Author Topic: GL1000 Front End: Alternate Triple Trees?  (Read 8953 times)
Offline CG2000
« on: February 16, 2015, 10:45:11 PM »
I tried fitting up a '76 GL1000 front end on my '76 CB750F Frame today. The top triple tree is pretty weird looking with those extended handle bar clamps.
Can anyone suggest alternate triple trees that are compatible with the GL1000 fork diameter and wheel width?
Here's a list of all the bikes with the same fork diameter, but I have no idea of the fork spacing or stem design compatibility:
37 Honda CR-80R (96-98)
37 Honda CR-80R (99-02)
37 Honda CR-85R (03-04)
37 Honda CR-125R "Elsinore" (79)
37 Honda CR-125R "Elsinore" (80)
37 Honda CR-250R "Elsinore" (78-80)
37 Honda NX-250 (88-90)
37 Honda XR-250R (81-82)
37 Honda CMX-450C (86-87)
37 Honda CX-500TC (82)
37 Honda FT-500 "Ascot" (82-83)
37 Honda VF-500C "Magna" (84-85)
37 Honda VT-500C "Shadow" (83-84)
37 Honda VT-500C "Shadow" (85-86)
37 Honda XL-500R (82)
37 Honda CB-550SC (83)
37 Honda CBR-600F "Hurricane" (87-90)
37 Honda CB-650SC "Nighthawk 650" (82)
37 Honda CX-650T "Turbo" (83)
37 Honda VF-700C "Magna" (84)
37 Honda VFR-700F "Interceptor" (86)
37 Honda CB-750F (81-82)
37 Honda VF-750C "V45 Magna" (82-83)
37 Honda VF-750S "Sabre" (82-83)
37 Honda VFR-750F "Interceptor 750" (86)
37 Honda CB-900C "Custom" (80-82)
37 Honda GL-1000/K "Goldwing" (75-79)
This list except is from: http://www.dotheton.com/forum/index.php?topic=1090.0
Cheers, C.
« Last Edit: February 16, 2015, 10:49:23 PM by CG2000 »
'76 CB750 | '72 CB350 | '96 XR650L | '06 KTM EXC 450 | '02 KDX220R
Offline chewbacca5000
  • I polish covers!
Re: GL1000 Front End: Alternate Triple Trees?
« Reply #1 on: February 17, 2015, 03:42:43 AM »
Alot of people mill those risers off and go with clip-ons.  It is fairly easy to do if you have access to a mill or machine shop in your area.  Some maker spaces or hacker spaces have machines as well.
Cognito moto has some really nice top clamps as well.
Offline Old Scrambler
« Reply #2 on: February 17, 2015, 11:30:13 AM »
I milled mine to the base of the bar-mount............that left sufficient material to tap and mount for possible future needs.
Not on the list but with slight machining the CBX1000 triples are same or near the stock CB750 width.......and have the advantage of an alloy lower with double pinch-bolts.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: February 17, 2015, 12:09:41 PM »
Tarozzi clip-ons without that really aggressive riding position...
http://www.fastfromthepast.com/clip-ons
Offline CG2000
« Reply #4 on: February 17, 2015, 03:04:58 PM »
Great, thanks for the advice. Flybox, those look like nice clipons, thanks for the link.
Scrambler, CBX1000 clamps idea sounds good. I'm trying to match the fork spacing to match the GL1000 wheel, axel etc, rather than the CB750's. Any idea if the GL1000 fork spacing is the same as the CB750's?
I like the idea of machining the mounts off drilling for new ones, but forks are also too long and will sit up in the way of the axis of the bars right? Anyone had a go at shortening the GL1000 forks? I guess that'll have a number of knock on effects to the springs / internal workings of the fork which might not be too much fun.
« Last Edit: February 17, 2015, 06:09:22 PM by CG2000 »
Online seanbarney41
« Reply #5 on: February 17, 2015, 05:00:08 PM »
GL forks are spaced wider than cb750...tubes are properly and easily lowered with shorter springs and pre-load spacers.
Offline Djfob
« Reply #6 on: February 17, 2015, 05:18:46 PM »
The high rise is just what I'm looking for
78 CB750k
« Reply #7 on: February 17, 2015, 05:57:06 PM »
Sean is correct................I used a spacer to compress the springs but also pushed the tubes up about 1.5-inches above the top tree.  A low-profile rear tire and a 1.5-inch longer swingarm brought the rake and trail back to stock for good handling. The 4-bolt axle-caps keep everything aligned without the need for a fork-brace if your running a custom fender.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline 6adan
« Reply #8 on: February 17, 2015, 07:34:19 PM »
I believe the CBX 1000 has 35 mm tubes.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline CG2000
« Reply #9 on: February 17, 2015, 08:17:13 PM »
You're right. It does.
Offline CG2000
« Reply #10 on: February 17, 2015, 08:19:23 PM »
Do you mean simply installing shorter springs and preload spacer without modifying the tubes?
Online seanbarney41
« Reply #11 on: February 17, 2015, 08:33:04 PM »
yep, allows the tubes to settle further down into the lower...also, according to my measurements, the gl fork is only about 1 inch longer than a 750k2-k6 frontend and there is room to slide the forks up in the stock trees that much using standard mounted handlebars...just to put that out there.  I don't necessarily think that is the best way to adjust the length.  Lots of guys will buy shorter, custom length fork tubes.
Also be aware that the GL triples have less offset, and that needs to be figured into the whole rake/trail picture, and also necessitates modifying the steering stops or the tubes will hit with a stock k0-k6 tank.
« Reply #12 on: February 17, 2015, 09:37:23 PM »
Check. These out..only set on the planet..built by Paul Brodie of Brodie bikes..
« Last Edit: February 17, 2015, 09:38:55 PM by 754 »
Offline Djfob
« Reply #13 on: February 18, 2015, 08:24:30 AM »
So same length as k7-k8 forks.
78 CB750k
Offline Djfob
« Reply #14 on: February 18, 2015, 08:25:16 AM »
Frank I'm assuming these would never be for sale then lol
78 CB750k
Offline CG2000
Offline Djfob
« Reply #16 on: February 18, 2015, 08:13:04 PM »
Finally pieced together a gl1000 front end myself. Milling would be the cheapest but that billet piece is slick.
To anyone that has the tarozzi high rise. How comfortable is it?
78 CB750k
Offline 6adan
« Reply #17 on: February 20, 2015, 10:34:47 AM »
Would lacing a 17'' wheel to the GL hub being it back close to stock rake & trail? I had planned on doing this and was wondering if anyone else had done it.
Online seanbarney41
« Reply #18 on: February 20, 2015, 12:55:40 PM »
don't forget, the stock gl1000 already has a 17" on the back...really probably need to run all the numbers and see how things come out, the main factor being the difference in triple tree offset
« Reply #19 on: February 20, 2015, 03:25:49 PM »
And the fact that a 17 inch wheel steers faster, so i gives the sense of reduced trail, and the smaller wheel will lower the front, effectively reducing rake, which reduces trail, not a good combination on a bike that already has a small trail number.... Don't guess when doing these swaps.... ;)
Offline Badluckhonda
« Reply #20 on: May 19, 2015, 11:59:20 AM »
The gl1000 has a 45mm offset which increases trail. Just in case you didn't know that already haha
« Reply #21 on: May 19, 2015, 12:24:52 PM »
There's also these for $129, if you like that sort of thing: http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-steering-parts-billet-aluminum-gl1000-top-triple-tree-12-2145.html
I used this top triple on my 750 with a 1976 GL front end.  I also used new Forking by Frank fork tubes and pre-load adjusters made by Voxonda.
I recommend against the Tarozzi high-rise clip ons.  I tried using them, but they do not hold their position well, no matter how much you torque them down.  You will get movement if you end up pushing all of the bike's weight on the bars, especially when loading or offloading the bike on a ramp.  I ended up using some Vortex clip ons.
JWExperience
« Reply #22 on: May 19, 2015, 02:41:43 PM »
I've got 1.5" rise tarozzi clip ons and like them a lot. Adjustable angle too.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #23 on: May 19, 2015, 08:46:01 PM »
Don,
This is a beauty. I love the front end.
I've always liked the look of bar end mirrors installed on the inside of the controls but they just don't work.  :)
« Reply #24 on: May 19, 2015, 09:30:05 PM »
Don,
Too true, Jim.  I reinstalled them on the bar ends.
