Ok… pulled the carbs last night. All the jets were immaculate but I cleaned them again to be sure. Every orifice was blasted with spray carb cleaner and pressurized air. Every float height was inspected. #2 needed a slight adjustment. A bench synch was conducted again and was a slight improvement over the last. I’m confident the carbs are in great shape. I was happy to find pulling them for the 2nd time was WAY easier than the first.
When reinstalling the carbs I decided to leave the push throttle cable out. I was having a real problem with my throttle sticking open with it installed so I just got rid of it. It works 100% better without it and I know others on the board have done the same. It is now working properly so I am content, for now.
I conducted another compression test:
             no oil      oil
#1   115        140
#2   120        140
#3   115        145
#4   115        140
These figures look pretty consistent so I think all set with compression.
I purchased a 1.5 amp hour 6 and 12 volt battery charger last night. I don't yet have a batter for the bike. I am wary of jumping it off my car even though I did it that way the first time to see if she would run. The Kaw z400g I'm getting uses the same battery as this CB. As it turns out the PO of that bike has 2 batterys. So I figure, being a thrifty guy, I can wait for that bike and battery instead of buying a new one... but I'm getting pretty anxious.
Next step, once I have the battery, is to properly synch the carbs with a manometer and set the timing with a strobe gun. While I'm waiting to borrow that equipment I may:
1) start cleaning up the gauges and handle bars,
2) try and fix my sticky front brake issue,
and/or
3) get some slight powdery patches of rust out of my tank. I think my tank is in excellent shape but I’ll treat it with molasses anyhow to get rid of any oxidation that exists.
Finally I took some pics of my bike with the pipes back on. I’ve included the same old before shots for some comparison of course. Looking good I think.
