Author Topic: K8 Highway Racer - Finished  (Read 32331 times)
Offline JoeCooley
  • Long time lurker, but now I'm a
Re: 78K Cafe - The 836 Runs!!!
« Reply #50 on: February 18, 2017, 02:16:22 PM »
Ok so the engine is out. The camshaft is broken. Definitely oil starvation on 3&4. Not sure what caused it but I will clean everything and make sure the oil holes aren't blocked.
« Last Edit: April 16, 2018, 01:21:45 PM by Glenn Stauffer »
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Restoration Fan
  • My wife will never call me
Re: 78K Cafe - Broken camshaft 😠
« Reply #51 on: February 18, 2017, 02:32:55 PM »
Contact Bill Benton.  He has another 78 camshaft and more valves to replace them.  Great guy who will give you a fair price as well.  He's a member on this forum.
Offline JoeCooley
« Reply #52 on: February 18, 2017, 02:46:41 PM »
Thanks first the tip. I already have another head that's been rebuilt and a 72K camshaft. I plan to get all back together this weekend.
« Last Edit: April 16, 2018, 01:23:38 PM by Glenn Stauffer »
Offline JoeCooley
« Reply #53 on: February 18, 2017, 02:47:55 PM »
Ok last one before its back to work.
Offline Desert-SOHC
  • It's old
« Reply #54 on: February 18, 2017, 02:52:06 PM »
I had one break too, rebuilt it on the kitchen table.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline JoeCooley
« Reply #55 on: February 18, 2017, 05:25:51 PM »
I'm doing all this at the hobby shop on base. It sucks not having a garage. I'm restricted to thier hours. If I had a garage I'd get things done much quicker. Hell, I'd be working till like 2am...
Offline JoeCooley
« Reply #56 on: February 19, 2017, 05:01:08 PM »
Update: The engine is back together and in the bike. I ground down the bottom front mount flange before fitting the engine. OMG it made it soooo much easier to install. I'm glad I didn't bother with the frame kit this time. I still may do it in the future, but I don't feel right about cutting a good frame and sacrificing frame rigidity. I ride pretty hard into turns when I'm in the mountains.
Ok so just a few more bits to attach and I should hear it fire tonight.
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #57 on: February 19, 2017, 06:29:21 PM »
Glad it's almost back together! IMO the frame kit is clutch and would make a job like this a breeze, I installed one to tackle a small oil leak the developed on my top end 7 years after my re-build and the frame is no worse for wear with a kit installed. I used Franks (754) no weld kit and it's done quite well on all my rides, I don't notice a difference in a similar bike with or without a frame kit that's fitted properly. The suspensions, now that's another story.  :)
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline JoeCooley
« Reply #58 on: February 19, 2017, 07:36:31 PM »
I will probably end up getting the frame kit. Frank was sold out when all this happened so I just went ahead without it. It was a pita cleaning the cyl/head surface with the engine out. The grafite & copper coat was stuck pretty good. I can only imagine how long I would've spent on it inside the frame.
Offline JoeCooley
« Reply #59 on: February 19, 2017, 07:40:52 PM »
Update: It runs again!!!! 😲
So it's all back together. Rebuilt F1 head with Kimble White springs, K2 cam, and MLS head gasket.... My 836cc 78K lives to fight another day.
Offline Desert-SOHC
  • It's old
Re: 78K Cafe - The 836 Runs Again!
« Reply #60 on: February 19, 2017, 09:34:33 PM »
Thats great
11 Ranger S/C 2wd
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #61 on: February 20, 2017, 08:14:43 AM »
...but I don't feel right about cutting a good frame and sacrificing frame rigidity. I ride pretty hard into turns when I'm in the mountains.
I see this sentiment posted often. As for the rigidity lost with a frame kit; poppycock! A mechanical joint (like Franks) can be just as strong as the continuous tube (stock). Plenty of modern bikes use 2 piece frames, bolted together with no loss of rigidity. Even modern bikes use bolted on subframes connecting the suspension to the main frame and engine mount with zero ill effect.
If you don't want to cut it because of stock, unaltered condition, so be it. But to believe you will be suffering stability or rigidity as a result, you are mistaken. Feel free to saw and install a welded or weedless kit at your convenience.
+1 on that.
1995 EG6
« Reply #62 on: February 20, 2017, 08:21:43 AM »
+1 on that.
Yep!
Offline JoeCooley
« Reply #63 on: February 20, 2017, 09:32:07 AM »
Thanks for the advice guys. 👍
Offline JoeCooley
« Reply #64 on: February 20, 2017, 12:08:33 PM »
A couple pics I forgot to add. I dropped the pan and cleaned out the pump screen and pan. Mostly just fine metal from the cam and some bits of black stuff from chain adjusters. The wheel on the primary adjuster was a little worn but didn't look terrible. There was a little thin piece of steel in the pan. Looked to be the end of a feeler gauge. You can see it laying on the drain plug. Kinda odd.
« Last Edit: April 16, 2018, 01:26:03 PM by Glenn Stauffer »
Offline JoeCooley
« Reply #65 on: February 20, 2017, 12:22:23 PM »
The pump screenhad clumps of hair and fibers. I'm guessing from Blue shop towels. I guess I won't be using those again to wipe off parts... 🤔
« Last Edit: April 16, 2018, 01:27:03 PM by Glenn Stauffer »
« Reply #66 on: February 20, 2017, 02:03:15 PM »
 Yes! Years ago there was an article in Road Racing World about a guy that was meticulous about his maintenance but always covered the opened up engine with red shop rags. Also cleaned parts with them. The end result after years was the oil pump screen became clogged and that was it. The fibers in those red/blue shop rags do not break down and are the perfect size to collect and pack up.
 I stopped using them for engine stuff and use the Scott's heavy duty paper towels the pull out of the box, Also blue shop paper towels. Blow off the parts with air too before assembly.
Offline JoeCooley
« Reply #67 on: February 25, 2017, 06:54:52 PM »
Update: I finally got a chance to install a better exhaust on my bike. Me and Ted (ricky_racer) did a little trade for a slightly used Kerker header. I picked up an 18" cone engineering "quiet-er" core muffler. Its definitely not a quite bike. The exhaust turned out great and sounds amazing with the cone engineering muffler. You really helped me out on this one. Thanks again Ted!
Offline JoeCooley
Re: 78K Cafe - New Exhaust w/ video
« Reply #68 on: March 02, 2017, 03:51:37 PM »
Here's a quick video of the new exhaust.
It's still running rich. I think I need to move the clip position up a groove. The bike runs ok, but I can tell it's pretty rich. I also need to change the oil again and rebuild the oil pump. Noticed today that I only get 20psi of oil pressure when the bike is fully warm. I dont want to scrap another cam and valves.
Maybe you guys can provide some input. Why would the engine run super rich with the same carb tune as before the big bore? Wouldn't the bigger bore, fresh rings, rebuilt head, and good compression cause the bike to make more power and need more fuel?
Offline JoeCooley
Re: 78K Café - New Exhaust w/ video
« Reply #69 on: March 02, 2017, 06:13:07 PM »
You may be experiencing the rings not yet seating and not a rich carb condition. How do you know its rich? How many miles are on the rebuilt motor that necessitate an oil change?
Maybe 60 miles on the rebuild. The the oil change is more due to the amount of fine shiny metal in the oil fromy the cam and rocker tower destruction. I got all the big stuff out bit it will take a few oil changes to clear it all out. The exhaust smells very gassy and may have put gas in the oil. Wet plugs also last time I checked before I adjust the pilot jets leaner. I need to pull plugs again and see if they are still wet. I also get a rich stumble at part throttle occasionally.
« Reply #70 on: March 02, 2017, 07:19:02 PM »
If you want the complete drilled out lighter look on back brake, check out the pic..
Takes an hour or two..
Offline JoeCooley
« Reply #71 on: March 02, 2017, 08:17:01 PM »
Thanks for the idea Frank. That looks awesome!
Offline JoeCooley
« Reply #72 on: March 20, 2017, 04:49:56 PM »
Update: Purchased some Marzocchi shocks off eBay. Hopefully they work. I've always loved the look of these shocks and I've heard they work well on our bikes. It appears that the red paint has been stripped at some point. Not sure if I'll paint them red again. Maybe black with silver springs to fit the monochrome color scheme? Opinions?
« Reply #73 on: March 20, 2017, 05:41:22 PM »
More important than color, is condition. If they haven't been rebuilt, you might want to have them rebuilt.  Ask the seller.
Offline slikwilli420
  • Master of Disaster
« Reply #74 on: March 20, 2017, 06:31:19 PM »
Rebuild them yourself it's super easy and the kit is like $65.
