Author Topic: 750K2 Hot Rod Revival - Early Christmas  (Read 53581 times)
Offline CBJoe
750K2 Hot Rod Revival - Blowing Smoke [emoji20]
« Reply #200 on: March 08, 2020, 03:51:30 AM »
Hi Pewe....
This is what is driving me crazy....I had a great 1st season ride with zero smoke last weekend.
Until yesterday, I did not do anything to the engine since the Dyno run last fall.  Probably have done maybe 40 miles on bike since Dyno run.
Last weekend I changed main jets to 125s from 120s and did a 20 minute ride.  This was the only change since last year besides cleaning up headlight wiring. No smoke after ride.
I had a re-occurrence of the starter gear issue so I quickly pulled cover and replaced Starter Gear and Rollers yesterday.  Torqued rotor bolt down and installed cover and bam...smoke.
I will double check for fuel issues...but that smoke in video sure appears to be oil burning. I can’t imagine how changing starter gear could cause damage.
« Last Edit: March 08, 2020, 03:56:11 AM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Re: 750K2 Hot Rod Revival - Blowing Smoke :(
« Reply #201 on: March 08, 2020, 03:58:35 AM »
I looked at the video again.
Did it smell burned oil?
If cold outside, it will smoke. Condense look like that too ;)
Offline CBJoe
« Reply #202 on: March 08, 2020, 04:05:26 AM »
Not water vapor...smelled like burning oil, but I will check again this afternoon.  It was smoking a LOT almost right after startup.  I’ll grab another video.
I am hoping I come back and magically it will just be fine again.  I’ll check the carbs again ....maybe I’m jumping to wrong conclusion and it is fuel related.
« Last Edit: March 08, 2020, 05:59:38 AM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #203 on: March 08, 2020, 09:31:48 AM »
I'm open to suggestions here.  I drained carbs and double-checked the main jets...I had this thought that maybe one of the jets didn't get tightened and fell out.  Nope...all the jets look good.  It smokes immediately on startup....does not smell like fuel.  I would think it if was a fueling issue with that much smoke it would smell intensely of rich fuel.
I just cant imagine i could have damaged something on the top end by replacing the starter clutch and torquing the rotor bolt down.
'65 CB77
'66 CM91 (C90'ish)
« Reply #204 on: March 08, 2020, 11:18:16 AM »
Take it out for a good ride Joe. If this persists check your compression. Ring?
« Reply #205 on: March 08, 2020, 12:27:07 PM »
+1 for a ride.
My K2 smoked like Bob Marley and friends at start-up earlier. Rich fuel mix that took some oil at the same time. Stopped smoke after 30 sec idle with reduced choke.
« Reply #206 on: March 08, 2020, 01:14:19 PM »
Yeah, do that. "What are you going to do?
Just a little dark humor. You know I feel for ya.
Offline CBJoe
« Reply #207 on: March 08, 2020, 02:04:52 PM »
Haha Ron...I know you feel my pain. Good thing is that since we've done so much work on your engine I can probably take the top end off in my sleep ;)
Plan of attack...
- Take it out for a ride and hope that I don't kill too many mosquitoes with the Fog
If that doesnt work
- Check Compression / Do Leak down test and go from there.
If the head/cylinders come off, I'm going to take it as a sign that fate wants me to send it back to Mike for further upgrades
'65 CB77
'66 CM91 (C90'ish)
« Reply #208 on: March 08, 2020, 03:17:28 PM »
I guess that B in CBJoe could stand for Billet
Offline CBJoe
« Reply #209 on: March 08, 2020, 03:18:58 PM »
Dont even think it Jerry....but if you're buying then ok...I wont argue ;D
'65 CB77
'66 CM91 (C90'ish)
Re: 750K2 Hot Rod Revival - Blowing Smoke [emoji20]
« Reply #210 on: March 08, 2020, 06:47:06 PM »
Did you leave the petcock on after the ride last weekend? Does the oil smell like gas?
« Reply #211 on: March 09, 2020, 03:13:36 AM »
Id check the plugs after a ride and see how they look. If oily then that would indicate a valve/seal issue - which I very much doubt.
Good luck Joe!
Offline CBJoe
« Reply #212 on: March 09, 2020, 02:32:09 PM »
Hey Scott...I did not.  However i went ahead and drained the oil yesterday in case there was fuel contamination at some point.  Oil didn't smell like fuel.
I'm planning to do as other suggested and take for a ride later this week if the weather holds.  If that doesn't work i'll narrow down rings/valves
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #213 on: April 19, 2020, 11:04:08 AM »
Well...I finally had some time to take the Honda out and slog it a bit.....after a 25 minute ride things seem promising.  Was like a mosquito fogger at stoplights for the first 10 minutes or so...then smoke dwindled down to essentially zero.
I installed a remote Idle Adjuster on the RS Carbs which made setting the idle after warmup a cinch.  I'm going to let it sit for a while and cool down and then i'll start it up again to see if the smoke is gone for good.
Still a few issues to sort out...I'm still having the starter clatter at times...I've done the following:
- Installed a Starter Gear from Scottly that had the contact face machined smooth
- Installed a Starter Gear from Bill Bentons Stash
- Installed New Rollers and Springs
Can a bad starter cause the same symptoms?  Or am I just unlucky with starter gears?  The rotor bolt is still plenty tight
Cheers, Joe
'65 CB77
'66 CM91 (C90'ish)
Re: 750K2 Hot Rod Revival - Hopefully no more smoke
« Reply #214 on: April 19, 2020, 06:07:10 PM »
Good video Joe! Sounds good to me. Glad you got past the smoke issue.
cheers
Andy
Offline TjTalan
« Reply #215 on: April 19, 2020, 06:59:12 PM »
I just read through most of the thread, you have an amazing machine there!
My dream bike.
« Reply #216 on: April 20, 2020, 02:35:45 AM »
Glad the smoke has dissipated... would be heartbreaking to dig into it again so soon. Hope to see you in Cherokee NC this fall...
« Reply #217 on: April 20, 2020, 08:08:19 AM »
 ;D
Offline CBJoe
« Reply #218 on: April 20, 2020, 08:57:56 AM »
cheers
Andy
Thanks Andy...i'm still so vexed about what it could have been.   I must have let it idle for 30+ minutes since it started smoking....but something about the ride made it happy again.  So strange.
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #219 on: April 20, 2020, 08:59:35 AM »
Thank you Sir...I cannot claim credit for the original build, but I've done enough work now that Its starting to actually feel like "my" project :)
'65 CB77
'66 CM91 (C90'ish)
« Reply #220 on: April 20, 2020, 09:10:18 AM »
Good news that it was no remaining problem! :)
Maybe you let some oil enter the cylinders with plugs off during another service you have forgotten?
Or something thru the carbs like high amount of carb cleaner?
Or oil in fuel to not allow tank to rust during the winter?
Offline CBJoe
« Reply #221 on: April 20, 2020, 12:49:40 PM »
I can say nope to all of that...but at this point i'm just happy its gone....I'll just pretend that the magic oil fairy got sucked into the engine and its corpse was burning off  ;D
'65 CB77
'66 CM91 (C90'ish)
Offline TjTalan
« Reply #222 on: April 20, 2020, 01:00:14 PM »
The engine mod list is impressive. How far are you spinning it?
My dream bike.
Offline CBJoe
« Reply #223 on: April 20, 2020, 02:03:41 PM »
Thats for some debate....I let the dyno guys spin it too high I think....up to 10.5K RPM.  To be honest I really haven't had a chance to get a great feel for the bike as it hasn't been ridden much since finishing all the wiring and putting the RS34s on it.
It pulls very hard from 7.5-9K rpm from a butt dyno.
Engine was built by member MRieck...and if the top end ever comes off for refresh he'll get it back.
Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #224 on: April 21, 2020, 08:23:49 PM »
Cheers, Joe
The only thing you haven't changed is the clutch "hub" itself? What oil are you using?
