Author Topic: Early Sandcast Found......  (Read 174441 times)
Online BenelliSEI
Re: Early Sandcast Found......
« Reply #1525 on: October 05, 2024, 07:02:10 PM »
Anybody that calls their bikes a “collection” probably doesn’t ride them…
Rode it around for the afternoon. Stuck very close to home, going in circles and sticking to paved roads. Didn’t really track the mileage, but I’ve put +100 miles on it. Borrowed” an oil pressure gauge from my K1 and it delivered nice, steady numbers (just like the K1). 65-70 psi cold, then +50 running at 4,000 rpm hot. Clutch and gearbox behaved perfectly. Really good news, because I only did the top end. Bottom has never been opened. Sadly, “Winterizing” is not far off!
« Last Edit: February 08, 2026, 02:52:47 PM by BenelliSEI »
Online BenelliSEI
« Reply #1526 on: October 05, 2024, 07:04:00 PM »
I just looked up where the Cobble Beach show is, and it's surprisingly close to where I'm at.  I'd need to get my passport of course, but that's easy enough to do.  It's definitely worth checking out one day!
If the weather cooperates (like it did this year) it’s well worth a visit. If you’re planning on staying overnight, book your accommodations 6 months in advance. Hotels in the area fill up well in early.
« Last Edit: October 05, 2024, 07:20:51 PM by BenelliSEI »
« Reply #1527 on: October 06, 2024, 01:34:44 AM »
Glad to hear you're enjoying riding that very nice K0 which you've restored John  ;)
Online BenelliSEI
« Reply #1528 on: October 09, 2024, 08:21:48 AM »
This is a great Forum, with a really nice bunch of people! Today my friend “Lash” sent me one more piece for this “puzzle”. This air box will need some work, but is a huge step to getting my project back to a true “survivor”. THANK-YOU DWAYNE!
« Last Edit: February 09, 2026, 05:33:36 AM by BenelliSEI »
Online newday777
« Reply #1529 on: October 09, 2024, 08:51:18 AM »
A true Patina Survivor!!
Online BenelliSEI
« Reply #1530 on: October 09, 2024, 09:32:37 AM »
Stu…. It will match the rest perfectly!
« Reply #1531 on: October 09, 2024, 09:51:03 AM »
The rider need patina too, John. Maybe quit shaving before the bike shows? ;D
Or you prefer the NOS rider style? ;D
Online BenelliSEI
« Reply #1532 on: October 09, 2024, 10:10:25 AM »
Not much shaving going on here!
« Last Edit: February 09, 2026, 05:34:16 AM by BenelliSEI »
« Reply #1533 on: October 09, 2024, 10:38:48 AM »
;D ;D ;D
"You meet the nicest people on a Honda"
Online BenelliSEI
« Reply #1534 on: October 09, 2024, 10:41:27 AM »
;D ;D ;D
So true!
Offline lash
« Reply #1535 on: October 10, 2024, 08:58:14 AM »
All winter to get it fixed John!
Online BenelliSEI
« Reply #1536 on: October 10, 2024, 01:32:40 PM »
That, the pipes, and the Rickman CR! Thanks, again!
« Last Edit: October 12, 2024, 07:36:24 AM by BenelliSEI »
Online BenelliSEI
« Reply #1537 on: October 16, 2024, 01:35:25 PM »
Had a good day in the shop. Started cleaning up the +50 year old air box. Lots of patina and cracks in both parts. The bottom needed less work so started with that. JBWeld “Plastic Repair” did one inside corner. It also has a long crack across the bottom which I’ll groove out and repair once the corner has cured….. slipped it in place  for a look. A lot of fading, but I think it will work.
The top has one part under the velocity stacks that is basically free of the rest. The stacks were as hard as the plastic, but using my paint stripper gun I warmed them up to just under melting. Using gloves, folded them up and they came out without causing more damage….
« Last Edit: February 05, 2026, 07:39:52 PM by BenelliSEI »
Online BenelliSEI
« Reply #1538 on: October 16, 2024, 01:44:30 PM »
While the airbox was setting up, started “winterizing”. Drained the carbs, dropped the bowls, floats and jets. Blew everything clean and dry and put it all back together. Battery is out and gave it a short charge.
In addition to the vintage air box, I’m going to work on the original pipes. The one on the lower right has a small hole on the underside, where the head pipe meets the muffler. It’s so low down that a small patch will be  virtually invisible. None of them have any dings, so hoping they will clean up well enough to use.
These few changes will take the bike back to +95% “original”.
« Last Edit: October 16, 2024, 04:45:22 PM by BenelliSEI »
Online newday777
« Reply #1539 on: October 16, 2024, 04:54:40 PM »
John
When you get the carbs back together inject Marvel Mystery Oil or 2 stroke oil into them to fill the bowls, to keep them wet over the winter, then drain them in the spring before running gas in them, it should fire right up. That's what I do.
Online BenelliSEI
« Reply #1540 on: October 16, 2024, 05:11:34 PM »
Stu….I always pull the lines off the petcock and plug the ends with a golf tee (incase the valve “drools” and fills the float bowls right back up). I’ll do what you suggest.
« Last Edit: October 17, 2024, 05:38:01 AM by BenelliSEI »
Online BenelliSEI
« Reply #1541 on: October 17, 2024, 10:32:09 AM »
Sorting some pictures today. This one clearly shows the characteristics of an early (#582) Sandcast engine. Much rougher finish than the later die cast parts…..
Online BenelliSEI
« Reply #1542 on: October 23, 2024, 06:23:50 AM »
Kevin…… Really appreciate your email. Here’s my preferred picture. John D.
« Last Edit: March 08, 2026, 07:22:28 PM by BenelliSEI »
Online BenelliSEI
« Reply #1543 on: October 23, 2024, 01:47:00 PM »
Working on the original air box. Anyone have a set of the bottom screws (2)?
Offline lash
« Reply #1544 on: October 23, 2024, 01:52:07 PM »
 ;D
Online BenelliSEI
« Reply #1545 on: October 23, 2024, 04:55:56 PM »
;D
Don’t suppose you have an “extra set”?
Offline lash
« Reply #1546 on: October 23, 2024, 05:26:05 PM »
I think so,will check in the morning
Online BenelliSEI
« Reply #1547 on: October 24, 2024, 05:51:44 AM »
Great and no rush.
« Reply #1548 on: October 29, 2024, 07:34:22 AM »
Are you keeping it? (the Sandy)
Online BenelliSEI
« Reply #1549 on: October 29, 2024, 01:11:38 PM »
Yep….. This winter I plan on fitting an original air box (after lots of repair) and the 4-4 pipes that came on it. Remarkably they don’t have a single dent. The lower right has a small hole where the head pipe meets the muffler, but I think I can weld in a small patch. It’s so hidden, I doubt it will ever be seen. They should clean up very well. The bike would then be +95% original!
« Last Edit: October 29, 2024, 01:14:37 PM by BenelliSEI »
