Author Topic: What did you do to your non-motorcycle vehicle today?  (Read 289614 times)
Online Kelly E
  • Geriatric Hooligan
« Reply #3550 on: June 29, 2024, 08:57:28 PM »
put a 45 degree brass elbow on my briggs powered toro ride on mower oil drain,why do they have the drain plug so it makes a mess no matter how hard you try not to?
Because they can. 8)
Probably some kind of twisted engineer joke. ;D
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #3551 on: July 01, 2024, 08:15:18 AM »
got next door mates Leyland p76 brakes fixed!
Never heard of that model, Dave.
After a bit of googling, it's a British car manufacturer, designed by an Italian
[Giovanni Michelotti] and built in OZ!  What could go wrong??!!!
Online Don R
« Reply #3552 on: July 01, 2024, 04:57:49 PM »
 I went three rounds with the Holley 600 carb on my 40 chevy, that gas hog wanted to drown the 350 in fuel. I cleaned the secondary needle and seat a couple times and pulled off the float bowl twice before getting it to not overflow. I left the fuel a little below the window plug and hopefully it won't act up the next time I start it.
 After some trouble with melting fuel lines, I replaced them all and added an after-pump filter before the pressure regulator. Still somehow a piece of crud must have lingered.
« Reply #3553 on: July 01, 2024, 11:19:01 PM »
dont ask,hes got two,both v8 4.4 litre and borg warner 35s,were gonna swap one over to single rail 4 speed as factory optioned.
« Reply #3554 on: July 02, 2024, 06:19:01 AM »
Our Lawn Tractor (20HP Craftsman) needed a 3” nipple, 90 degree elbow, and a plug. Absolute stupidity!
« Reply #3555 on: July 02, 2024, 03:05:46 PM »
I've noticed our society seems to put more and More things to do onto us:the people who trust them to provide a service and earn the $ we spend with them.  ::) Cutting corners is somehow making a way for them to $ put us to work for them?
Online Kelly E
« Reply #3556 on: July 02, 2024, 04:46:48 PM »
My Toro LX 425 riding mower has a 20hp Kohler engine that has a tool less oil drain. Pull off the cap, put a pan under it,  twist the drain spout a half turn and the oil is draining.
1983 Honda CB 1100F
« Reply #3557 on: July 02, 2024, 07:21:50 PM »
My 1968 12 HP Sears Suburban has a nipple that sticks out just past the side of the frame. :)
« Reply #3558 on: July 02, 2024, 08:17:33 PM »
This Sears machine looks very similar to the heavy duty Cub Cadet models from the same era.  8)
Online Don R
« Reply #3559 on: July 03, 2024, 04:12:59 PM »
 I put about 40 miles on the 40 chevy today, it came home running rough again. I've cleaned the carbs multiple times but now it seems maybe the points have faded away. They are only 25 or so years old, it might be time for the electronic pickup distributor to go in there.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #3560 on: July 03, 2024, 04:19:27 PM »
If something ever happens to my 305 V6 in my 61 GMC I probably won't go back to a motor with points ignition. But then again what will I do with my 7 dwell meters then?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #3561 on: July 03, 2024, 06:05:55 PM »
Back on the ground! Front wheel bearings replaced, repacked the rears, fresh pads, turned the rear discs a few thou’ and new tires. Alignment, wash and polish to be ready for next race. Double header weekend, back at Mosport.
« Last Edit: July 03, 2024, 06:12:06 PM by BenelliSEI »
Online Don R
« Reply #3562 on: July 04, 2024, 10:03:27 AM »
 I'm contemplating the electronic pickup distributor, it's a magnetic pickup and was wired to an MSD. I don't currently have an MSD on the 40 and I have a big old black Mallory coil on the firewall. I don't think they are multiple spark friendly so I think I'll forgo the MSD box and wire it up as is.
« Reply #3563 on: July 04, 2024, 01:33:41 PM »
I used to have one of those big honking Mallory coils on my 413.;D Don, is the electronic distributor an HEI type with the module that drives the coil?
« Reply #3564 on: July 05, 2024, 06:47:07 AM »
AC/Delco D106HP points
AC/Delco D204 condenser
We’re up to the task. Check your resistance wire even though they weren’t real troublesome..
« Reply #3565 on: July 05, 2024, 07:49:43 AM »
I'm contemplating the electronic pickup distributor...
Hey Don...are you familiar with PerTronix?  I installed it on my Corvette awhile back and is a very good system...
https://pertronixbrands.com/collections/ignition
« Reply #3566 on: July 05, 2024, 07:54:50 AM »
Spent the day on the boat yesterday, had a crew of nine!  Even with temps reaching 100 degrees, good thing about being on the boat is if you feel hot, you just jump in the lake!
Online Don R
« Reply #3567 on: July 06, 2024, 08:39:53 AM »
 I realized the gassy smell in the garage is the fuel pump on the 40 Chevy's mechanical pump. It's a Holley that needs to be clocked to clear the frame and motor mount. I think I can get a rebuild kit for it.
« Reply #3568 on: July 06, 2024, 09:14:42 AM »
I’ve been using their products for years. Excellent stuff.
Online Don R
« Reply #3569 on: July 06, 2024, 09:46:08 AM »
  I am I actually have a similar pickup that came in the dragster we bought, I unlocked the timing, swapped some parts, got a new vacuum advancer and have an MSD cap and rotor with some big 409 type plug wires all left over from our small block 383 dragster engine. I just need to figure out the wiring to the pickup, it has an MSD plug in on it but I'm not running one due to my old Magneto style coil. I'm really not sure if the pickup and coil will get along. I did see a set of NOS GM points on ebay for $30.
 Edit, I realized the fuel pump is seeping gas, the diaphragm is likely melted like all of the rubber fuel lines were last year. It's the only piece that I didn't replace yet, the pump is a Holley that you can take apart and clock the inlet/outlet and I need that due to the frame and motor mount being so close to the engine.
« Last Edit: July 06, 2024, 09:55:51 AM by Don R »
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #3570 on: July 06, 2024, 01:30:48 PM »
Fixed a tire on the pick-up that was leaking around the bead....
Offline CycleRanger
  • No comment about being an
« Reply #3571 on: July 13, 2024, 01:18:03 PM »
Revived a 2015 Subaru pressure washer that was given to me three years ago or so.
Finally got bored enough to look at it.
Cleaned a slight amount of crud out of the carb, replaced the fuel lines, put some gas in it and it started on the second pull.  :)
It's got an electric start too for some reason. The sealed LA battery is long dead and I didn't get the charger but who cares.
It's raining atm so I'll hook it up to water later. I expect it will work ok.
Might change the oil but it looks like a messy job.
Now, if I just had something to pressure wash..
« Reply #3572 on: July 13, 2024, 02:15:41 PM »
I was in a small gas engine repair shop looking for a gas tank for a lawn mower, and the owner took me into a room full of parts machines, including a bunch of pressure washers. He explained that most of them had good engines, but bad pumps caused by running them dry..
Offline CycleRanger
« Reply #3573 on: July 13, 2024, 02:53:30 PM »
Well it quit raining so I dragged it out and hooked it up to the hose. By golly it squirts!
It might be leaking some water at the pump housing, dunno, need to give it a closer look but other wise it worked just fine.
(It looked like may have been was stored outside at some point, I suppose it could have froze with some water in the pump, maybe.)
But for the moment since I don't have anything into it except a couple of pieces of fuel line I'm happy.
« Reply #3574 on: July 18, 2024, 06:12:09 PM »
Finished up and loaded the race car today. Gave it a quick wash and polish. Full weekend at Mosport (Canadian Tire Motorsports Park). 2.5 mile road course with 10 corners and huge elevation changes. My favourite race track! Super fast. No motorcycle stuff until next week……
