Author Topic: Frame-up cb350f restoration, hunk o' junk transformation  (Read 60286 times)
Re: Frame-up cb350f restoration, hunk o' junk transformation
« Reply #175 on: May 05, 2016, 09:40:37 PM »
Clutch is fixed!!
It was the cable. I used a genuine Honda cable in the stock routing position and the clutch is smooth and light. It's perfect. This is a dramatic improvement to the ride quality.
I had a stainless brake line but didn't install it tonight as I misplaced the hydraulic bank bolt switch. Hmm... Sure it's around here somewhere.
I also had the gas cap gasket start leaking, pouring fuel al over the front of the bike after a hard stop. That's a first. I rotated the seal a few times, closed the cap and the problem stopped. Odd...
So next up is the brakes and more riding lessons for Cindy this weekend. She can shift now!
That must have been a Huge relief for you when you installed that oem clutch cable ! I would even run a known good used oem cable rather than a china-cable.
Offline markreimer
« Reply #176 on: May 06, 2016, 08:37:43 AM »
It was! Such a night and day difference. My wife has a bruised hand from squeezing that lever while learning, hah! This should be better.
Say, to the other 350 owners out there, what kind of mileage do you get in the city? I'm getting mid 30's in town, which isn't so great. That's flogging it hard. My r80 gets about 28-30 in the city and just shy of 40 on the highway. So with that comparison I'd guess I would get close to 50 on the highway but need to test. Any numbers out there to compare to? I'm using stock jetting, stock air filter, and the 400 headers. Would the exhaust side of the equation affect fuel economy much?
Second question. My cam chain is very noisy. At a low idle around 1k it's totally silent. By 1,200 it's a kitchen drawer dumping on the ground. I know the adjustment should be automatic. How loud do these chains get normally? My 750 is similar but not as loud
Online carnivorous chicken
« Reply #177 on: May 06, 2016, 11:06:39 AM »
I usually get around 120 miles on a nearly full tank -- averages to about 40mpg. Stock airbox and jetting, 400F exhaust.
Cam chain noise usually decreases as  you increase rpm. The adjustment isn't automatic -- look up cam chain adjustment for these bikes. It can be tricky and you need to be careful -- the adjusting bolt can snap, for example.
Offline markreimer
« Reply #178 on: May 06, 2016, 12:30:22 PM »
Is that 120 miles to reserve, or to empty? I hit reserve right around 100 miles in the city I think.
Cam chain does quiet down when I'm riding. Certainly not unusually loud anyway. It's just when my idle is set a touch too high that the cacophony of noise happens. I found a Honda service bulletin with cam chain adjustment detailed in it for the 350F. I'll give that a try next shop night.
« Reply #179 on: May 06, 2016, 01:33:22 PM »
I was consistently 38mpg. Stock airbox/plenum.  Jardine 4:2's and #78mains.
« Reply #180 on: May 07, 2016, 02:51:04 PM »
120 total including reserve -- so about 40mpg.
Offline markreimer
« Reply #181 on: May 07, 2016, 08:23:24 PM »
Another afternoon of practice for Cindy. The new clutch made it much easier. She's making it through the gear box easily now. By Sunday next week she should have her license. Exciting!
I also took the bike out for a proper highway run. I learned a few things:
- the top speed this bike can hit is about 91mph. Well, at least into the wind. I really had to lay down on the tank and work to get there. It'll power up to 75 or 80, but after that it was slow going.
- I can't wheelie this bike
- the wind really blows you around on these little bikes. I missed my 750 out there!
« Reply #182 on: May 08, 2016, 04:30:59 AM »
A 16t. countershaft sprocket will allow the engine to reach the good part of the powerband a lot better, imo.
Offline markreimer
« Reply #183 on: May 08, 2016, 08:34:19 AM »
Yeah I could see that for sure. When this one wears I'll be dropping down a tooth for sure.
« Reply #184 on: May 09, 2016, 07:08:37 AM »
well that could take a while..  ::)
Offline markreimer
« Reply #185 on: May 09, 2016, 07:59:48 AM »
Haha yeah, I guess so. I think I'm still on the same sprocket on my 750 after about 30,000km. Maybe I won't wait so long..  Really it's just that the budget is running out on this project and I'd like to devote some money and time to a couple cosmetic items soon. The seat comes to mind, given the giant tear in the vinyl.
Also, I'm not sure if I had mentioned this or not, but Cindy and I have planning a 2-up tour from Winnipeg to Jasper, AB in mid August. It'll be about 4,500km round trip, a mix of blustery prairie crossings and winding mountain roads. So I've got three months to find and fix any remaining kinks in the bike, and she's got three months to get her riding skills up to snuff. I'm confident we'll both succeed in our tasks.
For the bike, the remaining items I've got listed are:
- Replaced that damn brake line! I lost my hydraulic banjo bolt switch, so ordered a new one this morning. Hopefully I can have it all replaced by the weekend. I'll also rebuild the caliper with some Dow Corning High Vacuum grease around the back and sides of the pad, which successfully eliminated the brake squeal on my 750 a few years back. Hoping for a repeat on the 350.
- I still haven't balanced the carbs, checked timing/points, adjusted cam chain. All small but meaningful things. I'll get to that on the weekend likely as well.
- Take the seat in for reupholstery. I'm not good with that, and 'I know a guy' who does it well and affordably.
- The front tire is a touch out of balance I think, but only between 60-80km/h. Once up to 100kmh it's smooth and easy. Those tires will not be on the bike for the tour anyway though, so I'll replace them with fresh rubber and balance at the time.
- The headlight is brutal. Basically a tea light. However Cindy isn't allowed to drive at night for the first year of her license, but I'd still like to improve it.
- Find a cb550F kick start!!!!!
« Reply #186 on: May 09, 2016, 08:18:16 AM »
You've got a lot of 'prep' to do for your two-up trip;if you're going to do that trip Please install the 16tooth CS sprocket on your bike beforehand otherwise it'll feel like you have to ride your mountain bike w/ panniers w/ only a 50 tooth chainring.. remember cadence & 'spin' w/ 170 cranks which is similar to your short stroke CB350F engine.  :D
« Last Edit: May 09, 2016, 08:19:56 AM by grcamna2 »
Offline markreimer
« Reply #187 on: May 09, 2016, 08:21:37 AM »
You've got a lot of 'prep' to do for your two-up trip;if you're going to do that trip Please install the 16tooth CS sprocket on your bike beforehand otherwise it'll feel like you have to ride your mountain bike w/ panniers w/ only a 50 tooth chainring.. remember cadence & 'spin',at least w/ 172.5 cranks  :D
Oh god this is NOT a 2-up trip haha! I can't even imagine attempting this 2-up on the 350. That would suck, hard. I'm taking my R80 and will be the trip sherpa, so to speak. I've got two huge aluminum panniers, 37L each I think. Cindy will be on the 350F with a tank bag and small dry bag behind her, at most. But yeah, the more I think about how hard the bike worked to hold 100km/h into the headwind, the more I realize the 16T will be a necessity.
« Reply #188 on: May 09, 2016, 08:28:41 AM »
I understand that two-up w/ heavy luggage on your CB350F would be maxed-out
« Last Edit: May 09, 2016, 08:31:35 AM by grcamna2 »
Offline markreimer
« Reply #189 on: May 09, 2016, 10:33:08 AM »
Ok, I ordered a 16t sprocket and a new hydraulic brake switch so I can install the braided line on Thursday.
Question - how much soot is common in your exhaust? Since the emgo cocktail shaker is pretty wide open, I can get a real clear look down the throat, so to speak. I was a little surprised how sooty everything looked in there. Given that the carbs/air filter are all 100% stock, I don't think I'm running terribly rich. In fact I thought I was running lean given the header discolouration I experienced on the first run. If it is rich/lean, it couldn't be by much, and I wouldn't expect it to cause this much soot. Am I just out to lunch?
One thought could be that it's burning a bit of oil. That seems odd to me given that it has under 2,000 miles on it, but maybe the rings are a bit stuck after sitting for almost 40 years. Based on the photo here, what would you suspect? You can see where I wiped it with a cloth to see how oily it was.
I checked the oil for the first time since filling it and it was down a fair amount. Maybe 0.5L or a bit more. However, I had removed the clutch twice, which attributes for some of the oil loss. After filling it again, I rode for about 100km, with lots of wide open throttle, experienced zero oil loss. Thoughts?
« Reply #190 on: May 09, 2016, 11:54:17 AM »
Mark,
You may be running a bit of oil past the rings/guides;why not warm up the engine and then while it's hot remove all the plugs and pour in about a half oz. of Seafoam or Marvel Mystery oil into each cylinder and then let that sit over-night and fire it up mid-day tomorrow.That will give it a change to loosen up the rings a bit,they might have a bit of carbon around them which needs to be removed for the rings to 'spring back' w/ the proper tension to seat them.
Offline markreimer
« Reply #191 on: May 12, 2016, 10:22:40 PM »
Ok more proper work done tonight. First on deck was replacing the crappy brake line. I ordered a single braided steel line straight from the caliper to master cylinder. I also rebuilt the whole caliper again, and discovered my pivot bolt was doing anything but pivoting. It was seized solid, glazing my pads as a result. So THAT is why the front brake squeals so hard and sucks!
I cleaned and lubed the bolt, coated the backside of the pads with Dow Corning high vacuum grease and reassembled. WOW I have a actual brake now!! I had a very slight squeal once after about 25 hard brakes, we'll see if it stays quiet. But it definitely works waaaaayyyyyyy better.
Next was fabbing a temporary exhaust hanger. I'm embarrassed to even show it. It's so ugly. But it works and will be replaced in time. Just some metal strapping to do the trick.
Then I attempted to pack some glass pack into the muffler. The shape of the pipe makes this next to impossible, but I did manage to cram a bit in from the other end and it's taken the harsh overtone off the overall sound. Still loud, but more pleasing.
Last was a first attempt at restoring the tank finish.  a buffing wheel and some abrasive paint restoration compound did a shockingly nice job at polishing out the stains. Next week I'll tackle this in earnest, now that I know there is something worth saving.
Cindy goes for her moto driving course tomorrow. By Sunday she'll be legal and I'll have to give this bike over!
After all that we replaced the wheel bearings in a cx650 and called it a night. I rode home and boy oh boy is it feeling FINE with the new clutch cable, good brakes, smooth squeak-free swing arm and front brake.
Offline markreimer
« Reply #192 on: May 13, 2016, 07:20:06 AM »
I should clarify - I didn't leave the glass pack just stuffed in the end like that haha. I forced it between the baffle and the pipe, packing it in tightly.
I also lightly sanded the brake pads to remove the glaze.
Also packed more grease into the swingarm pivot bolt after a slight squeak reappeared. I was able to pump a lot more in since last week actually, and continued till it oozed a lot out of both ends.
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #193 on: May 13, 2016, 09:44:24 AM »
I was a little confused for that muffler haha  ;D
Offline markreimer
« Reply #194 on: May 13, 2016, 01:40:24 PM »
Haha yeah. That looked....wrong. The baffle fits snug where the cocktail tapers down near the exit of the pipe, so you can't wrap the baffle in glass and strap it down. If you do, it won't fit back inside the pipe!
So instead I pulled the baffle 3/4 out, and then pushed glass in from the 'intake' side of the muffler. As it filled the space between the baffled and pipe, I pushed it in further and continued packing till all the space was crammed tight. We'll see how long it lasts.
Offline markreimer
« Reply #195 on: May 16, 2016, 09:00:42 AM »
Small but important update today:
Cindy passed her licensing exam and has her motorcycle license! She was the only woman in her class to pass, interestingly enough. We're going on our first ride together tonight!
Other than that, the front brake squeal has returned. I'm wondering if my seized brake pivot bolt cause the pads to glaze up pretty bad. I sanded the pads, but it only took 50 or so brake applications to bring it back. I'm using EBC pads. I'm going to hunt for a pair of OEM pads instead, which I've read are less prone to squealing.
« Reply #196 on: May 16, 2016, 04:53:00 PM »
Mark, You're right getting the OEM stock pads.
Offline markreimer
« Reply #197 on: May 17, 2016, 01:24:29 PM »
Failed finding OEM pads. So I'm trying some semi-sintered ones instead. Turns out I didn't have EBC pads before. I had some super cheap crap BikeMaster pads. I'll scrub the rotor with scotchbrite and cleaner, replace the pads and try again.
Offline markreimer
« Reply #198 on: May 19, 2016, 01:02:40 PM »
We went on our first ride together, and her first time riding in traffic. Success!!
Riding behind her I noticed the rear wheel has a bit of a wobble. Perhaps the spokes have loosened up or something. I'll be checking that before the bike moves again. Brake squeal was gone too. Maybe it's only when the force of two-up braking is needed that it squeaks? Strange.
« Reply #199 on: May 19, 2016, 01:38:11 PM »
I assume you changed the swingarm bushings, wheel bearings and steering head bearings.  If not, those can contribute to a wobble.  Also, some tire patterns can catch grooved pavement on freeways and give you a wobble.
