Author Topic: Time to go racing.  (Read 11642 times)
Re: Time to go racing.
« Reply #50 on: August 10, 2021, 06:41:05 AM »
 I didn't know you had this build thread going David......very nice work sir.
Offline Daggless888
« Reply #51 on: August 10, 2021, 10:31:18 AM »
Cheers mike. I was inspired by bwaller and rocket mans builds. About 5 years ago I read a magazine article on the Davies 500 and instantly fell in love. Pictures have adorned the garage walls since and the seed was planted. It’s getting closer to reality now and can’t wait to get it completed. Thank you for the information you sent through. Will be in touch shortly.
« Reply #52 on: August 11, 2021, 07:15:35 AM »
Attached fairing. Looks fast. Fairing is Davies classic model.
I have the more modern model fairing.  How was the job of fitting the fairing? Did the mount points seem to match up well or did it take some muscling?  Also where and how did you attach the lower portions of the fairing?
« Reply #53 on: August 11, 2021, 10:40:27 AM »
Doesn’t Davies makes a fairing for their frame?  Was thinking that Brent used it on his. When the bike had the end over end crash it really tore it up… but, that is normal on many fairings. I cannot understand how MotoAmerica bikes can go down and come out fully rideable after a low side when anytime you drop most street bikes in a low side you are looking at repairs…
Offline Daggless888
« Reply #54 on: August 11, 2021, 11:22:43 AM »
The fairing attached up quite well. The Davies fairing is made for narrow engine case tho so you would probably need to remove the alternator or make a hole for it to poke through. Top mounting is off a fairing bracket and the bottom mount is from the top rear engine bolt. I turned up a couple of plugs to slip inside the pipe for quick release. On a street bike I would probably just bolt it directly to the mounting shaft. Once you have everything all lined up then a small bolt in either side bracket will stop the whole thing slipping down. I read somewhere earlier to make sure you have your exhaust on when fitting. If you don’t you will probably end up having to put a zip tie through your hole to hold everything in place while you think about your stupidity and have to drill another hole through your freshly painted fairing and then go through the hassle of plugging the hole that’s in the wrong spot by about an inch and then touch up the paint to hide your mistake. I should have read that tip earlier 😩 photos to follow.
Offline Daggless888
« Reply #55 on: August 11, 2021, 11:24:20 AM »
Top mounting bracket
Offline Daggless888
« Reply #56 on: August 11, 2021, 11:28:31 AM »
Bottom bracket and plug
Offline Daggless888
« Reply #57 on: August 11, 2021, 11:52:20 AM »
Mmmm.
Offline Daggless888
« Reply #58 on: August 26, 2021, 12:36:33 AM »
A little bit of jmr goodness arrived in the mail today. Just the head to go and I can wake up the neighbourhood. Cylinders are all done but have to wait until the country is out of lockdown.
« Reply #59 on: August 26, 2021, 10:20:26 PM »
Where are you at ? I might be able to make a nice cover for  the back of the tach..
Offline Daggless888
« Reply #60 on: August 31, 2021, 11:46:25 AM »
I’m hiding down south in New Zealand. A cover would be brilliant if it can easily be made. I’m keen. What info would you need?
Offline Daggless888
« Reply #61 on: September 06, 2021, 02:21:58 AM »
Cylinders returned from being nikasil coated and O ringed.
Offline Daggless888
« Reply #62 on: September 06, 2021, 02:23:58 AM »
Davies slipper pistons fitted and cylinders are on.
Offline Daggless888
« Reply #63 on: September 06, 2021, 02:25:58 AM »
An hour later and cylinders all fitted. Went together quite nicely.
« Reply #64 on: September 06, 2021, 11:38:56 AM »
Nice bike porn pics Daggles!
Offline Daggless888
« Reply #65 on: September 28, 2021, 12:27:15 AM »
Cheers David. I’ve been saving parts for a few years and it’s nice to start putting them all together.
Offline Daggless888
« Reply #66 on: September 28, 2021, 12:32:03 AM »
Been spending a few nights checking everything over. Degreeing the cam and checking valve clearances. 1st race is in a couple of months so need to get a wriggle on. Just dropping a standard head and cam on top while I get a proper head machined and ported.
Offline Daggless888
« Reply #67 on: September 28, 2021, 12:33:20 AM »
Offline Daggless888
« Reply #68 on: September 28, 2021, 12:34:37 AM »
Everything all sealed up and ready to drop in the frame.
Offline Daggless888
« Reply #69 on: September 28, 2021, 12:51:17 AM »
Lotsa bubble wrap to stop the scratches and then we had the engine back in the frame. Now the push is on for all the bits and pieces. Getting closer.
Offline Rocketman
Time to go racing.
« Reply #70 on: September 28, 2021, 06:32:52 AM »
Getting close!  Exciting time!
« Reply #71 on: September 28, 2021, 08:40:27 AM »
Looking good Dave, I can feel your excitement!
PM sent.
Offline Daggless888
« Reply #72 on: October 02, 2021, 10:03:40 AM »
Spent the last few days getting everything bolted up in preparation for first start up. Finally got everything done but it was too late last night to fire it up. Didn’t want to scare the neighbours. Will wait till tomorrow to do that.
« Reply #73 on: October 02, 2021, 10:05:19 AM »
Looking gorgeous!
« Reply #74 on: October 02, 2021, 05:26:58 PM »
Looks fast! Let us know how the shakedown goes.
