Author Topic: compression testing thoughts  (Read 3128 times)
Offline DWS
  • Treat others as you would like to be treated .
« on: October 22, 2014, 05:05:02 PM »
Here are my testing results'
1st cylinder
cold-50
warmed up-100
wet-150
2nd cylinder[/color]
cold-60
warmed up-91
wet-145
3rd cylinder
cold-55
warmed up-92
wet-150
4th cylinder
cold-60
warmed up-93
wet-130
can someone help with the figures please
thanks
Duane
« Last Edit: October 22, 2014, 05:10:06 PM by DWS »
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Re: compression testing thoughts
« Reply #1 on: October 22, 2014, 05:41:10 PM »
Sorry, you should say little more.  Is it a fresh from the barn bike, daily rider you doubt or freshly rebuilt engine?
Offline DWS
« Reply #2 on: October 22, 2014, 05:44:50 PM »
i bought it new in 78 but been sitting for the last 15 years i have restored everything but the motor it only has 15000 on it
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline DWS
« Reply #3 on: October 22, 2014, 06:11:06 PM »
i need to check the valves, yes i did open the throttle all the way.
its an old cheap tester.
i'am at 5000 feet here also
« Last Edit: October 22, 2014, 06:12:59 PM by DWS »
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline DWS
« Reply #4 on: October 22, 2014, 10:20:01 PM »
Thanks ill try a good tool
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
« Reply #5 on: October 23, 2014, 12:14:44 AM »
if the bikes been sitting as you say a few decent rides should see the compression come up,use the same guage as that's your baseline.
« Reply #6 on: October 23, 2014, 03:17:34 AM »
^^^ That.  Very likely you will be happy with it after you put some miles on it.
Offline Vinhead1957
« Reply #7 on: October 23, 2014, 04:52:02 AM »
That bike needs the snot run out of it!   Worry about compression when a problem running pops up. Otherwise ride!
Offline DWS
« Reply #8 on: October 23, 2014, 02:46:22 PM »
Now that puts a smile on a guy!
That is what ill do.
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: October 23, 2014, 03:24:35 PM »
Most definitely +1.
 I purchased an 83 gl1100 earlier this spring with a locked up engine due to the previous owner letting it set outside for 4 years and rain getting in the cyl's. It only has 34k miles which is chump change for a GL and I was able to free the engine without tearing it apart. At first it would smoke a bit on a cold start up but now it doesn't smoke at all and compression tests keep improving and I've only put maybe 1k miles on it so far but basically as Dave and 70CB750 pointed out what the engine needed more than anything was to be ridden.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #10 on: October 23, 2014, 04:04:15 PM »
How much "wet" volume did you add to the tiny cylinders?
But, I agree, run at least one hundred miles.  What's the worst that will happen?  A top end job?  I'd rather do those later than sooner.
Offline DWS
« Reply #11 on: October 23, 2014, 06:58:01 PM »
two pumps from a small oil can, 2 to 3 cc
I also adjusted the valves to .003 on every Valve and adjusted points.
I'll do the timing tomorrow.
What do you think that  I should set the points at?
and advancement?
5000 feet here
1978CB750F3
Spark plugs- 24"
valves- .003"
Points- 14
 Carb's 42A
stock air box
4 into 1
#35 slow jet
#110 main
2 turns out on the slow jet
4900 feet elevation
Timing is at --1&4 F mark now
advance,  not sure what i was seeing timing light.
« Last Edit: October 23, 2014, 07:21:06 PM by DWS »
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
« Reply #12 on: October 23, 2014, 07:11:21 PM »
two pumps from a smll oil can, 2 to 3 cc
That's fine for a car engine.  The compression chamber is only about 13 cc on the 550.  I expect a lot of your compression increase is due to the volume displacement change from the added oil volume. Changing from 13 to 10 cc is significant, as it is a smaller space to compress the swept piston volume into.
In general, you only want to use enough oil to wet the rings for a possibly better seal, not change the compression ratio.
There is/was a FAQ entry about this.
Offline DWS
« Reply #13 on: October 24, 2014, 09:09:23 AM »
Good to know that, thanks 8)
need to ride it i guess but need to sync the carbs but dont have the sync tool! can i make one or do they not really work?
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
« Reply #14 on: October 24, 2014, 09:20:05 AM »
i just go for the lov kost  4 gauge type...they does the job easy and presise...
(.and are easyer then fluid and a lot of meters of gas lines..and spilled atf oil all over the place..sucking dirt up the next many years..dripping oil dovn the vall...until the day your vife throv it all aut) ;)
Offline DWS
« Reply #15 on: October 24, 2014, 09:34:59 AM »
Your probably right
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline garyS-NJ
« Reply #16 on: October 24, 2014, 10:09:47 AM »
like the others said, I'd be happy and ride if the motor runs OK and not blowing a ton of smoke.  and 4 cylinders around 140PSI I'd be happy.  If you're curious you can wet the rings with oil and blow the oil out putting your thumb lightly over plug hole and then test compression.  the book says .002 intakes and .003 exhaust  but some folks say .004 on both and others run larger clearance.  for the Points use 0.015".  find the shop manual online.  I put a dyna in last year and happy with it.
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
Offline DWS
« Reply #17 on: October 24, 2014, 10:25:03 AM »
i have mine set at .003 ex and in, from hondaman for this bike, he said that it will run a little cooler and lease tapping knock.
where did you get your info from?
my points are at 14 now
i have lots of different manuals plus hondamans book, just got the book after i'am almost done.
doesn't the manual say .002 and .005?
I would love to get the dyna.
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline thirsty 1
« Reply #18 on: October 24, 2014, 04:24:42 PM »
Chop the hose off of that gauge and try it again. I'd also run that old girl and see what happens.
« Reply #19 on: October 24, 2014, 05:36:00 PM »
no make it longer
then youll get this much compression
Offline thirsty 1
« Reply #20 on: October 24, 2014, 06:00:04 PM »
What gives Dave. The long hose will take up volume and chase a lower number.
« Reply #21 on: October 24, 2014, 06:38:40 PM »
this has been gone over dozens of times,the hose has a one way valve at the spark plug end,itll still compress up just take a couple more pumps,for example fit a larger tank to your air compressor,itll just take longer to reach max.
Offline thirsty 1
« Reply #22 on: October 24, 2014, 06:58:07 PM »
Haha just checking your game.  :D. Pressures, Pressure. Pascals law. Cheers bud it's Friday!
« Reply #23 on: October 24, 2014, 06:58:51 PM »
pascal was a rascal!lets not forget this,on second thoughts maybe we should?
http://forums.sohc4.net/index.php?topic=133013.0
« Last Edit: October 24, 2014, 07:04:17 PM by dave500 »
Offline thirsty 1
« Reply #24 on: October 24, 2014, 07:21:30 PM »
Oh jesus hell...
