Author Topic: 1977 CB550K Cafe Racer project "Shinobi"  (Read 14679 times)
Offline jdizon
    • Project Shinobi 77 cb550
« on: September 01, 2015, 04:06:36 PM »
Hi, My name is Johann and I've been lurking around this forum for quite some time and actually had a project posted but took it down mainly to losing interest. The project was put on the backburner for some time but I've got the itch again and I think it needs some scratching. Time to finish this project that I dub the "Shinobi". Here is rendering of what I have in mind for this bike.
Some History:
 The donor bike started off as a 1977 cb550k model. The only thing I'm going to use of the bike is the motor/title & registration.  In terms of background, I've got some experiencing rebuilding xs650's and Triumph unit motors from the ground up but I'm a newbie on hondas. So bare with me on the newbie questions.
Some details on the build specs.
Frame:
I've always been a fan of triton's and opted for a custom featherbed style frame coupled with a floating monoshock swingarm.
The frame and swingarm was built by Jamie of ElsewickCycles in CA.
Front end: Ceriani Triple and trying to score a set of 35mm forks.
Exhaust: 4 into 1 with a yoshi style muffler out back.
Electronics: Going crazy with Motogadget ( M-UNIT, Button, buttons, etc..)
Other mods: Dyna 5ohm coils, Ricks Reg/Rec, Shorai battery
Tank: Benelli Mojave and cowl.
Wheels: Kimtab 18/19 or Lester Mages 18/19 not sure yet.
I'm really looking forward to getting my hands dirty rebuilding this motor and learning everything I can to making my vision become a reality.
Offline Restoration Fan
  • My wife will never call me
Re: 1977 CB550K Cafe Racer project "Shinobi"
« Reply #1 on: September 01, 2015, 04:09:42 PM »
First of all, welcome to the forum.
Second, if you did that drawing, you have some drawing skills!
Finally, I'm in.  Looking forward to seeing what happens on this one.  Should be a fun thread to watch.
Offline jdizon
« Reply #2 on: September 01, 2015, 04:14:59 PM »
 Nice to meet you and Thanks! I used SketchBook on my Iphone to make the rendering.
« Reply #3 on: September 01, 2015, 04:27:18 PM »
I cannot remember if this is the same Shinobi project that was up on the builds board a WHILE back.
Very nice rendering.
To avoid title for a custom bike, I assume you are incorporating at least the headstock into the Elsewick frame.  Is the frame completed or being fabricated?  Is it a one-off or a production frame they make?
What type of swingarm are you going to use? The rending shows a braced double sided model of one kind or another with monoshock dampening.
Offline jdizon
« Reply #4 on: September 01, 2015, 04:36:00 PM »
Same one posted but took it off as I wasn't planning to update it anytime soon. Frame  is completed and is a one-off custom. Swing arm is double braced and the monoshock is sourced from a CBR1000.
In terms of the title, I've already got the donor bike Titled/Registered and I have the headstock with the original frame. If I get pulled over, worse case I'll get a custom title if I have to.
Offline jdizon
« Reply #5 on: September 01, 2015, 04:51:40 PM »
Some pics of the frame and Rearsets built by Jamie of ElswickCycles.
« Last Edit: September 01, 2015, 04:53:46 PM by jdizon »
Offline jdizon
« Reply #6 on: September 01, 2015, 05:08:09 PM »
I've always liked the racy cafe look of the Benelli Mojave tank. Took a while but found a NOS Benelli tank on eBAY but unfortunately it sat to high on my frame and would need to be chopped quite a bit to look right. Instead of chopping the NOS I decided to pickup an Indian re-poop! The quality on the repop was terrible so I knew I wouldn't feel bad cutting it up. I'm also pondering the idea of cutting out the whole tunnel and creating a flat bottom since there's no backbone anyways and could use the extra fuel capacity. Here's a pick of the chopped tank. Took about 3" from the tank
« Last Edit: September 01, 2015, 05:10:05 PM by jdizon »
« Reply #7 on: September 01, 2015, 05:10:53 PM »
I think a new tank bottom will help with fuel capacity but you should weld in some sort of baffle on the bottom piece to prevent your fuel from completely sloshing from side to side.
Offline jdizon
« Reply #8 on: September 01, 2015, 05:13:17 PM »
Great Idea, I was thinking of putting a small tunnel to hide the coils in that should help.
Offline jdizon
« Reply #9 on: September 01, 2015, 05:19:57 PM »
Got the headlight installed with the ceriani short fork ear mounts. Also a pic of the ceriani triple I plan to use.
Offline jdizon
« Reply #10 on: September 01, 2015, 05:27:25 PM »
What's a ninja without his ninja stars ;)
Process of rebuilding this set of Lester mags with the ever elusive 18" rear drum.
The past owner had the lips on the retainer bearing on the front rim all gone so it took some persuasion to remove. Got it out in the end with the threads in the hub undamaged. Look at the aftermath on that front retainer tho!
Offline jdizon
« Reply #11 on: September 01, 2015, 05:35:08 PM »
Some cardboard mockup of a rear cowl.
Offline slikwilli420
  • Master of Disaster
« Reply #12 on: September 01, 2015, 05:37:01 PM »
Lots of awesome stuff on this one. I dream of a custom frame so good on you for making it happen for your build. I will keep watching with interest.
Offline jdizon
« Reply #13 on: September 01, 2015, 05:40:41 PM »
Thank you I appreciate it! Unfortunately the stock frame didn't fit the vision I had in mind. Got big plans for this one so stay tuned :)
Offline jdizon
« Reply #14 on: September 01, 2015, 06:45:47 PM »
The cowl should have a similar radius as the tank. It'll look good when done. My buddy Adam with Speed Devices will form the actual metal (cowl) when look is finalized.
Offline jdizon
« Reply #15 on: September 01, 2015, 06:51:26 PM »
Yeah, theses pictures show it clearly. Looks really good!
Thanks btw been going through all your build Threads for ideas. Thanks again for answering a lot of my questions as well.
« Last Edit: September 01, 2015, 06:53:38 PM by jdizon »
« Reply #16 on: September 01, 2015, 07:22:20 PM »
Johann,
Make sure to leave enough space for you to move around the seat.  That space is a little tight on the privates in the mock-up photos.
Offline jdizon
« Reply #17 on: September 01, 2015, 09:27:48 PM »
Johann,
Yup for sure!
Offline MessnerMoto
« Reply #18 on: September 02, 2015, 02:27:28 AM »
This is impressive! I am really amazed. Please continue
« Reply #19 on: September 02, 2015, 06:23:57 AM »
Is your build thread current to where you are now?
« Reply #20 on: September 02, 2015, 01:04:35 PM »
Johann,
I was able to reach James Elswick.  He provided the following details on your frame:
"The frame is 28 degrees which would put the trail around 4" with a 19" wheel. All of the crucial dimensions were held in the factory locations...neck (other than being raked 2 degrees), swingarm pivot, all motor mounts except the rear upper mounts which I built custom plates for. The frame is 1018 1"x.120" wall mild steel. The seat area is shorter than stock, I just did what looked right to me. The swingarm is 2" longer than stock also and I set it up with a '05 cbr1000rr monoshock and linkage."
It's a very interesting package.
Offline jdizon
« Reply #21 on: September 02, 2015, 01:25:35 PM »
Already had this info but thanks!
Johann,
« Reply #22 on: September 02, 2015, 02:07:42 PM »
I wasn't sure if you did, but I figured there might be some others (like me) interested in the frame geometry and construction.
Offline jdizon
« Reply #23 on: September 02, 2015, 02:10:01 PM »
I thought I answered what you asked in your private email?  Well anyways I gave you his contact info as I thought you were interested in getting work done from him.
« Reply #24 on: September 02, 2015, 03:23:07 PM »
Johann,
Thanks for giving me Jamie's email.  I think his price is very fair for a custom frame, but not in my present budget (at least until after next tax season) with the projects I already have going.  Plus I'd prefer to see how yours performs.  I hope I didn't rub you the wrong way by sharing the geometry info.
I was just sharing the specs because I figured there are others that were curious as well.  This is a great looking project!
Don
