Author Topic: Powdercoat front brake caliper - good idea?  (Read 1970 times)
Offline Franky
« on: January 27, 2017, 04:46:39 AM »
I took it apart as it was sticky. Cleaned out lots of gunk and now that I have it apart, I figure I'll paint it. But, we all know that paint and brake fluid is a horrible mix... how about powdercoating? Does it play nice with brake fluid? Will the caliper be OK with the 180 degree celcius curing?
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: Powdercoat front brake caliper - good idea?
« Reply #1 on: January 27, 2017, 04:54:56 AM »
The temperature is not an issue, but while pc is more durable than paint, it is not completely resistant to brake fluid.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #2 on: January 27, 2017, 05:51:54 AM »
I've used caliper paint (available at auto parts store) on several calipers and have not had an issue.
I use a hose and bleeder bag when bleeding so fluid does not leak on the caliper, other parts of the bike or my garage floor.
Offline 540nova
« Reply #3 on: January 27, 2017, 06:33:05 AM »
I powdercoated mine, it is very resistant to brake fluid.
Offline DaveBarbier
« Reply #4 on: January 27, 2017, 06:33:10 AM »
Agreed. Both my calipers are powder coated in satin black. Look great.
Offline Bodi
« Reply #5 on: January 27, 2017, 06:52:39 AM »
It works fine. The OEM coating - dunno what it is - holds up to brake fluid. I have had them powdercoated with no ruination from occasional dribbles.
Mask the bore, the face where it mounts to the bracket,  and the holes for the line and bleeder. The coating may crack under the bolts, I did not mask a washer circle.
Offline T100
« Reply #6 on: January 27, 2017, 12:03:42 PM »
Use caliper paint. Immune to brake fluid.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #7 on: January 27, 2017, 03:26:36 PM »
I wonder if a satin finish might be more durable than gloss, or at least not show up spills so easily. I had some calipers powdered a few years ago - gloss black - and first time bleeding them got a run of fluid down the outside which left an unsightly stripe that I was only able to cover up by painting the caliper.
Lesson I learned there was never to take any chances with brake fluid, now when I come to bleed brakes I try to protect finished surfaces as much as I can by masking and winding rags around the caliper.
Another factor may be in the PC process - the sage advice of employing a reputable tradesman who knows motorcycles (rather than someone who coats railings and garden gates) might apply here.... :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline T100
« Reply #8 on: February 19, 2017, 08:13:41 AM »
I remember reading once that the old school English bikes some used black stove paint on their engines for heat durability.
« Reply #9 on: February 19, 2017, 08:39:25 AM »
Sure, I've done that and used regular spray too. The coat is a more durable finish.
