Author Topic: Power plug in for my electronic ignition  (Read 585 times)
Offline Dreadnought
« on: April 05, 2023, 08:46:45 AM »
Building a piggy back for electronic ignition. I plan on tapping into the rear brake light for power to my electronic ignition. Any tips on making the plug connector? I plan on using connectors from my old ignition switch.
Re: Power plug in for my electronic ignition
« Reply #1 on: April 05, 2023, 09:19:02 AM »
My CB750's have relay for ignition  the black/white wire activate when turning on the switch.
Kill switch will work.
« Reply #2 on: April 05, 2023, 06:19:26 PM »
You can get new connectors from VintageConnections.com.
Are you planning on killing the Ignition by turning off the headlight?
« Reply #3 on: April 06, 2023, 01:00:06 AM »
Most use the black power lead at rear brake switch which is on with the Key switch, not the headlight. Correct?
« Reply #4 on: April 06, 2023, 01:06:05 AM »
This guy shows his pigtail he made up at @ 8 minutes in. With this you can unplug it and put points plate back in if needed
