Author Topic: Newbie here.. showing off my find.. 750K2 1824 miles  (Read 3518 times)
Wolfowner
« on: November 23, 2008, 08:30:37 PM »
Hey Guys...
Letting ya'll see my 1972 CB750K2.. looking to find out a bit more about her..
I havent tried to crank her..   she had always been stored indoors untill me, like a dummy had it tarped and some condensation got to it.  it does turn over via kick start..
last licensed in 1984, houston texas as where I am.. it shows to have 1824 miles
twin disc front
oil cooler
extended rear wheel mount..  for lack of a better name
I am thinking the motor may be built..because of the oil cooler..  maybe I am way off..
She really is sweet.. any input would be appreciated... the seller was an auction.. she was taken for nonpayment of rent !!!   poor chap that lost her was probably sick..  :-\
So I have no absolute prior knowledge of her
Adding a few more pics .. sorry I didnt get them sooner..
 Her left side..
Carbs
speedo
discs and some jug
Thanks
Wolfowner out
« Last Edit: November 25, 2008, 01:11:46 PM by Wolfowner »
Re: Newbie here.. showing off my find.. 750K2 1824 miles
« Reply #1 on: November 23, 2008, 08:40:23 PM »
Extended swingarm.. maybe RC Eng
Tracy glass body
Carbs look like might be different, cant see real clear.
 Chances are good it may be hopped up. Before you try to adjust valves, get familiar with the process, then measure & record clearances.. just in case it is not a stock cam..
 Nice bike, BTW..  :o
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: November 23, 2008, 09:00:24 PM »
Definitely a Tracy body.......A unique style from years ago, love it or hate it ;D
Looks like some fiberglass mods have been made to the rear end of yours.
Click here for my Tracy build for comparisons.
http://forums.sohc4.net/index.php?topic=17831.0
Offline mrbreeze
  • Not your average
« Reply #3 on: November 23, 2008, 09:42:23 PM »
Very sweet bike!!!! I have never seen an exhaust like that. The collector sweeps way back.Any clue where that came from??
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #4 on: November 23, 2008, 10:33:37 PM »
Nice looking bike seaweb !
That's the crappy before pic ;D
and yes, you will need to remove the body kit to get at the battery.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #5 on: November 23, 2008, 10:51:58 PM »
There should be a bolt on the rear, up behind the seat under the rear wheel to undo. It bolts onto the seat and keeps the complete kit in place.  Once that is off, you will get enough play to pull the seat. That's how my body kit is mounted. One bolt 8)
If you want to continue the body removal  lift the rear body kit a bit and slide the body off the gas tank rubber mounts slowly while wiggling the body kit side to side pulling towards the rear.
You can access the battery on mine without completely removing the body. "my bad on my text earlier" ::)
Offline Shenanigans
  • Right turn?
« Reply #6 on: November 24, 2008, 12:09:23 AM »
Thanks.. I have no idea where the exhaust is from..
My Plans are to let her sell on Ebay, probably no reserve  ..  I do need to fire her up and detail her first
you guys are the first anybody has seen her in 24 years   :)
You know someone here might want it too  ;)
Offline Geeto67
  • A grumpy
« Reply #7 on: November 24, 2008, 07:48:10 AM »
Definatly an RC engineering swingarm. It is almost identical to the one hanging on my wall, except mine is chrome. Those swingarms are heavy but with purpose, they are designed so a drag racer can tune his wheelbase to the track conditions.  Someone set that rear up to run drags, I have that same dunlop on the back of a cb750 drag rim (same gold anaodized rim also).
some tracy bodies have two bolts, one at the rear and one at the front. becareful of that when trying to remove it since it is old brittle fiberglass and once you crack it then the body is junk.
Maintenance Matters Most
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #8 on: November 24, 2008, 10:54:14 AM »
I don't know about originality but this bike makes my britches tight.
1974 CB550K
                                  Your 1%er name
Offline Geeto67
  • A grumpy
« Reply #9 on: November 24, 2008, 11:25:55 AM »
Thanks for the info so far..  I have no idea what an RC engine is..  or RC swingarm..  what is RC?
Sorry for my Ignorance..
I have to leave now, but will be back later.. maybe get a few more pictures closer up.. it's back in the building now, but the flash works fine on the camera..
I am having a bad feeling that maybe she is not going to be wanted as much as if it were in original condition..  how many people really want a souped up engine?.. on the positive side..  how many 72's are there with an origianal 1824 miles on it..  ( if thats even correct)
RC Engineering was a company that made CB750 parts back in the 1970's-1980's. The RC stands for Russ Collins who was the head of the company and an accomplished cb750 drag racer. While he did build complete bikes as well, he sold a lot of parts that ended up in hot rodded and racing CBs. He had everything from big bore kits to chassis stuff. Russ is still around and heads up a company that does electronic fuel injection for cars.
I understand that you are worried about value because this isn't a bike to you it is a pay day, but there are plenty of people who want hot rodded cb stuff out there. Look at all the big money spent on crappy built cafe racers (some of them sell for more than original bikes would), what you have is an original period correct cafe racer and I think that those in the know will pay for the quality of parts alone.
Offline gene03079
« Reply #10 on: November 24, 2008, 02:55:23 PM »
If you shoot a price out, I my want it. I could use another project.
78 CB550 74 CB550  71 SL175  08 Harley Ultra
Honda CL 175 racer  1977 Honda MT125R race bike 65 CB160  69 SL350
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #11 on: November 24, 2008, 07:19:21 PM »
Gene, I appreciate you asking.. I believe my best shot is letting ebay fight over it.. what ever it brings.. it brings..
Yes, but if you have a number you would be happy with.........lay it out here. We won't let you get screwed on a deal either I assure you 8)  We have a history here 8)
The motor has value in a bike, the kit is "messed with" but someone could do a real nice job with it I'm sure.
Go high and see where it goes................... :)
Good luck to all interested parties either here or on Evil Bay/ ???
I have my Own Tracy ;D ;D ;D ;D ;D
Offline KB02
« Reply #12 on: November 25, 2008, 05:21:49 AM »
Just a suggestion: Before offering it up to ebay, once you have a price in mind, list it for sale here. If you get no bites, then offer it up to the ebay bidders.
Sweet looking ride, man.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #13 on: December 02, 2008, 08:23:14 PM »
Have you seen the added "Final Value Fees" eBay tacks on now?
Un-freakin-real!
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline DarkRider
« Reply #14 on: December 03, 2008, 03:17:50 AM »
I agree with the others. Post it up in the for sale section on this site first...Chances are you will probably have it sold for a fair price to both you and the seller pretty fast. Im just throwing a number out here but i would have to guess it could go for somewhere between $1500 and $5000...either between or even over the high side. But then again im also looking at what bikes like Vic worlds bikes go for as well as carpys as examples of both stock and cafe racers.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Artfrombama
  • CB750 K2
Halfassed machinist
CB750E2441103
Offline Ecosse
  • Member #4139
« Reply #16 on: December 03, 2008, 10:32:29 AM »
final value fees????   WTF
http://pages.ebay.com/help/sell/motorfees.html
http://pages.ebay.com/help/sell/fees.html
Ooooh, that's why they call it FEE bay! Wow.
Like they're not already making money hand over fist, the greedy buggers.  :o >:(
1974 CB550K
                                  Your 1%er name
