Author Topic: Will this rectifier work? It will!! (Limited supply available!)  (Read 20537 times)
Offline Zaipai
    • My Home page
Re: Will this rectifier work? It will!! (Limited supply available!)
« Reply #25 on: August 23, 2009, 07:43:54 PM »
Darn... Day late, dollar short. Any info on the supplier by any chance?
Yes, any info on the supplier? I will be looking for one of these soon or some thing like it anyway.
Its my Avatar..
75 CB550F  |
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #26 on: August 25, 2009, 11:31:45 AM »
Everyone who paid, they are on their way!
Bryan, got your payment this morning and sent it out. Thanks!
You two last posters have PM's
1974 CB550
Forever West
Offline Quorthon
  • Pace till death
« Reply #27 on: August 25, 2009, 12:40:37 PM »
Any chance of a writeup/faq with pictures of installing one of these guys?
1972 cb500/4
Offline HedNut
  • Underwater Basket Weaving
« Reply #28 on: August 25, 2009, 12:52:04 PM »
Darn! I missed this....GOOD FIND MY MAN!!!....would be fantastical if you could get another batch... I'm sure they'd go quick again!  I could use one for sure.
Cheers!
Offline Pinhead
  • 1979 CB652-ST
« Reply #29 on: August 25, 2009, 01:38:07 PM »
I've got a wiring diagram in the linked topic in my sig. :)
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline mystic_1
  • 1970 CB750K
« Reply #30 on: August 25, 2009, 01:54:39 PM »
Aye, but this unit us a three-phase rectifier so your diagram isn't quite valid as yours uses two two-phase rectifiers.
Same principal though.
mystic_1
- John Augustus Shedd
Offline Pinhead
  • 1979 CB652-ST
« Reply #31 on: August 25, 2009, 03:06:54 PM »
The "~" symbols go to the stator wires, the "+" symbol goes to the positive battery terminal, and the "-" symbol goes to the negative battery terminal.
Doug
:D
  • The Stumped
« Reply #32 on: August 25, 2009, 04:07:57 PM »
PM'ed the two guys above, haven't heard back.
He sent extra as a thank you for the large order! I have two, the first two guys to PM me get them.
1974 CB550
Forever West
Offline mystic_1
  • 1970 CB750K
« Reply #33 on: August 25, 2009, 04:30:07 PM »
I plan on taking the harness and connector off of an old stock rectifier and soldering it right up to this puppy, then adding a nice custom heatsink/mounting bracket to make it a plug-and-play replacement.
Lots of old CBs used the same or similar rectifiers.
mystic_1
  • The Stumped
« Reply #34 on: August 29, 2009, 12:54:33 AM »
You fellas that have got them let us know, definitely want to see them mounted up.
I have a maybe on one, with 1 more still available!! PM me for info.
1974 CB550
Forever West
Offline mystic_1
  • 1970 CB750K
« Reply #35 on: August 29, 2009, 05:37:19 AM »
Mine arrived Thursday.  Won't be mounting it for a little while yet but will take pics when I do.
Rectifier seems perfect for this application, thanks!
mystic_1
  • The Stumped
« Reply #36 on: August 30, 2009, 09:41:51 PM »
He sent me a modified schematic (I guess?). Not sure how this will effect wiring. Doesn't look critical. Any ideas what this is?
1974 CB550
Forever West
Offline GammaFlat
« Reply #37 on: August 31, 2009, 06:52:16 AM »
Funny... it looks like something is erased in the first drawing and then a redundant diode added in the second.
K6
85 Goldwing
Offline mystic_1
  • 1970 CB750K
« Reply #38 on: August 31, 2009, 08:01:55 AM »
Exactly what I was thinking.
mystic_1
  • The Stumped
« Reply #39 on: August 31, 2009, 06:39:58 PM »
ONE left! PM me to take it away!
Thanks guys!
1974 CB550
Forever West
Offline HedNut
« Reply #40 on: September 01, 2009, 09:43:03 AM »
I sent you the money paypal!... Hopefully I'm not too late.
Cheers!
B
Offline mark
« Reply #41 on: September 01, 2009, 02:18:13 PM »
wow. I hope this thing doesn't make the bike lean too much. lemme see if there is room for a brick behind the side cover.
 :D
maybe I'll just carve the big black heatsink to the shape of a side cover.
 :D :D
okay seriously....
A chunk cut from the corner of the big black heat sink('90 T-Bird Premium Sound amp) would be plenty, and will likely shoehorn into the stock location. I'll apply a generous smear of thermal compound when mounting the bridge.
I think I will run the + side through a circuit breaker(call it a 30A, what the heck) to the battery side of the starter solenoid. The - side will likely run directly to a frame ground. This will eliminate several troublesome connectors, as well as taking a large part of the load away from the already stressed green harness wire(ground).
As for the yellow(stator) wires, I will probably take the terminals out of the engine harness connector and put them in a separate plug. A short set of wires from there to the bridge's ~ terminals completes the circuit and eliminates another connector set and the power panel wiring.
After the wires are screwed on(where are those mil-spec ring terminals?) a thick coat of 'liquid tape' should keep the weather out.
 8)
B.O.X.N.I.F.E., thanks for letting us in on the deal - looks like good parts.
Happy trails.
F you mark...... F you.
Offline CrescentSon
« Reply #42 on: September 02, 2009, 05:57:44 PM »
Got mine today.  Thanks for the prompt return man, maybe I can get my beast off the ground now.
I have to say this is a really sturdy unit.
Thanks again brother.   ;D ;D ;D
-Daniel
  • The Stumped
« Reply #43 on: September 03, 2009, 07:18:14 PM »
All gone! thanks fellas
1974 CB550
Forever West
Offline XN
« Reply #44 on: September 04, 2009, 02:45:29 AM »
Any more on the way? I'm in need... I fried my whole harness  :o
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
Offline HedNut
« Reply #45 on: September 04, 2009, 06:19:15 AM »
You have a K8 too!?...they eat harnesses like candy...apparently... :-\  (I picked up mine with a pre-cooked harness)
Offline kenolds
  • Before the Dismantle
« Reply #46 on: September 04, 2009, 07:29:38 AM »
Has anyone installed one of these rectifiers and confirmed that they do indeed work?
They look great, just asking.
Kenolds
Parts, Parts, Everywhere - But Not A Bike To Ride.
  • The Stumped
« Reply #47 on: September 08, 2009, 12:10:17 PM »
Can everyone that received theirs let me know if I mixed up an order? Bryanj bought 3 units and only received 1. Did anyone here who paid for one get 3 instead?
1974 CB550
Forever West
Offline HedNut
« Reply #48 on: September 09, 2009, 06:48:11 AM »
Still waiting on mine to come in...could be me?...I'll let you know when it does...or they do.
  • The Stumped
« Reply #49 on: September 09, 2009, 12:03:42 PM »
Nope, definetly not you, yours was the last to go out. Should be there soon, may be taking a little while because of the border crossing.
It's looking like his package was damaged in transit! Darn postal workers.
1974 CB550
Forever West
