Author Topic: How to polish valve covers and engine parts like chrome finish that lasts?  (Read 4062 times)
Aerobhoy
 anyone give advice,products to use on my valve covers and aluminum parts i plan on trying to get them to a chrome like finish similar to the services offered by carpy etc. thanx in advance
jimmy O 8)
Offline Johnie
Yes, there are quite a few posts in the FAQ about using a buffer with red, green and white rouge.  You may want to start your search there. It is tedious and time consuming, but well worth the effort.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline RRRToolSolutions
  • I love old Japanese bikes!
It can be done -
1) Clean all grease and grime away
2) Use oven cleaner to remove old clear coat
3) Wet sand 240, 400, 600, 1000, 2000 until smooth
4) Use 1,700 RPM buffer with red/brown cutting compound
5) Clean part and remove all compound
6) Use white compound and flannel buff wheel to achieve mirror results - NEVER contaminate your white/flannel buff. Use only after cleaning all of the brown off the parts.
Buffing time is less than 2 minutes if you get the right tools and get the parts up to working temperature. The block compounds are made with animal fats that are desined to melt at 140 degrees F. You'll need to wear cotton gloves to hold the parts - that way you can feel when the temps are reached. When it's right, the part won't drag and there will not be any black on the part. If the part is black, it means you don't have enough heat. Trust me, I learned the hard way how to buff parts - This set-up is about $350 with the stand, but I paid for it with just 1 bike and it's mine for as many as I want to do. Tools are always a good investment if you enjoy this hobby.
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline The_Crippler
  • Work in progress.
This post is not a bookmark for later.   ;)
Offline w1sa
That's a really nice finish, Gordon.
I just went and had another hard look at some I did a while ago, and you've encouraged me to have another go for even better results......... :)
 It's messy, dirty work. Be prepared. ::) ;)
Offline the technological J
  • deliciouso!
it will last if u hit it with mothers polish every once in a while
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline oldfett
I've heard that using a sealer like Zoop is the way to go if you don't want to touch it for a year or so to touch it up. Is this correct or not worth it?
  • Be careful you might get a
What's the model # for that Jet buffer?
Offline blindguy76550
  • da blindguy
i wet sanded some of my parts and then just went over them with "Never Dull" (comes in a silver can). they arent as shinny as the post before me but good enough for a poor boy like me, lol.
if its got tits or wheels then its gonna be a pain in the ass at times.
Offline Skunkmiester
Re: How to polish valve covers and engine parts like chrome finish that lasts?
« Reply #10 on: October 24, 2009, 02:31:16 AM »
Which Mothers polish do you use? There is a fair bit of choice on their site and I will need a few gallons for my fuel tank alone.
1973 CB 750 Cafe Racer
1992 (original) Fireblade
Offline mazingerzeca
« Reply #11 on: October 24, 2009, 03:48:35 AM »
I used zoopseal after polishing on my cb750 two years ago. The shine still lasts, and I live in a very wet area.
Offline HawaiiMike
    • Hawaii realtor
« Reply #12 on: October 24, 2009, 10:05:20 AM »
Wow!  That motor looks cherry!
« Reply #13 on: October 24, 2009, 10:08:17 AM »
I just use the "mag and wheel polish" on my stuff after all the sanding and buffing.
« Reply #14 on: October 24, 2009, 05:56:10 PM »
Green Ape works great for a finish/repolish product but I have only been able to get it from a guy in Chicago we race with. If you run across any get it.
