Author Topic: Stev-o's K4 "Big Bang Theory"!  (Read 37428 times)
Online Stev-o
Re: Stev-o's K4 "Big Bang Theory"!
« Reply #100 on: July 12, 2017, 04:54:02 PM »
Moving pretty quickly Steve! Won't be long and I'll be expecting a video.
I can send you a video now but will be pretty boring w/o a running engine!
Online Stev-o
« Reply #101 on: July 12, 2017, 05:02:30 PM »
A little cooler today [only 96!] so thought I'd get a little shop time in.
Pulled the rear wheel to clean and check sprockets, brake shoes, bearings and the BT45, all look good. Also cleaned the chainguard and swingarmarm while the wheel was off and out of the way.
The Bridgestone does show some minor wear, but I think it's good for another 1000 miles.
Wheel back on....
« Last Edit: August 20, 2017, 12:02:51 PM by Stev-o »
Offline riverfever
« Reply #102 on: July 12, 2017, 05:32:31 PM »
96??!!  :o  I would melt. It was in the 50's here and lovely.
That rear wheel looks drop dead gorgeous Steve!
Online Stev-o
« Reply #103 on: July 12, 2017, 05:36:25 PM »
Thanks...it needs stainless spokes but that will happen at a later date.
Offline Tews19
  • I am no
« Reply #104 on: July 12, 2017, 07:12:08 PM »
96 is nuts! I was sweating just from reading the temperature!
1970 Honda CB750 survivor.
« Reply #105 on: July 12, 2017, 09:26:34 PM »
Wait, someone has new oil lines?
Who makes them?
Are any available?
I would like some new ones for my K3.
Steve
Offline CycleRanger
  • No comment about being an
« Reply #106 on: July 12, 2017, 09:42:38 PM »
Who makes them?
Are any available?
Steve
http://forums.sohc4.net/index.php/topic,166903.0.html
Offline Restoration Fan
  • My wife will never call me
« Reply #107 on: July 13, 2017, 03:04:30 PM »
Who makes them?
Are any available?
Steve
Not only that, you won't find a more stand up guy than Rafi.  Very good guy.
Online Stev-o
« Reply #108 on: July 17, 2017, 09:51:26 AM »
Quick update....
Chain cleaned and back on...
New oil filter and polished cover back on....
Left side covers button up...
But holding off putting the sprocket cover back on.  Upon inspection of the wiring harness, noticed some burning on the large connector...
...and another wire looks to have been pinched. Damn PO!
Luckily, its just the short alternator wiring harness, no damage to the main harness.  A replacement is on the way...
« Last Edit: August 20, 2017, 12:04:40 PM by Stev-o »
« Reply #109 on: July 18, 2017, 02:30:01 AM »
Looks great Steve, well done! Are the spokes really badly rusted, or just covered in chain grease? Cheers, Terry. ;D
Online Stev-o
« Reply #110 on: July 26, 2017, 03:43:52 PM »
The rear spokes are neither rusty or covered in grease, I did give them a cleaning when I pulled the wheel.  They are a dull gray as opposed to shiny stainless on the front. One day they will get changed, possibly when the tire wears out and gets replaced.
Online Stev-o
« Reply #111 on: July 26, 2017, 03:51:47 PM »
Quick update and a question....
Received the alternator harness and got it all connected up.  Installed the sprocket cover, ground cable as well as the AGM battery, I now have a cranking motor! [another minor milestone]
When I installed the ground cable to the solenoid the rubber cap that goes over the connection is worn out and I want to replace it.  I checked the fiche and do not see it. Anyone have the proper name or part number. Look here for reference...thx
Offline CycleRanger
« Reply #112 on: July 26, 2017, 04:48:28 PM »
http://www.easternbeaver.com/Main/Elec__Products/Connectors/Boots/boots.html
or
http://www.ebay.com/itm/8-Pcs-15mm-x-8mm-Smoking-Pipe-PVC-Battery-Terminal-Insulating-Covers-LW-/181775772171
or
http://www.oldbikebarn.com/parts-by-model/honda/cb200/honda-cb200-cb-cl350-cb360-starter-terminal-rubber-boot.html
Online Stev-o
« Reply #113 on: August 04, 2017, 04:16:03 PM »
Thanks Ranger, but I ended up having one.
Got that installed and got the area looking tidy....
Online Stev-o
« Reply #114 on: August 04, 2017, 04:20:35 PM »
Next up is everyone's favorite task....installing carbs!
I have my "special tools"...........
Really not bad, had the carbs on in 15 min.   Then cleaned up and installed the airbox...
« Last Edit: August 20, 2017, 12:05:35 PM by Stev-o »
« Reply #115 on: August 04, 2017, 04:50:46 PM »
Jesus Steve-O, you been using that 2x4 for a while, huh.
I like a little smear of bearing grease on the lip of the carb boots...
Online Stev-o
« Reply #116 on: August 04, 2017, 05:04:42 PM »
That 2x4 is perfect, Sean.  Old and soft, easy on the carbs, and angled just right on one end.
Any lube is good lube!
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #117 on: August 05, 2017, 06:43:53 AM »
I'm guessing you use the 2 x 4 as a lever to push the carbs into the carb boots?
Bud
1973 CB750K3 Chopper (in pieces)
Online Stev-o
« Reply #118 on: August 05, 2017, 07:14:19 AM »
Actually to push the carb boots [with carbs] onto the head, Bud.
That's how they came off during disassembly.
The 2x4 fits within the frame from the top and gives ample amount of leverage.
I may start re-popping this "tool"!
Offline budman
  • 1914X
« Reply #119 on: August 05, 2017, 10:09:48 AM »
Maybe you could have them CNC'd out of billet aluminum.  How much?
Bud
Online Stev-o
« Reply #120 on: August 07, 2017, 07:30:22 AM »
Alum is too hard, Bud, needs to be old southern soft pine!
Online Stev-o
« Reply #121 on: August 07, 2017, 07:45:09 AM »
So, with carbs on and a cranking motor, I followed Hondaman's suggestions on how to prime and get oil pressure:  kick over motor 40-50 times followed by a couple short cranks with the electric starter [about 3 seconds ea].
I did this a couple times but could not get the oil light to go out.  Then, getting all excited, I thought hey, with fuel in the carbs this thing might start?!
Hooked up the fuel line, cranked it over a couple times and we have a runner!!!
Here is a video, the start up was a little premature as the cables weret yet connected and the air filter not yet installed..
https://www.flickr.com/photos/156452678@N06/36018847620/in/dateposted-public/
So stoked!!
« Last Edit: August 07, 2017, 07:54:28 AM by Stev-o »
Offline budman
  • 1914X
« Reply #122 on: August 07, 2017, 08:10:27 AM »
Cool!  Glad you got it running.  Maybe you can repop that left handed throttle lever and make a few bucks.
Bud
Online Stev-o
« Reply #123 on: August 07, 2017, 08:16:48 AM »
Thanks.      Ha....might run into patent issues on that throttle lever?!
Online Stev-o
« Reply #124 on: August 08, 2017, 05:09:48 PM »
A little out of sequence, but lets wrap this sukka up!
Found these old pipes in the Batcave and slapped em on!
Also found this body kit, bought it a couple years back from Chewy.  Put NOS badges and a petcock on it....
And about three months later, she is done!  I've put about 160 relatively easy miles [not over 6K RPM yet] and she is running good!
However, I've blown the main fuse twice though, thats a new issue, never happened before.   Put a new fuse and off she went, but that concerns me a bit, must have a short somewhere but not a daily thing [I make sure I have a supply of fuses with me at all times!]
Here she is today at the local park....
...and how she looked on the day she blew!
Now I can concentrate on my Kaw H2 project, want that on the road by Oct 1.  Then a K1 is waitin' in the wings....
