Author Topic: Custom Frame  (Read 11756 times)
Offline Matt Hubbell
Custom Frame
« on: December 15, 2008, 09:49:25 AM »
Is there any interest in custom frames here. Maybe somthing with a hidden oil tank or adaptable to both standard forks and mondern forks, rear set mounts.  What would you want in a frame if you could build it or buy it?
Offline KB02
Re: Custom Frame
« Reply #1 on: December 15, 2008, 10:01:01 AM »
1.) Which model SOHC? 350, 400, 500, 550, 650, 750? (or any/all of the above?)
2.) Cafe, Chopper or just a new standard frame?
« Last Edit: December 15, 2008, 10:05:24 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Re: Custom Frame
« Reply #2 on: December 15, 2008, 10:06:02 AM »
Cafe style seems to be a common theam here.
Offline KB02
Re: Custom Frame
« Reply #3 on: December 15, 2008, 10:09:52 AM »
As for a Cafe frame, here is what I think would be nice:
 - Mono-Shock rear suspention
 - Lighter frame (tresile style? Worked for Martin and Ducati)
 - Body work (including tank) either to come with, or be easily adapted from another bike.
 -  - A custom frame is great, but finding a tank that you "Hope" will fit is a pain in the butt.
 -  - Design the frame to take a stock tank?
 - for a 750 either A.) Make it so that engine work can be done with Frame in Chassis, or B.) Make the engine EASILY removeable.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Re: Custom Frame
« Reply #4 on: December 15, 2008, 10:38:09 AM »
Lets make a list and I can get a price. Please add to ideas
A. Tresile Frame
B. interchangeable forks
c. Mono or standard swing arm
d. ?
E. ?
Offline cafe2be
Re: Custom Frame
« Reply #5 on: December 15, 2008, 10:43:34 AM »
oil running through frame.
Rear set mounts
Offline cafe2be
Re: Custom Frame
« Reply #6 on: December 15, 2008, 10:44:15 AM »
Wider rear tire and how much would a frame be?
Re: Custom Frame
« Reply #7 on: December 15, 2008, 11:10:55 AM »
The price will depend on the number of orders and the amount of detail. Once we have a list, I will work with my builder to get the design and a price.
Offline BlindJoe
Re: Custom Frame
« Reply #8 on: December 15, 2008, 11:37:15 AM »
chrome-moly
crustyxpunk
Re: Custom Frame
« Reply #9 on: December 15, 2008, 12:43:02 PM »
+1 on the easy access to the engine and also a lighter frame would be nice as long as it is kept rigid and strong.
Offline UnCrash
  • Pass
    • My Blog
Re: Custom Frame
« Reply #10 on: December 15, 2008, 01:02:04 PM »
Trelis frame
Integrated oil tank with dry compartment area for cleaned up electric system / fuses
Bolt on CBR 600 swingarm and triple / front end
Re: Custom Frame
« Reply #11 on: December 15, 2008, 11:19:40 PM »
Soft tail with 240 to 300 rear tire and Harley front end with good numbers stamped on it and papers
Offline KB02
Re: Custom Frame
« Reply #12 on: December 16, 2008, 04:49:28 AM »
;D ;D ;D ;D ;D ;D ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Soos
Re: Custom Frame
« Reply #13 on: December 16, 2008, 06:18:54 AM »
That and fit a cb500/550/650 engine! (& STD cb650 neck)
(doesn't the 500 use the same motor mount points as the 550/650 motors???)
Would like to see a mono shock as well.
However, the fatty tire listed up there, mabey a separate rear swingarms could be offered.
I think about a 140 or 150 rear is nice.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
Re: Custom Frame
« Reply #14 on: December 16, 2008, 06:31:58 AM »
chrome-moly
Titanium for those who are crazy and a BIG wallet...
For the rest of us, Aluminum mabey?
l8r
-=≡ Soos ≡=-
Offline Soos
Re: Custom Frame
« Reply #15 on: December 16, 2008, 06:33:48 AM »
Trelis frame
I've got limited experience with different frames, do you have a pic you could share of a good example?
Sounds interesting though.
l8r
-=≡ Soos ≡=-
Re: Custom Frame
« Reply #16 on: December 16, 2008, 07:48:32 AM »
If you look at this web site it shows many examples, all made back in the day, and all in europe.
www.satanicmechanic.org
Offline KB02
Re: Custom Frame
« Reply #17 on: December 16, 2008, 09:40:22 AM »
Trelis frame
l8r
Check out this Martin Framed F2. Good example of a Trelis frame (or just about any modern Day Ducati).
http://forums.sohc4.net/index.php?topic=40457.0
***sorry, just edited to add the link***
« Last Edit: December 17, 2008, 04:48:43 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline olds-cool
  • Choppa Guy
  • Choppa
Re: Custom Frame
« Reply #18 on: December 16, 2008, 11:31:26 AM »
I would love to see a nice dropseat chopper frame for the 500/550s.  One for a 750 would be ok too.  Something with a little rake to it but not overly wild.  Think of a prostreet type of frame then drop the seat.
Offline Maxacceleration
Re: Custom Frame
« Reply #19 on: December 16, 2008, 12:34:59 PM »
Making everyone happy with a custom frame is a tough job.
Change too much and nothing stock fits.
The backbone tail section should accept stock and aftermarket tanks and tail sections (sohc specific), for simplicity.
But in a cafe I would see a frame with twin shocks still, longer swingarm, boxed, rearset mounts, mounts/tabs for buddy pegs or exhaust hangers, oil cooler mount tabs, adjustable steering lock and maybe eccentric headstock for steering angle changes including triple clamps which provide more width for a wider wheel setup.
Mounts or tabs could be just threaded bosses in the frame so they wouldn't be so unsightly if not used.
A trellis frame will make for a wide frame. Mono shock will make for a long bike as the motor/tranny is long and not compact as todays motors are. An overhead monoshock could shorten things up a bit, but there wouldn't be room for both the airbox/electrics and shock.
A stock styled frame, braced where they are braced now (for roadracing) with flush mounts/tabs would be the most cost effective.
Bimota kit style comes to mind... Parts or roller.
Not cheap in todays market!
Look at TTR stuff. Beautiful, but not cheap.
Olden is Golden
CR550F RD400 KZ550 KH500
Re: Custom Frame
« Reply #20 on: December 16, 2008, 01:14:34 PM »
(1) lighter, trellis frame;
(2) accept stock tank;
(3) mount for rear sets;
(4) make easier to remove engine (maybe bolt engine to bottom of frame as a partially-stressed member a la Ducati)
Re: Custom Frame
« Reply #21 on: December 17, 2008, 08:23:02 AM »
I think we have a good start here, and I will work to get us a price. What would you be willing to pay for something like this?
(5 )interchangable fork , so you can use stock forks or change to modern forks.
Offline KB02
Re: Custom Frame
« Reply #22 on: December 17, 2008, 08:55:39 AM »
I'd love to see a price under $500, but chopper frames go for around $800 or so.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Soos
Re: Custom Frame
« Reply #23 on: December 17, 2008, 09:09:58 AM »
Hey Vonblonde, what motors are you thinking of having these frames accommodate?
l8r
-=≡ Soos ≡=-
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Custom Frame
« Reply #24 on: December 17, 2008, 09:42:17 AM »
try this posting too, I put a link to Rick Denoon's frame on there.
http://forums.sohc4.net/index.php?topic=42018.msg434141#msg434141
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
