« Reply #3 on: April 06, 2023, 01:00:06 AM »
Building a piggy back for electronic ignition. I plan on tapping into the rear brake light for power to my electronic ignition. Any tips on making the plug connector? I plan on using connectors from my old ignition switch.
You can get new connectors from VintageConnections.com.
Are you planning on killing the Ignition by turning off the headlight?
Most use the black power lead at rear brake switch which is on with the Key switch, not the headlight. Correct?
Logged
Stu
My current rides
Prior bikes....
