounded like shifting to a needed 6th gear ;)
A few years earlier (mid 80's) Castrol GTX2 that worked fine. Engine took some oil when riding fast all day long on Autobahn.
Easier today thanks to Internet making it easy to improve the knowledge and read others experiences.
« Reply #662 on: April 19, 2021, 08:58:10 AM »
Without getting into an oil discussion, I am using appropriate spec oil.  I was getting some slip at high revs under heavy load, so I swapped to HD springs and replaced the plates.  The pull of the cable clutch (yes I lubed the cable) is someone stiff so I wanted to do the hydraulic actuator.  I'm getting Godffery's new clutch cover/slave cylinder today or tomorrow, so I'll be installing it this week.
Online grcamna2
« Reply #663 on: April 19, 2021, 02:23:48 PM »
Don,are you going to have a larger piston in Godffery's new slave cylinder,and I imagine that will be a better ratio for your clutch master cyl. piston size(12 or 14mm?)to give it usable travel plus less resistance.
« Reply #664 on: April 20, 2021, 10:06:23 AM »
I am not sure what the specs are on the Oberon slave cylinder (since the part is still in transit from the Post Office).
Offline Godffery
  • Godffery's Garage
« Reply #665 on: April 20, 2021, 11:06:41 AM »
29.5mm
« Reply #666 on: April 20, 2021, 12:47:29 PM »
The Beringer MC is a 12mm.
Online grcamna2
« Reply #667 on: April 20, 2021, 01:25:27 PM »
That sounds like an excellent match.  8)
« Reply #668 on: April 20, 2021, 06:48:18 PM »
Jeff aka Godffery concurs that it should be effective.
I cannot tell you how good this cover looks in person.  Jeff is a craftsman.
« Reply #669 on: April 21, 2021, 06:28:22 AM »
Looks great Jeff/Don!  What is the finish on the outside of the cover?
We are all impatiently waiting on hearing how this will look and perform!
Offline Godffery
  • Godffery's Garage
« Reply #670 on: April 21, 2021, 07:23:58 AM »
The finish is a glass-bead blast, then washed with soap & water, Dried and heated to about 150° F for a final treatment of paste wax to resist corrosion and staining. (Additional wax treatment can be done with regular maintenance, as desired)
Here is a brand I've found that will Not leave a yellow powdery residue.
« Reply #671 on: April 21, 2021, 09:26:02 AM »
This glass bead finish looks very similar to the peened vapor blasting finish.
« Reply #672 on: April 23, 2021, 07:55:53 PM »
Clutch plates soaking in oil overnight for installation tomorrow!
Online grcamna2
« Reply #673 on: April 23, 2021, 09:09:44 PM »
Going with fresh plates,a good idea.
« Reply #674 on: April 24, 2021, 10:11:31 PM »
Installed the new clutch pack along with the Godffery hydraulic clutch cover with oil sight glass.  Installation went smoothly and without incident.  Everything fitted up perfectly.  The glass-bead finish matched up great to my vapor-blasted engine covers with a freshened-up satin finish.  I also gave the brake lever a quick blast to clean it up.
Now to plumb the new hydraulic line from the Beringer MC to the Oberon slave cylinder.
IMG_0116 by Donald Leonhardt, on Flickr
IMG_0117 by Donald Leonhardt, on Flickr
IMG_0118 by Donald Leonhardt, on Flickr
Fantastic work, Jeff aka Godffery!
