Author Topic: 76 550 top gear rev problem  (Read 7539 times)
Offline FIREBLADE74
« on: April 22, 2017, 05:11:29 PM »
Need help! I've searched but no one ever comes  back with a solution.
The bike will redline in all gears except 5th. It'll climb but stop at 5500, 75mph. The throttle is at the stop. Plugs go from white to tan across the cylinders with 1-3 white and 4 tan. The sync is spot on air screw is out 1.5 turns. I'm thinking the boots to the cylinders are shot, I did the starter fluid test.
Do y'all think the worn boots are causing this? I've ordered new boots but want to make sure I'm not missing anything.
Bike is a 550ss with 6100 miles.
3k service done.
Point gapped and timing set.
New plugs
Pod filters
110 main jet
06 CBR1000RR, 76 CB550
Offline Bodi
Re: 76 550 top gear rev problem
« Reply #1 on: April 22, 2017, 05:38:17 PM »
Worn boots would cause lean mixture. Vacuum is lowest (manifold pressure highest) at WOT so that's unlikely to be your problem. What speed is it going at 4th gear redline?
It should easily top 75mph in top gear but none of the stock fours will pull redline in top gear unless going downhill with a stiff tailwind.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: April 22, 2017, 05:55:24 PM »
Yeah, it's a lot easier to do the ton if you've redline shifted in 4th.  Which is about 85mph ish
Offline FIREBLADE74
« Reply #3 on: April 22, 2017, 06:52:28 PM »
Bet! What I noticed is that if I redline 4th, I can get 5th over 6rpm barely tho.
So these bikes can't really redline 5th easily?
Thanks guys, ill hit back what the new boots do.
Offline FIREBLADE74
« Reply #4 on: April 22, 2017, 06:53:24 PM »
Didn't notice the speed, ill say about 60-65.
  • Holy Cow! I'm a
« Reply #5 on: April 22, 2017, 09:41:15 PM »
Make no mistake, the cb550 can and will go to the max when it's tuned and running properly.  I've noticed a bit of a character change since switching to a pamco ignition timing unit (with a clean and lubed advancer unit).  Which as made it easier to roll on the throttle in 5th and do the boogie.
Things that have slowed me down are,
1) unsynced carbs
2) points timing wrong
3) valve tappets out of spec
4) fuel mix wrong (both float level and a/f screw)
5) brake drag (didn't adjust the rear brake screw when changing tires)
And a big one that I battled EXHAUST LEAKS and an airbox seal leak.
Offline FIREBLADE74
« Reply #6 on: April 22, 2017, 11:04:29 PM »
1) unsynced carbs
I'm betting all on the rubber boots being dry rotted.
Lubing advance unit? Is that pamco specific?
  • Holy Cow! I'm a
« Reply #7 on: April 22, 2017, 11:52:20 PM »
A clean advancer unit is something everyone should have.
Alas, the pamco instructions did have a prompt.
Offline FIREBLADE74
« Reply #8 on: April 23, 2017, 08:55:21 AM »
I'll take that bet. I'll bet you your fuel level/mixture is wrong and you are starving for fuel at the higher speeds. Supple boots will help in all areas, but if they were the source of your issue, the issue would be very noticeable at idle.
What would be noticeable at because my idle isn't the best, lol.
Offline FIREBLADE74
« Reply #9 on: April 25, 2017, 03:02:28 PM »
Ok the boots wasn't the problem but I noticed if I get 4th up to about 7rpm before I shift I can get 5th to creep pass 6rpm.
Coming from a 1kcc bike I may be expecting too much. Am I?
Offline DaveBarbier
« Reply #10 on: April 25, 2017, 03:17:45 PM »
Are you riding with a 4x8 sheet of plywood facing the wind?
You should be able to go higher in the revs in top gear. On my 550 I can go around 8k in full tuck slightly uphill on this stretch of highway where there's no cops :)
Offline FIREBLADE74
« Reply #11 on: April 25, 2017, 03:32:08 PM »
Lol, feels like it!
Offline FIREBLADE74
« Reply #12 on: April 25, 2017, 04:03:48 PM »
Ok played with the air mixture:
1.5 turns grayish white
2 turns bone white
1 turn dry black
1.25 should be the sweet spot
Offline jonda500
« Reply #13 on: April 25, 2017, 05:01:28 PM »
So going by that turning the airscrews in definitely made it richer and turning them out made it leaner - do you have any pics to back that up so we can put the airscrew debate to bed forever?
John
A starter clutch thread:
Offline FIREBLADE74
« Reply #14 on: April 25, 2017, 05:20:57 PM »
John
No pics but righty is rich and lefty is lean.
1.25 turns is not the sweet spot! SMFH!
The kicker is it hauls azz in gears 1-4, but fall flat in 5th.
I'm now thinking my spark maybe weak. I do still have the coils from 1976 on there. What do you guys think?
« Last Edit: April 25, 2017, 05:22:45 PM by FIREBLADE74 »
Offline DaveBarbier
« Reply #15 on: April 25, 2017, 05:39:30 PM »
John
I would test them first. I think there's info on how to test in the FAQ. If the coils were bad you wouldn't haul a$$ 1st-4th. I think it's pretty rare for the coils to go bad, they're pretty robust units. Mine from '78 perform fine. My other bikes I've had from '74 were the same.
Here is the coil testing info from the FAQ:
http://forums.sohc4.net/index.php/topic,5752.msg8383.html#msg8383
I'd focus on carbs. Remove and clean them and check fuel level with clear tube method.
Tire pressure good? Doubt that has anything to do with it but hell, thought I'd ask.
Offline FIREBLADE74
« Reply #16 on: April 25, 2017, 05:53:05 PM »
John
Damn those carbs! I'm going to take them somewhere to be professionally cleaned!! I've cleaned those carbs about 4 times now, but I think that's my problem! I'm going to tear them down to their very last compound, lol.
But if it were the carbs wouldn't the problem be noticed in every gear?
Tire pressure at 36.
« Last Edit: April 25, 2017, 05:57:53 PM by FIREBLADE74 »
Offline DaveBarbier
« Reply #17 on: April 26, 2017, 04:14:18 AM »
Yes.
Ah, so Cal are you suggesting more like fuel delivery like clogged tank vent or inline filter?
Offline FIREBLADE74
« Reply #18 on: April 26, 2017, 04:17:41 AM »
Yes.
No inline filters so I'll check the breather tube and try riding it with the gas cap open.
Offline FIREBLADE74
« Reply #19 on: April 26, 2017, 06:34:12 AM »
I'll take that bet.
Sucks being right.
Damn calj lol.
Offline FIREBLADE74
« Reply #20 on: April 26, 2017, 04:15:56 PM »
This is my kinda chop, 3rd gear 8krpm, 60-65mph.
Plugs 1, they all look the same. I cant seem to load anymore
Offline FIREBLADE74
« Reply #21 on: April 26, 2017, 04:17:19 PM »
plug 2
Offline FIREBLADE74
« Reply #22 on: April 26, 2017, 04:18:17 PM »
plug 3
Offline FIREBLADE74
« Reply #23 on: April 26, 2017, 04:19:59 PM »
plug 4
These all were ran with 1.25 turns out on air screw
Offline Killer Canary
  • Typical Bran Muffin
« Reply #24 on: April 26, 2017, 04:45:24 PM »
Do you remember if you've cleaned the screen in the fuel tank/petcock?
Kawi GPz900, H1
