Author Topic: 1974 Rickman Honda  (Read 43243 times)
Online BenelliSEI
Re: 1974 Rickman Honda
« Reply #200 on: April 22, 2020, 04:56:39 PM »
Dwayne...... it’s more than a few dents. It has some serious creases! And, it has so many interior baffles that nothing can come in through the filler. The only way to repair it would be to cut the bottom out, do the work, then weld it shut....... probably pull the baffles out, then reinstall. I may do it.
If you check out one of my previous posts, there is a company in Wales that builds an exact replica of the Rickman CR tank in alloy. It is gorgeous, and expensive. I’ll decide this summer, how much I really like this bike. Also, when I fit the fairing, the tank starts to disappear. I do have a good, original ‘glass Rickman tank, and the molds to make a new one. Too many choices!
« Reply #201 on: April 24, 2020, 09:31:59 PM »
Frank......I love that tank and plan to run as is. The other side is whacked and there is “road rash” on the TOP! But hey, it was a racer.......
The original Rickmans actually have a piece of half tubing welded to the side stand bracket and then it was brazed to the frame tube. I’ll do something similar.
Please let us see a pic of the other side of the tank, the side with the battle scars. ;)
The half tube piece is called a "doubler", as I was told by my friend that worked in the aerospace industry.
Online BenelliSEI
« Reply #202 on: April 25, 2020, 04:49:05 PM »
Scotty....... here you go, pictures of the “hammered side”. It actually has road rash on the top!
Offline lash
« Reply #203 on: April 25, 2020, 06:47:02 PM »
Thats not road rash, thats history!
« Reply #204 on: April 25, 2020, 06:59:00 PM »
Wow that is quite a lot of damage..  looks like they will have to open it up to fix it.l
 It's got experience..
Online BenelliSEI
« Reply #205 on: April 25, 2020, 09:41:21 PM »
A LOT of history!
« Reply #206 on: April 26, 2020, 04:17:55 AM »
Not that it would be inexpensive but Godfrey does tank repairs.
Online BenelliSEI
« Reply #207 on: April 26, 2020, 06:17:15 PM »
RAF..... I’ll probably just leave it alone for now. It’s super clean, no leaks, and the petcocks work. Perfect for the sorting I want to get done, this summer.
Online BenelliSEI
« Reply #208 on: April 30, 2020, 11:59:44 AM »
Super productive day in the shop. Finished fabricating the clamp on side stand. Started by welding the original side stand bracket (cut off the race bike 30 years ago!) to a piece of split tubing, 1.25” ID. Then used the other half to make the temporary clamp. I want to be able to move the stand slightly, to adjust it fore and aft, and get the outward angle just right. The location on the bottom tube makes this difficult, as the frame tube has a flattened top, at the rear, just before the frame tube turns up, for the left rear engine mount. Rickman did this for engine clearance and space is tight. The thin, bolt on strap should just get across that “flat”. Once I get it all set properly, I will shorten the Allen screws to fit nicely.
The plan is to get it just where it clears all the shifter linkage, and leaves room for my riding boot. Next Fall, when I tear it all down again, the saddle plate can be welded, and all the other bits will disappear.
« Last Edit: April 30, 2020, 12:13:10 PM by BenelliSEI »
Online BenelliSEI
« Reply #209 on: April 30, 2020, 12:06:03 PM »
Also built another battery box. The one currently in place belongs back in my K6. Took this old one and cleaned off the original brackets. Now the Fuse Panel, hooks for the rubber mounted solenoid, and two mounts (stud and bolt) for the combo rectifier/regulator have moved. All the components will fit easily within the triangle in the Rickman frame tubes. Should tidy up the wiring nicely.
« Last Edit: April 30, 2020, 12:07:38 PM by BenelliSEI »
Offline TjTalan
« Reply #210 on: April 30, 2020, 08:32:40 PM »
Great work, welds look good too!
Sent from my iPad using Tapatalk
My dream bike.
« Reply #211 on: April 30, 2020, 10:33:34 PM »
Don't trust that clamp-on stand to hold the bike up.
Online BenelliSEI
« Reply #212 on: May 01, 2020, 05:25:47 AM »
Taking bets on the stand.
Tested on a scrap piece of 1.25” pipe and couldn’t budge it with a very long lever.
« Reply #213 on: May 01, 2020, 02:07:32 PM »
Well you won't be worrying about denting the tank..
Online BenelliSEI
« Reply #214 on: May 01, 2020, 06:05:31 PM »
Frank..... so true! And all the turnsignals are old ones too. Maybe I should just lay it down whenever I stop anywhere? Cheers, John D.
« Reply #215 on: May 01, 2020, 06:40:39 PM »
keep her race ready...just gotta park her where there is a tree to lean her up against
Online BenelliSEI
« Reply #216 on: May 02, 2020, 02:02:13 PM »
Sean....... for now, the side stand is removable. Fitted it all up today (few minor modifications to clear shifter linkage). All back on the bench for a quick coat of paint, photos next time......
Online BenelliSEI
« Reply #217 on: May 03, 2020, 01:37:07 PM »
Also...... took another battery box and moved around the brackets, trimmed a few corners and got it to fit perfectly within the Rickman frame tubes. Using a combo for rectifier and regulator, so all fits pretty nicely. Need a source for the rubber buttons that locate the battery. Does Honda still sell them?
Get this installed, lube the chain and swing arm and I am ready for a test ride. I have the indicator panel tied in above the headlight (all working). I do have 4 X small LED dash lights on order. Plan to stick them in a “T” pattern between the tach and speedo, on the instrument mounting panel.
Offline TjTalan
« Reply #218 on: May 03, 2020, 02:12:47 PM »
Looks like it should tuck up nicely!
My dream bike.
Online BenelliSEI
« Reply #219 on: May 03, 2020, 02:20:20 PM »
.......and here’s the completed (temporary) side stand install. When I’m satisfied with location (and angle), I’ll add a few tach welds. Next Winter, when I strip down the bike to strip and replate the bright nickel on the frame, I’ll braze in the bottom saddle, remove all the top 1/2, tabs and cross plate. Looking forward to a ride!
« Last Edit: May 03, 2020, 03:06:43 PM by BenelliSEI »
« Reply #220 on: May 03, 2020, 02:34:57 PM »
Ya John, this is one of your barn bikes, before, at your place and after , as it is so far. Getting there...
Like night and Day  8)
« Reply #221 on: May 03, 2020, 05:14:17 PM »
Yes, battery box buttons still available...
Online BenelliSEI
« Reply #222 on: May 03, 2020, 05:19:39 PM »
“Lash” does amazing restorations! That’s not the most incredible........ A few years ago, he bought an early non sandcast K0 from me. Somebody had hacked and cut the rear 1/2 of the frame to make some kind of hard tail chopper. It was a mess. He also took a K2 (no ownership) frame and grafted on all the required bits. 12-24 months later, he rode over on a beautiful, perfectly restored, blue K0. Imagine my surprise when I realized it was the “chopper”!
Recently, he picked up all the spare engines that came with my race Rickman. He needed a K2 and I’m hoping for a replacement K6 for the bike I used for the Rickman road engine..... Watch for his build posts. Meticulous work!
Offline lash
Online BenelliSEI
« Reply #224 on: May 03, 2020, 05:20:44 PM »
RAF/ Lash....... Spotted them, thanks! Vintagecb750 has them too.
« Last Edit: May 03, 2020, 05:27:48 PM by BenelliSEI »
