Author Topic: CB750K2 petcock OEM or aftermarket?  (Read 1537 times)
« Last Edit: March 23, 2019, 05:39:29 PM by andy750 »
Offline tlbranth
Re: CB750K2 petcock OEM or aftermarket?
« Reply #1 on: March 23, 2019, 06:41:00 PM »
If I needed one, I think I'd at least give it a try. Chinese stuff is improving in some areas.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #2 on: March 24, 2019, 05:28:29 AM »
 Not suggesting either one but of you notice in the second link there is a petcock with 2 new bolts and the red fiber washers. I have in the past just had to replace those two red washers/seals to stop a pesky petcock leak. Other rubber parts like the 4 hole gasket are also available to fix the originals.  Those prices though are pretty hard to beat if they work.
  What is the problem your experiencing with your old one ?
« Reply #3 on: March 24, 2019, 12:03:27 PM »
Thanks guys for the feedback. The old one has some gunk in outlet tube #2 that I am having a hard time removing. Looks like calcification and makes it hard getting the brass outlet tube back in (most of the time this falls out but can be pushed back in place). I was going to remove the whole petcock and give it a good cleaning but wanted to a new one to replace so Id have a spare and a running tank.
« Reply #4 on: March 24, 2019, 12:53:30 PM »
17 bucks!  Its like the Honda NOS o-rings cost (bowl and petcock-tank) ;)
Looks OK!  Hopefully no major leak when tank is full long way from the garage. :) :)
Offline johans
    • corporate leather
« Reply #5 on: March 24, 2019, 02:29:48 PM »
Replaced a petcock on a 78K build w/ an aftermarket and it started to leak shortly afterward . Fuel on a hot motor ; not good... Stock petcocks on all of my bikes afterward.
1978 CB750K
1976 CB750F SS
1978 CB750F
1979 Honda 400T
1979 BMW R65
1979 Kawasaki KZ400
2003 Ducati Monster 800 SIE
1988 Suzuki GSXF
Kawasaki 200 KDX
Yamaha YZ 250F
1986 Kawasaki KZ 900
Kawasaki Lakota 300 ATV
« Reply #6 on: March 24, 2019, 02:52:46 PM »
Ok thanks for all the feedback - Ill stick with stock. I dont need gas leaking anywhere...just found out today my carb float bowl gaskets leak on the K4 as I was prepping it for first Spring ride. Ill take that as a sign!
Thanks all,
Andy
« Reply #7 on: March 24, 2019, 03:04:39 PM »
 I finally  replaced mine last August on my Bonneville trip.  K and L on the box I think
 I will enclose a pic of where I changed it, in a field behind an old truck near Miller Raceway..
 I had been having trouble with my stocker, even drove 180 miles to get a now rubber with the 4 holes, but mine continued to leak. I think i even made copper washers for the screws, and changed the O ring.. by the end of it all  it still leaked.
 And  I think it cost me a motor top end and a 5 month old nos Andrews cam.
 So I had to do a motor swap shortly before my trip.
 So they seem to leak internally after 40 years. Keep that in mind.
 So a word if caution, after changing O rings and seals, let it sit a few hours or overnight in the off position. Put paper under it, see if it leaks.
 Things you can do if it is leaking and you can't repair it soon.  Pop the gas lines off at night and install a short hose, between the 2 outlets. Or a plugged hose if single outlet. I also Had a piece of wood to prop up rear of tank.. easier to get lines on and off.
 Great fun changing out a petcock over plastic bags in the dirt in Utah..
« Reply #8 on: March 24, 2019, 03:06:14 PM »
 How much for stock replacement ? Are they exact ?
« Reply #9 on: March 24, 2019, 05:40:16 PM »
Thanks Frank for the input love that photo! Very good tips thank you. I’ve had pretty good luck with stock petcocks so far and hearing mixed aftermarket stories I’ll try a stocker again.
The new ones are $45.
Offline Johnie
« Reply #10 on: March 24, 2019, 05:52:34 PM »
I think you already got some great advise Andy. Every bike I do gets the OEM petcock. The quality is excellent and never had a leak.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #11 on: March 24, 2019, 07:55:48 PM »
 45 is good, I was expecting a hundred .
 Probably 90 up here.,  with our luck.l
I was fed up pulling gas lines every night and worrying. Bought one on ebay  with buy it now, about 75 or 85  miles away, drove down next day and picked it up
« Reply #12 on: March 25, 2019, 06:23:56 AM »
I have an aftermarket petcock on Dorothy and also on Red - never had any problems with it.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #13 on: March 25, 2019, 09:07:57 AM »
I replaced mine with a pattern one; can't remember from where now.
It looked good and was nice and shiny. Worked well until I tried to remove the tank. The fuel pipes came off with the spigots still in place; i.e. the spigots were in the pipes.
I refitted them and "fixed' them in place with some "wonderfix" stuff. Having carb and idling problems I had to take the tank off again and guess what!! Yep, the spigots came free again.
This time round I ground off the arrow-head bit - don't know the correct term – so the pipes slide on more easily and come off more easily.
So far so good; no leaks, but I haven't tried removal again.
I'm going to replace it with an original from another tank - I have new filter and o-rings etc – and will replace that one with an OEM part.
Sean
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
