Author Topic: "INSPIRATION GALLERY "  (Read 2400322 times)
Offline j-conn
  • Federico Fabrizi
Re: "INSPIRATION GALLERY"
« Reply #675 on: January 09, 2009, 05:21:16 AM »
what is the thought behind the 'exhaust bar'? for regidity/looks/gives special powers?
anyone know if that is a sportster seat?
1976 CB550
Member #7772
« Reply #676 on: January 09, 2009, 05:47:36 AM »
The exhaust bar is most likely an equalization tube, to equalize the pulses between the exhausts, adds some effective length to an otherwise short (too short) system. Some schools of thought give "special powers" to equalization type devices. Certainly just being there gives the separate pipes some stability, but i don't think that was the primary reason.
I think they were stock on some sportsters from the factory.
Offline j-conn
  • Federico Fabrizi
« Reply #677 on: January 09, 2009, 05:53:08 AM »
wouldnt there be a risk of... whats it called. scaving? like with the chambers in 2stroke exhausts
i have been thinking that a sportster seat would work well for my 550 cafe project. seen it done anywhere anyone?
1976 CB550
Member #7772
« Reply #678 on: January 09, 2009, 05:58:42 AM »
I guess not. Here's a discussion of the equalization or crossover tube. Seems to beneift Harleys especially. You'll have to scroll down a bit for the answer.
http://en.allexperts.com/q/Motorcycle-Repair-837/1997-Harley-Sportster-Exhaust.htm
« Reply #679 on: January 09, 2009, 06:03:58 AM »
Stock head pipes with balance tube, and Yes, H-D accessory seat on stock fender (cut down).
Seat should be close to fitting Honda frame, might not cover front part as well, loook at one on a bike & measure.
Offline j-conn
  • Federico Fabrizi
« Reply #680 on: January 09, 2009, 06:11:53 AM »
berry berry interesting...
im gonna see what i can do with a sportster seat. the PO had what can only be described as a 'fat guy seat' on my 550.
still intrested
1976 CB550
Member #7772
Offline crazypj
  • I'm brill, me
« Reply #681 on: January 09, 2009, 06:22:41 AM »
 I as used on Triumph twins, Suzuki Katana & Bandit 4 cyl, and loads of other bikes I can't think of a present.  ;)
 It mainly helps mid range torque
 On most bikes ( the ones I've cut exhausts up) there is only a smallish hole in the main pipe (smaller than the cross/balance pipe) so it also has some sound deadening effect (Helmholtz resonator probably?)
PJ
  • Be careful you might get a
« Reply #682 on: January 09, 2009, 08:28:08 AM »
Here's another option for a seat. You might give them a call and see if they know if their seat fits a CB550.
http://www.storzperf.com/index.html
Here's a pic. You might do a little cutting on it for a better fit.
and here's another bike just cause it's that kind of thread.
Offline Flying J
« Reply #683 on: January 09, 2009, 09:36:24 AM »
JAG
What kind of tires are those. does dennis Kirk carry them? I like the fat car tire look but havent found any.
Offline mateo tomas
« Reply #684 on: January 09, 2009, 10:33:21 AM »
That seat looks a lot like the one on the "pro street" 500/550 from july's bike of the month:
http://forums.sohc4.net/index.php?topic=37138.msg385875#msg385875
looks good on that bike IMHO
« Reply #685 on: January 09, 2009, 11:02:10 AM »
i was just gonna say that ... (ya beat me to it )
Offline Really?
« Reply #686 on: January 09, 2009, 01:15:07 PM »
Four Pack is a sweet bike.  Infact, it was my wallpaper for a while.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Shenanigans
  • Right turn?
« Reply #687 on: January 10, 2009, 05:52:17 PM »
I would sell both my kidneys for this bike.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #688 on: January 10, 2009, 05:58:17 PM »
have any info on that?
1974 CB550K
                                  Your 1%er name
Offline Shenanigans
  • Right turn?
« Reply #689 on: January 10, 2009, 06:06:51 PM »
Well the base bike is a ZX10, the rest of it is photoshop.
And if I am going to give both my kidneys for it they better at least fix the front end.
« Reply #690 on: January 11, 2009, 09:24:13 PM »
I don't usually go for this look but this one looks cool.... ;D
Offline bzr
  • I'm not here.
« Reply #691 on: January 11, 2009, 10:08:22 PM »
I don't usually go for that style either, which is why I can't help thinking, "man, how much cooler would that look with NO fender at all?"
1976 Honda CB550F
Offline Shenanigans
  • Right turn?
« Reply #692 on: January 11, 2009, 10:27:10 PM »
Stock is not always a bad thing...
And the rest...
Offline Ecosse
  • Member #4139
« Reply #693 on: January 12, 2009, 12:30:38 AM »
Quote from: link=topic=32693.msg471739#msg471739 date=1231737853
i have to say... i like it!
1974 CB550K
                                  Your 1%er name
Offline Ecosse
  • Member #4139
« Reply #694 on: January 12, 2009, 12:33:31 AM »
love these. and nicely photographed too.
1974 CB550K
                                  Your 1%er name
Offline Joksa
« Reply #695 on: January 12, 2009, 06:17:06 AM »
« Last Edit: January 12, 2009, 06:19:02 AM by Joksa »
Offline Ecosse
  • Member #4139
« Reply #696 on: January 12, 2009, 10:05:50 AM »
ok joksa you can't get away with a drive by like that; give with the details.
1974 CB550K
                                  Your 1%er name
Offline j-conn
  • Federico Fabrizi
« Reply #697 on: January 12, 2009, 10:11:21 AM »
i read about that frame...
u the builder joksa?
1976 CB550
Member #7772
Offline Joksa
« Reply #698 on: January 12, 2009, 10:14:43 AM »
:) I do not know the details, but found the picture from a blog: http://bubblevisor.blogspot.com/
There are more pictures: http://s451.photobucket.com/albums/qq231/lennyway/?action=view&current=Lockheed_Lounge-hellforleather.jpg
Edit: I just found more info. The bike is called "Lockheed Lounge"
http://hellforleathermagazine.com/2008/03/build-your-own-lockheed-lounge.html
http://hellforleathermagazine.com/positions/buildyourown/lounge-layout.html
« Last Edit: January 12, 2009, 10:21:46 AM by Joksa »
Offline j-conn
  • Federico Fabrizi
« Reply #699 on: January 12, 2009, 10:16:52 AM »
this is what id give my 2 kidneys for.
id just dress it alittle differently. or have no dress at all.
http://www.twostrokeshop.com/Aprilia_RS500_2008.htm
1976 CB550
Member #7772
