65Ch; You probably could get away with just one good sized hose from the main tank to the second tank. All you got to do is make sure that the gas will flow down and allow the air in the second tank to escape back into the main tank.
Lordmember; My second tank holds about 1 gallon. You probably can get away with a smaller one or even have the pump on it's side. You just got to make sure the whole pump part that goes into a tank is submerged in gas all the time. I wonder if the gas may get a bit warm in a real small tank?
750essess; The tack drive you are working on..sounds very interesting....is it using an electronic pick-up with magnets or something else? I would be interested in one myself. Thanks for the req'd fuel info.
Aaaaand, I got something that is going to make my tuning a whole lot simpler.....
My youngest son didn't like his "Netbook"....too small...so he gave it to me:
It will fit real nice inside my jacket:
My daughter found a USB cable and programm to hook the "Windows 7" netbook up to the bikes microsquirt. She downloaded all my programs into the little netbook. My daughter also set up the netbook so it keeps working with the lid closed. Got to manually shut it off. Now I can easily datalog as I'm riding in megatune or tunerstudio.
