Author Topic: I've got some cyl. head ports to clean up..;what could I spray inside ?  (Read 2416 times)
Hi,
I want to clean up the ports in my engine before I remove the valves and wondered what I could buy to spray into each port and let sit for a while to really dissolve the stuff like Gumout,etc.,only the Gumout will evaporate pretty quick...
I don't have a shop or a sand/glass bead blaster,just a storage & and Apt. so I'm doing most of the work in my apt. where it's above freezing.Looking forward to Spring  :)
I really want to do this port cleaning myself rather than paying a shop to glass bead it.
« Last Edit: February 07, 2015, 05:33:38 AM by grcamna2 »
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: I've got some cyl. head ports to clean up..;what could I spray inside ?
« Reply #1 on: February 05, 2015, 05:08:37 PM »
Try some Simple Green, it cleans pretty well and won't stink up the apartment.
......Paul
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
« Reply #2 on: February 05, 2015, 06:11:34 PM »
I'll do the Simple Green as a last step.I'll put the head outside while it's soaking but something stronger would be better so I have less scraping later;the goal will be to soften/melt off as much carbon as possible before I start disassembly.
« Last Edit: February 07, 2015, 05:34:59 AM by grcamna2 »
Offline Restoration Fan
  • My wife will never call me
« Reply #3 on: February 05, 2015, 08:11:14 PM »
Marvel Mystery Oil will help it but you'll still have to do a good bit of scrubbing.
Offline rb550four
« Reply #4 on: February 06, 2015, 02:21:36 PM »
so if the head is off and you are removing the valves, Why not wait to clean until the valves are out.
You can spray it with gummout or brake cleaner with 1/2, 3/4" copper  plumbing cleaning brushes on a battery op drill, Then clean everything at once before assembly?
« Reply #5 on: February 06, 2015, 04:16:30 PM »
rb,
I like what you're saying about the 1/2 & 3/4" copper plumbing cleaning brushes;I was hoping to use a very strong product prior to removing the valves so I have the added benefit of letting the ports soak for a while to really soften that crap up and clean up should be much quicker.Have you used those types of brushes much? is that the correct name I should give a plumbing supply company to get the right ones ?  Thanks
« Reply #6 on: February 07, 2015, 03:22:58 AM »
I had my head blasted at local powder coating shop. Just chambers before pulling guides out and it was less than $30. Money well spent.
« Reply #7 on: February 07, 2015, 05:40:50 AM »
That's exactly what I would prefer,to have a shop glass bead blast the ports,unfortunately I had to(my stickers expired on my 87' last month..)run my car through inspection a couple days ago before I got caught riding around w/ expired stickers.. and the added expense of that destroyed my budget for the month and now I'm down to 'make those ports shine like new' w/o glass bead blasting.
That's a challenge to figure out  ::)
« Reply #8 on: February 07, 2015, 12:26:01 PM »
To bad you weren't closer....I'd it the ports and chambers for 15.00 (on a degreased head).
« Reply #9 on: February 07, 2015, 12:51:17 PM »
ROAD TRIP!  ::)
« Reply #10 on: February 07, 2015, 02:42:55 PM »
Yeah buddy  ;)
