It's all good, tighten the bolts (and torque to spec, you don't want them coming loose). The clutch is assembled correctly from what I can see.
This clutch design is "upside down" compared to many engine models where the clutch actvates via a rod right through the motor. This one is disengaged by a cam and lever in the clutch cover pushing inward. The clutch outer basket rotates "all the time", driven from the crankshaft and it rotates freely on the transmission shaft. The inner assembly including the bolts, springs, inner hub, etc. are stationary when the clutch is disengaged. The inner hub that engages the teeth on the inside clutch plates (flat metal discs) is splined to the transmission shaft that the whole clutch assembly mounts on.
So when you tighten the bolts and pull the springs tight, that's engaging the clutch. You push the bolt plate in to disengage it, this is basically impossible by hand unless you're superman so it's hard to see what happens when you pull the clutch lever... and of course then you can't see it because the clutch cover is on.
