Author Topic: My pucks are leaking after 49 years... thanks Honda !  (Read 4902 times)
Offline Spanner 1
« on: April 04, 2019, 07:14:03 PM »
So, the very worst thing that is wrong with my 49 yr. old K0/1 is that the 'pucks' have started to leak round about year 48 ! Motor never 'opened' yet. Runs like a champ with 38K miles. I'm not taking the head off , feck it I'll just pressure wash the ( so far minimal ) oil wash on the fins now and again ;)
Re: My pucks are leaking after 49 years... thanks Honda !
« Reply #1 on: April 04, 2019, 07:51:20 PM »
You know, auto trans fluid is supposed to help keep seals soft and pliable.  Could try some of that as an additive to your oil.
Likewise are some additives in synthetic oil offerings.
Stated in another thread was an experience of switching to a synthetic (brand not stated) and the engine developed leaks, which later healed themselves and stopped leaking.  The theory was that the synthetic additives behaved like a penetrating oil past marginal hardened seals, then the rubber swelled and once again sealed as it should. If I recall correctly, it was those pucks that were the leak/stop leak subject.
FYI.  Good luck.  It didn't help my oil passage orings in the head on my 550s.   Dang.  But, I only use semi-synthetic oil.  And, probably not the same blend as was in that posting.  I live with the weeping, as it is not that bad.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #2 on: April 06, 2019, 07:02:38 AM »
the leaking gets worse ray.  just changed mine.  not too much trouble.
cb750 k6 - ugly
« Reply #3 on: April 06, 2019, 07:17:59 AM »
Castrol high mileage oil, seals it right up! L0L!
Offline uksparky
  • Track days
« Reply #4 on: April 06, 2019, 08:04:31 AM »
Go to parts store and get a bottle of Bars rear main stop leak...... add 6oz     used that on my oil pump seals stopped the small leak, i know its a temp thing until i get the courage to remove the mounting screws lol
Present bike 1982 900C Custom
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #5 on: April 06, 2019, 08:55:53 AM »
I pressed some rope in between the fins where that leak comes from.  It helped while out on trips.  Then clean or change the rope when needed.
Kept the engine cleaner.
Offline Tracksnblades1
« Reply #6 on: April 06, 2019, 10:28:01 AM »
+1 on Max Life oils.
I don't like putting anything in engine oil that has diethylene glycol monoethyl ether or variants.
Jet fuel icing inhibitors, ink, paint, solvents.....and an active ingredient in dot3 brake fluid....
No thanks.
Age Quod Agis
Offline Spanner 1
« Reply #7 on: April 06, 2019, 10:55:36 AM »
Thanks for the advice fellas.
« Reply #8 on: April 06, 2019, 02:50:08 PM »
 Ethel has mono?
« Reply #9 on: April 06, 2019, 04:47:47 PM »
Ethel has mono?
Oh no....I hope not...😎
My pucks were leaking yesterday. Terrace riser was plugged up. Had a little skinny 400ft pond.
I was wading around with shovel in mud. Both my pucks were leaking and too soon to be dragging...
Age Quod Agis
Offline Deltarider
« Reply #10 on: April 08, 2019, 01:53:00 AM »
Lucky you. Not in my experience however. Although I saw improvements with other seals and hope it does something good for the valve stem seals, as long as I've owned my bike (since 1980) it has always sweated some at the head, even after a professional top rebuilt. It's just a minor sweating not even threatening my pants. Less when I ride it daily. I can live with it.
CB500K2-ED Excel black
« Reply #11 on: April 08, 2019, 02:25:34 AM »
Virgin engine....
I guess there are some to fix  if it has been used some during the decades.
Leaking oil is the engines cry for " please restore me" !
Offline Johnie
« Reply #12 on: April 08, 2019, 06:02:22 AM »
I do the same thing as SohcCB's above. I got this trick from this forum years ago. I take 1/4 inch cotton rope and stuff it between the fins in front of the seal. Works like a charm. Keeps the motor clean. I can go over a year before I have to change it.
« Last Edit: April 09, 2019, 05:40:16 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline SohcCBs
« Reply #13 on: April 08, 2019, 11:20:06 AM »
I do the same thing as SohcCB's above. I got this trick from this forum years ago. I take 1/4 inch nylon rope and stuff it between the fins in front of the seal. Works like a charm. Keeps the motor clean. I can go over a year before I have to change it.
I used cotton rope, thinking nylon might melt....but I guess it didn't.  It does work pretty well....keeps the engine clean.
« Last Edit: April 08, 2019, 11:21:47 AM by SohcCBs »
Offline lrutt
« Reply #14 on: April 08, 2019, 12:00:10 PM »
Use Cotton rope. Got mine at Ace. I've had it in my K8 for several years now. Once tucked way in there you never see it unless you're really looking for it.
Honda3
« Reply #15 on: April 08, 2019, 01:09:11 PM »
My 1973 CB500F started doing the same a few weeks ago. I cut up an old t-shirt and rolled little pieces of it like a pencil-long joint, or doobie depending on which generation youre from. Stuffed it in between the fins and I cant see the leak anymore. Out of sight, out of mind.
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #16 on: April 09, 2019, 01:45:43 AM »
I always say, it’s better to appear stoopid for a moment than remain ignorant for a lifetime.
What are pucks?
Sean
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #17 on: April 09, 2019, 04:11:03 AM »
Warm oil leak smells bad. It is worth the efforts to avoid that. Just cleaned engine, warm degreaser smells nice!
« Reply #18 on: April 09, 2019, 04:28:04 AM »
What are pucks?
Sean
Rubber seals under cam shaft towers in CB750 SOHC4 engine.  Lot of threats on the topic, the must read is here:
http://forums.sohc4.net/index.php?topic=107040.0
Also not all pucks are created equal - some are too thin to seal properly.    More info in Hondamans book.
« Last Edit: April 09, 2019, 04:31:05 AM by 70CB750 »
« Reply #19 on: April 09, 2019, 09:28:40 AM »
Also between cam cover and head on 500/550, they are used to seal the holes thar are there for access to head nuts. In UK also know as Pontefract cakes
« Last Edit: April 09, 2019, 09:30:13 AM by bryanj »
Honda3
« Reply #20 on: April 09, 2019, 11:25:57 AM »
my 73 CB 500F is leaking. Its a gorgeous bike and this sucks!
Offline DaveBarbier
« Reply #21 on: April 09, 2019, 12:04:56 PM »
Can be fixed in a couple hours. Why live with the leaks?
Honda3
« Reply #22 on: April 09, 2019, 01:33:08 PM »
I was told by a mechanic that the top end has to come off and it would cost around $1,500 as the head gasket needs to be replaced too, etc etc.
« Reply #23 on: April 09, 2019, 01:54:50 PM »
No need to remove head to do the pucks but a common leak is the oil feed O rings in the head gasket which does need the head off, 3 hour job if you dont touch the valves or cylinders---not always a good idea on an old bike.
Another leak is possible from the bolts that hold the steel brackets the cam end caps fasten onto worth checking there as well.
Honda3
« Reply #24 on: April 09, 2019, 01:56:48 PM »
Yeah I think mine is the O rings
