Author Topic: Fox Podium RC1 Shock - Impressions  (Read 27680 times)
Offline tweakin
  • tear down
Re: Fox Podium RC1 Shock - Impressions
« Reply #25 on: April 19, 2016, 09:17:05 AM »
Jim-  Renton Coil Spring could be an option if you want to keep the shocks.  http://www.rentoncoilspring.com/motorcycle.html
When I raced Downhill I always upgraded my shock springs, including FOX, to their sweet Ti springs...  And they are local in Renton, WA.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #26 on: April 19, 2016, 09:31:45 AM »
Thanks Tige. I had an RCS titanium spring on my Fox Vanilla RC shock back in the day.
Would love to have them provide springs for these Podium shocks but I don't know what spring rate I need yet.
That's the help I'm seeking.
BTW, I emailed RCS technical dept.
Will let you know what they say.
« Last Edit: April 19, 2016, 09:46:11 AM by FunJimmy »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #27 on: April 19, 2016, 10:18:21 AM »
Wasn't like that when I was sponsored by Progressive.  One call was all it took,  c'mon Fox, you need these? Lol.G'luck.
BentON Racing Website
BentON Racing Facebook
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #28 on: April 19, 2016, 10:44:36 AM »
Heard back from the tech Dept at RCS and this is what they said.
Jim-
Sorry, I have no idea what spring rate would be necessary.
Usually the only motorcycle applications we supply are motocross/supercross.
If you figure out the rate, feel free to get back to me and I can check to see if we have a titanium spring to fit.
Best regards-
Kyle
Nice but not nearly helpful enough.
I shouldn't have to do the R&D work for FOX!
« Last Edit: April 19, 2016, 10:46:46 AM by FunJimmy »
Offline simon#42
  • liverpool
« Reply #29 on: April 19, 2016, 11:26:15 AM »
not sure why you picked these shocks in the first place , unless you want to do the development for them pick a company that has already done it .
the reason people pay top money for ohlins and wp is that they have been developing their products on race tracks all over the world for decades and know exactly what works.
if you wish to persevere with them you need to find a decent suspension specialist that can lend you a few springs on the understanding that you buy the one that works , that is quite a common practice over here . if you were closer i would send you a box full !
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #30 on: April 19, 2016, 12:10:40 PM »
You're absolutely right Simon. I chose the Fox Podium RC1 shocks because I've had nothing but great results with their mountain bike stuff and these shocks look to have a good range of tuning options. That said, Fox doesn't have a lot of experience in the street bike market and it shows. Do you have any Ohlins model numbers I should be looking at?
Thanks for setting me straight.
« Reply #31 on: April 19, 2016, 12:56:58 PM »
Fox made twin and single shocks for street bikes for years. My understanding is they got out of it to focus on snowmobiles and bicycles. You have the free length and ID/OD dimensions...maybe something from YSS, Hyperpro, Eibach etc. Maybe these guys http://www.asbg.com/products/springs-overview/compression-springs.aspx?gclid=CK258NS9m8wCFVhbhgodTbcE4A
Offline simon#42
  • liverpool
« Reply #32 on: April 19, 2016, 01:01:02 PM »
this is the type of thing i had in mind
https://www.ohlins.eu/en/products/motorcycle/shock-absorber/?Brand=Honda&p=2
i know these are not exactly what you want but it should give you an idea
these are there budget model but are still very good quality shocks , when i say budget i actually mean quite expensive !
if you email them with the weight of the bike , the distance between the swing arm pivot and rear axel , the distance between the bottom shock mount and swing arm pivot and
the distance from the top shock mount and swing arm pivot they will be able to supply a spring that will work . normally they don't charge extra for this sort of thing .
wp will do the same . if you fancy something handmade for your bike have a look at maxton shocks
http://www.maxtonsuspension.co.uk/files/wr26.htm
if you do like these i am only 20 miles away and they have known me for 40 years so i could possibly help out
sorry if it sounded like i was trying to put you straight !
« Reply #33 on: April 19, 2016, 02:36:37 PM »
I can't offer the correct spring rate, because I use dual springs, the short @ 80 & longer @ 120lbs. This for a 185lb rider with leathers, etc. and these are ideal for my situation.
Offline turboguzzi
« Reply #34 on: April 19, 2016, 03:00:07 PM »
See FJ? assuming a ballpark average of 80-120=100 lbs/inch, that's about 1.7 kg/mm, so your 1,5 kg/mm is not that way off, roughly speaking...
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #35 on: April 19, 2016, 03:56:12 PM »
Except I only get 7mm of sag.
Offline turboguzzi
« Reply #36 on: April 19, 2016, 04:10:38 PM »
so that's a spring length issue, if at minimum preload it's still too compressed, needs to be some 10-15mm shorter or maybe some extra room can be gained in the adjusters, agree that it shouldnt be like that....
« Reply #37 on: April 19, 2016, 04:48:56 PM »
 Let me sit on it...easiest way to get more sag.....
« Last Edit: April 19, 2016, 05:33:22 PM by 754 »
Online Stev-o
« Reply #38 on: April 19, 2016, 05:16:16 PM »
I'd already have those shocks in the return mail after that last email!
Offline Camrector
« Reply #39 on: April 20, 2016, 10:27:01 AM »
Jimmy, sorry to hear about this. My experience with the podiumR shock is quite different so far.
Mine are the podium Rs at 363mm. This is a different shock but in the same "series line". Also my 550 isn't using the stock mounts.
Sag was measured at 25mm right out of the box, and from the pictures you can see a lot of adjustment to be had.
I understand our applications are different but i just wanted to show a comparison.
You'll get it sorted!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #40 on: April 20, 2016, 05:06:40 PM »
This is great Cam. You may have uncovered the problem.
Can you post a pic of the spring code for comparisons?
Fox offers these shocks in 325mm, 350mm and 363mm lengths.
Did they in their infamous wisdom use the same 9" spring in all three lengths?
Looking at your pics, there's ample adjustment to fully unload the spring on the long body shock but clearly not on the short body units.
Offline Camrector
« Reply #41 on: April 20, 2016, 05:43:11 PM »
that's what I'm thinking they used the same 9" spring
« Last Edit: April 20, 2016, 06:08:09 PM by Camrector »
Offline Camrector
« Reply #42 on: April 21, 2016, 08:13:14 AM »
Jimmy my springs read, Fox 900-1880-0100 (1.8kg)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #43 on: April 21, 2016, 09:51:54 AM »
Thanks Cam
I find it odd that a suspension company like FOX would spec and try to squeeze a 9" spring into a short body shock and think it's OK!
It takes nothing for them to wind up an 8" spring for short shocks and a 9" for the longer versions. Corporate greed, I guess.
Online dragracer
  • CB750F Dragbike
« Reply #44 on: April 21, 2016, 10:51:51 AM »
Wow, I'm glad this thread cane up. I was contemplating a set of Fox adjustable shock for my F model dragbike to get better control of rebound and dampening for my launches. The stock shocks work okay but i know it would lower my 60' times if I could tweak the shock. You just saved me a bunch of $$$.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #45 on: April 21, 2016, 11:23:18 AM »
That's a pretty naive and obnoxious attitude Jimmy. Perhaps it's an oversight. Perhaps the short body shocks haven't been ordered for a configuration like yours. You often seem ready to label "corporate greed" every time what you want isn't readily available or cheap.
Did you contact Fox and provide the insight, or did you just send them a sniping email like a spoiled customer and whine and accuse them of mistreating you? You posted their replies to you, but you never posted your side of the emails. I smell a rat...
If you want semi custom shocks you need to work with vendors to get the best treatment and results. I'd bet with a polite attitude and some open dialogue, they would love to satisfy you. They sell heaps if these shocks and we have yet to see reports of dissatisfaction from buyers. So perhaps your situation is unique?
As for "winding up a spring" being trivial, that's the most obnoxious thing you've ever said. A company in production can't stop and do one-off springs simply to address a single buyer. But I'd bet they have a spring in their catalog that might work. Try that approach if you truly want a satisfactory resolution.
Listen up before you start one of your rants, Cal! Where the fcuk did you get the idea I was complaining about price. These shocks cost over a grand and that's not chump change. For that I expect a quality part. Have you EVER seen me complain about costs or scrimp on my build. How dare you! I don't think there's anything short sighted when a suspension company with the expertise and knowledge like Fox chooses to use a spring across a range of shock bodies like this. It's also unacceptable for a reputable company to tell a custome that they do not offer anything softer to address the issues. You would NEVER get that from Ohlins or Works. And, YES. Corporate greed does play into desisions like this.
Oh FYI, I did not email Fox. The email response (posted one first page) from Stacey came unsolicited. Stacey was talking to Devin and sent that reply to confirm what was already discussed between Devin and myself.
« Last Edit: April 21, 2016, 11:57:54 AM by FunJimmy »
« Reply #46 on: April 21, 2016, 12:17:50 PM »
Why don't you look at some YSS shocks Frank
Online dragracer
  • CB750F Dragbike
« Reply #47 on: April 21, 2016, 12:41:07 PM »
Thanks Mike.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #48 on: April 21, 2016, 12:52:51 PM »
As I said, and perhaps they too but you didn't hear, they might have a spring in their catalog that could work but it's not part of this product line. This is where dialog to solve the problem would be productive, instead of vendor bashing.
Nope! No such item currently available from FOX!
That said, Stacey is indeed consulting with his engineers and spring supplier to see if they can provide a solution.
That as you may have concluded (but chose to ignore) was an inquiry with Renton Coil Spring as recommended by Tige. Not FOX.
I have also contacted a couple of other spring vendors in an attempt to solve this dilemma.
Just curious, is the shock length of the Fox the same as the Works unit you removed? I remember you had a For Sale thread where you were offering those, but don't recall the specs on them.
The shock length is exactly the same between the Fox and Works shocks. The Works shocks have 8" springs and the Fox units have 9" springs. I pulled the classified listing until I get this resolved. Would hate to sell the Works units only to find that the Fox shocks are unable to work.
« Last Edit: April 21, 2016, 12:54:38 PM by FunJimmy »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #49 on: April 21, 2016, 07:32:21 PM »
Here's a spring comparison between the Works and the Fox.
The Works spring is to soft at 70lbs/in but would be a better overall length.
Unfortunately the ID is to small to slip on the Fox shock.
Would have been interesting so see how much of an effect the gas charge and compression circuit has.
