Author Topic: Cb650 Cafe racer  (Read 16496 times)
Re: Cb650 Cafe racer
« Reply #25 on: May 30, 2020, 12:40:33 AM »
Damn! DaveBarbie and I might be interested in your VFR800 upgrade to the charging system.  Let us know the specs and what's involved OR if you're willing to turn out a couple more for us!  I assume this is a 32 AMP upgrade, right?
I'll post a more detailed description when I'm done. If it works
Liking the build so far! What’s the benefit of upgrading the charging system? My 650 charges fine and makes a surplus at idle. I’ve only heard people say these have charging problems but haven’t seen anyone post about an issue. Before the tear down did yours have problems?
With the 32 amp system, the bike will charge at idle and you can run accessories including a charger or heated gear.
Online grcamna2
« Reply #26 on: May 30, 2020, 12:50:05 AM »
Really cool conversion on the charging system. from what i can remember the vfr reg/rec is of the more modern mosfet typ, perhaps wouldnt be bad to incorperate that aswell? Looking forward to se the results.
Yes that might be the case. It's bigger anyway.
But I'll upgrade to an even more modern regulator later. It's in the plan to switch to a 4 cell lithium battery. A bit small maby, but it's cooler to do a run start of the bike if needed I have a small 7Ah lead battery now and that works great.
I installed a Shindengen Mosfet style 5-wire Reg/Rect. into my 82' Suzuki GS450TZ with the number #SH775.
I was told by reliable people on another forum this will make my stator last much longer,not like my original reg./rect. which is a 'shunt type' that keeps the alternator running full output even when not necessary.
Offline DaveBarbier
« Reply #27 on: May 30, 2020, 04:11:31 AM »
Ah ok, my bike charges at idle but I’m running all LED lights and no accessories.
Offline dkihlgren
« Reply #28 on: May 30, 2020, 05:25:27 AM »
I will be running a powerful headlight and heated grips for our dark and cold Swedish season
Offline onepieceatatime
« Reply #29 on: May 30, 2020, 05:45:36 AM »
In my experience, a lot of the problem with the CB650 charging system is that the rotor is prone to failure, which usually takes out the rectifier/regulator when it fails.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline dkihlgren
« Reply #30 on: May 30, 2020, 07:09:02 AM »
Got some stuff done today! Starting to look like a bike and not a pile of parts
Online grcamna2
« Reply #31 on: May 30, 2020, 10:25:01 AM »
Rotor or Field coil ?
Online grcamna2
« Reply #32 on: May 30, 2020, 10:27:08 AM »
That is a nice cafe custom.I like the work you completed on the rear swing arm  :)
« Reply #33 on: May 30, 2020, 12:42:46 PM »
ROTOR  31110-425-005
The DOHC bikes of the generation had the same charging system with the same issues.
« Last Edit: May 30, 2020, 12:44:55 PM by onepieceatatime »
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Online grcamna2
« Reply #34 on: May 30, 2020, 12:48:07 PM »
ROTOR  31110-425-005
Not enough magnetic power ?
« Reply #35 on: May 30, 2020, 01:08:53 PM »
ROTOR  31110-425-005
They are an electromagnet; insulation on the windings break down and they fail, or the windings break. When they are good they are in the 4-8 ohm range, measured between the sliprings.
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Online grcamna2
« Reply #36 on: May 30, 2020, 02:02:44 PM »
Ok,Thanks for that information.  8)
Offline DaveBarbier
« Reply #37 on: May 31, 2020, 06:55:23 AM »
Totally understandable, haha.
Offline dkihlgren
« Reply #38 on: June 03, 2020, 01:14:35 AM »
Making an adapter for external oil lines to camshaft. Have to mill 17mm hex and cut off. I'll use M8 banjo fitting and steel braided lines.
Offline DaveBarbier
« Reply #39 on: June 03, 2020, 04:23:13 AM »
I was really considering the external oiling modification. I said to myself once this motor starts leaking I’m going to do it. Haven’t gotten to it yet because my motor is bone dry, haha. Very cool mod. Where will you feed from? I’m assuming the oil gallery plug on right below ignition cover but I’ve heard some trying to do it from the left inside the generator cover so it’s protected.
Offline dkihlgren
« Reply #40 on: June 03, 2020, 04:25:59 AM »
Yes I'm using right hand side. Figure a small banjo is a bit protected.
Offline DaveBarbier
« Reply #41 on: June 03, 2020, 04:39:09 AM »
Yeah I’d say so. That’s where I’d go from if I was doing the mod. Just make sure to put a restriction in the lines the same size as the the factory designed system. I’m sure you did the research but of course you want proper pressure. Any change will affect the crank pressure.
Offline dkihlgren
« Reply #42 on: June 04, 2020, 06:19:14 AM »
Yes my plan is to insert a modified main jet in the banjo bolt. Will use my jet reamer kit so it's the same size as old restrictions.
Offline dkihlgren
« Reply #43 on: June 04, 2020, 07:35:53 AM »
M24x1.5 to M8x1.0 adapter finished. Could not find a caliper when I was milling the hex. So I eye balled it and figured I can always use a wrench... By luck I got a super tight fit to a 19mm socket. What are the odds? Next version will be shorter for a cleaner look
« Last Edit: June 04, 2020, 07:56:29 AM by dkihlgren »
Offline DaveBarbier
« Reply #44 on: June 04, 2020, 09:24:00 AM »
Very nice! I was going to ask whether or not you would modify the existing plug because it’s quite thin. This is much better, but without some sort of flange to press on the case it won’t be able to be torqued down, right? Might it spin when you try and tighten down the banjo bolt?
Offline dkihlgren
« Reply #45 on: June 04, 2020, 09:50:30 AM »
I just copied the original plug. There is a difference between 550 and my 650.
« Last Edit: June 04, 2020, 09:55:44 AM by dkihlgren »
Offline DaveBarbier
« Reply #46 on: June 04, 2020, 12:05:18 PM »
Oh sorry, you’re right, forgot our 650’s have that kind of plug. Carry on :)
Offline dkihlgren
« Reply #47 on: June 05, 2020, 03:39:03 AM »
Damn! Had my measurements wrong. Have to modify my swing bracing. My idea is to make a cut out in the tube so the chain has some room. Then I'll weld some sheet metal to close it up.
Made one restricted banjo bolt for head oil lines.
« Last Edit: June 05, 2020, 03:50:13 AM by dkihlgren »
Offline DaveBarbier
« Reply #48 on: June 05, 2020, 04:49:56 AM »
How much room do you need? Would going to a thinner 520 chain give you the clearance? And nice main jet, haha
« Reply #49 on: June 05, 2020, 08:10:42 AM »
That's not much room even if you swap to a 520 to allow for any slack.  I know it seems more drastic, but if you are going to mod the brace, why not replace with with a wider arc piece (symmetrical on both sides) to accommodate the chain.  I know that the brace is primarily to increase rigidity than structural integrity, but it seems like notching neuters it as a bracing device and makes it more cosmetic.  Up to you though.
« Last Edit: June 05, 2020, 08:14:01 AM by SOHC4 Cafe Racer Fan »
