Author Topic: Electric box under seat  (Read 3280 times)
Offline aminemed
« on: June 11, 2017, 01:26:15 PM »
Do I risk something leaving the electric components as in the picture? I think about the magnetic switch that has a tendency to overheat. I put the rectifier outside the box and I'm running a lithium ion battery.
« Last Edit: June 11, 2017, 01:27:50 PM by aminemed »
Re: Electric box under seat
« Reply #1 on: June 11, 2017, 01:39:57 PM »
Should look dapper riding about in a fire suit.
Offline aminemed
« Reply #2 on: June 11, 2017, 01:43:40 PM »
so I guess I'm running a very big risk ?
« Reply #3 on: June 11, 2017, 01:51:11 PM »
My first thought was short circuit that will blow the main fuse and stop bike direct if lucky. No fuse, maybe melted wires, and more if fuel leaks.
It must be mounted and clamped in a way that it can not be shorted.
Offline aminemed
« Reply #4 on: June 11, 2017, 01:58:33 PM »
sorry maybe it's a dumb question, but what can cause the short circuit ?
Offline aminemed
« Reply #5 on: June 11, 2017, 02:16:38 PM »
so what is the best way to hide wires under seat ? I've invested in the lithium battery especially to be able to hide electronics under the seat
« Reply #6 on: June 11, 2017, 02:36:51 PM »
Build a box , mount stuff inside.
Offline aminemed
« Reply #7 on: June 11, 2017, 02:45:12 PM »
that what's on the picture :s ! it's a box I built.
Offline 540nova
« Reply #8 on: June 11, 2017, 03:05:56 PM »
Dude, have some pride in your work; That's a rat's nest.
Sent from my SM-G955U using Tapatalk
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #9 on: June 11, 2017, 03:09:23 PM »
Need to have your vreg and recifiter secured and rubber insulated too.
Offline Jimray23
    • none
« Reply #10 on: June 11, 2017, 03:18:52 PM »
Secure everything that has a bolt hole or mount and give that battery plenty of room. The battery also needs some kind of vent to help keep it cool.
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
« Reply #11 on: June 11, 2017, 03:21:01 PM »
Mount stuff, has to be anchored.
Offline aminemed
« Reply #12 on: June 11, 2017, 05:16:32 PM »
Thanks guys, I'll leave the electronics for another time as my lifepo4 lithium battery died completely...just used 4 times. I'm afraid that my bike voltage exceeded the 14.4 volts. Just hooked up an acid battery and everything is fine, but as soon as I plug the lithium one, everything is dead!!
  • Holy Cow! I'm a
« Reply #13 on: June 11, 2017, 05:46:52 PM »
It would be worth purchasing an www.oregonmotorcycleparts.com
V-reg if you're needing to be real precise about your charging with the LiPo battery.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #14 on: June 11, 2017, 05:51:20 PM »
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
speaking of keeping the battery cool.  is it absolutely necessary to have a battery breather hose?  i do not have one.
« Last Edit: June 11, 2017, 05:54:45 PM by evinrude7 »
cb750 k6 - ugly
Offline aminemed
« Reply #15 on: June 11, 2017, 05:52:43 PM »
is it best to go for a vreg or buy a combo rectifier-regulator to change the old stock separate units ? thx
Offline evinrude7
  • not a kung-fu
« Reply #16 on: June 11, 2017, 05:57:17 PM »
tony at oregon motorcycle parts really stands by his stuff.
cb750 k6 - ugly
Offline jonda500
« Reply #17 on: June 11, 2017, 06:01:58 PM »
The breather hose doesn't keep the battery cool, it allows the flammable gases that develop when charging to escape, and when properly routed, stops battery acid corroding everything below the battery, dumping any acid that may drip out on the road instead. So not absolutely necessary, but insane not to have one!
John
A starter clutch thread:
  • Holy Cow! I'm a
« Reply #18 on: June 11, 2017, 06:27:35 PM »
I like discreet electronics.  The omp vreg plugs into the factory harness with no guesswork.  Biggest perk, widely adjustable with a small screwdriver.
He also sells a rectifier.  I have them both.  He warns not to let the rectifier ground its body to anything.  So I put a loop of old rubber around mine for safety.
Offline evinrude7
  • not a kung-fu
« Reply #19 on: June 11, 2017, 06:43:17 PM »
John
thanks jonda.  even with a modern sealed battery?
« Last Edit: June 11, 2017, 06:47:48 PM by evinrude7 »
cb750 k6 - ugly
  • Holy Cow! I'm a
« Reply #20 on: June 11, 2017, 06:50:08 PM »
No hose on sealed batteries
Offline jonda500
« Reply #21 on: June 11, 2017, 07:44:10 PM »
If there's nowhere to attach a hose then it's safe to say it don't need one!
John
Offline Jimray23
    • none
« Reply #22 on: June 11, 2017, 08:46:48 PM »
As far as keeping the battery cool, its more important on lithium ion batteries, they are temperature sensitive
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline DaveBarbier
« Reply #23 on: June 12, 2017, 04:32:02 AM »
John
Haha
Offline pjlogue
« Reply #24 on: June 12, 2017, 04:55:04 AM »
That's an accident waiting to happen.  Vibration and jolts will ruin your wiring and components.  Especially the Li battery pack which will get smacked around on every bump you hit.  Components need to be mounted and vibration isolated if they were originally meant to be mounted that way.  Wire bundles need to be anchored to the frame so they don't flex and that Li battery, I would not have one under me on a bike.
Aircraft and motorcycles have 1 thing in common....vibration.  You will never find a lose wire bundle/components on either from the factory.  There is a reason for that.
-P.
