Don't forget to check the tiny screens mounted to the float needle valves. They can get clogged too.
That is where I'm at now. I took out the petcock, cleaned the rust colored gunk off the filter bag, broke the screw off when dissasembling, paid $21 to the machine shop to get broken screw out and tap the threads. I reinstalled it, put in the gas, started it and went for a test run.
NOW it bogs like crazy! I can't get over 3k rpms without it sputtering and bucking like a mule. The bike shut off on me about 1/4 mile away and we had to push it back.
I'm looking throught my lousy clymers manual for the float needle valves locations or diagarams. No luck, if anyone has any pics, or diagrams, It would be greatly appreciated.
Where are they located before I open this up? Please bear with the motorcycle/carb noobie. GRRRR... :-D
Alright, as I said before remove float bowl, that's the "cover" on the very bottom of the carb with that big clip around it. Just gently pry the clip back until it clears the bowl and carefully lower the bowl. The float will be right there in front of you.
I don't really understand why you are complaining about the pictures in the Clymer book.
My Clymers has a pretty good drawing in the section titled CB750 K1-K6 and F Removal/Disassembly in the Fuel System Chapter. Float Item #16, pivot pin un-numbered, #13 & 14 identified as float valve set (Honda Terminology) are actually the fuel needle and seat. There is a small screen (not shown here) attached to the top of the seat on some models.
After you have remover the fuel bowl, remove the pivot pin -VERY CAREFULLY- SO AS NOT TO BREAK THE "LEGS" which it passes through. I use a tiny pin punch (drift pin or whatever you want to call it) and a very light weight hammer of even a small pair of pliers to tap the punch. Some people use very small nails as a drift. Remember to tap very gently, that's all it should take to move the pin. Any hard tap can break the carb. Use spray carb cleaner or penetrating oil to loosen the pin. When the pin is removed the float will be free and the needle will fall out. Do not attempt to adjust anything until you check carefully and determine that this is really needed. Floats do not usually get out of adjustment all by themselves. Just clean and check for now.
Check the little plunger in the bottom of the needle to be sure that it moves freely, it is spring loaded.
If I remember correctly the seat is a hex brass style shich screws out . I use small 6 point sockets.
Check the seat and the screen located above.
ANY QUESTIONS???
