Author Topic: CB400F converted into a v8!  (Read 2545 times)
Offline chewbacca5000
  • I polish covers!
« on: June 17, 2015, 03:29:19 PM »
Check this out guy took 2 cb400f engines put them together and made his own v8!
Offline Davez134
Re: CB400F converted into a v8!
« Reply #1 on: June 17, 2015, 05:02:16 PM »
Builder is a member here, I remember seeing that in project shop section a month or do ago. Posted up some pics, a video and left us all hangin' wanting more info!
« Reply #2 on: June 17, 2015, 07:55:47 PM »
Runs pretty well with the kill switch turned on. Anyone know about the fuel delivery? If he could get rid of the primary chain slap it would REALLY be nice.
  • I polish covers!
« Reply #3 on: June 17, 2015, 08:04:12 PM »
Not sure it is chain slap.  Check out the write up.
http://classicmotorcycles.about.com/od/designersandentrepreneurs/fl/Honda-CB400F-to-CB800-V8.htm
Offline Doum
« Reply #4 on: June 17, 2015, 08:41:57 PM »
It's mine!
Someone saw the kill switch! wow :)
I will have to replace it,the reason is simple,since I removed the electric start I also changed the left control for a model without the start buttom.The buttom must be in OFF position to give positive to the coil,the control is from a small bike that didn't use a battery for the coil.I will have to replace only the contact Under the red buttom
It's a chain slap.It's the primary chain,reacting to the vibration of the ''V''.The 400f use only slider for the primary but for mine a tensionner would be better to remove play in the chain.If maybe a day I have to split the case I will work on it.  The good is the chain rattle stop with 100-200 rpm increace.
I have 2 carb mounted Under the tank.Ok I know I lost power.....but that's the last of my problem,it's a show bike,it run and it's perfect.And they fit Under the tank,so I keep a stock look.
  • I'm back
« Reply #5 on: June 17, 2015, 11:59:25 PM »
« Reply #6 on: June 18, 2015, 03:45:54 AM »
Why not go bigger, like V12 Diesel  ;D
Wobbly
« Reply #7 on: June 18, 2015, 05:14:24 AM »
@Doum
Aside from its awesome engine, this is also a really nice looking bike. I am amazed.
Wobbly
« Reply #8 on: June 18, 2015, 05:19:46 AM »
Because you need a garage to go with it. Amazing.
Offline Doum
« Reply #9 on: June 18, 2015, 09:30:16 AM »
Offline SKTP
« Reply #10 on: June 18, 2015, 09:49:56 AM »
Amazing.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #11 on: June 20, 2015, 07:03:50 AM »
Hey Doum; Wife wants to know where she can buy one, says that Looks AWESOME !! My own comment other than the wrapped pipes (Not a complaint), it looks totally OEM Excellent work !!   ...cougar... & dragonet
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
