Author Topic: How many CCs does over sized pistons add?  (Read 6651 times)
Offline Flying J
« on: October 29, 2009, 06:51:12 PM »
Im going to do a rebuild to my 550 and was debating on putting in 1.00 oversized rings and pistons. How do i calculate how many CCs that will ad?
Re: How many CCs does over sized pistons add?
« Reply #1 on: October 29, 2009, 06:58:01 PM »
It will go up from 544.087cc to 562.847cc, simple :D :D :D
Sam. ;)
« Last Edit: October 29, 2009, 07:27:10 PM by SamCB750A »
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: October 29, 2009, 07:06:40 PM »
:P
Original bore and stroke
58.5 x 50.6 mm
new bore and stroke
59.5 x 50.6
so, 3.14*(29.75^2) * 50.6 (pi r squared x stroke)
= 141 ish
*4 (4 cylinders) = 563ish cc's.
(sorry, just wante dhim to be able to figure it out on his own, Sam :P )
Don't forget to round off randomly and use "ish's" a lot to show people you really know what you are talking about! That's how I do it!
Fuzzy math = win
No.
Offline mick7504
« Reply #3 on: October 29, 2009, 07:35:54 PM »
Here's a crash course in maths!!
I'll try and keep this uncomplicated.
Basically you need to determine the volume of each cylinder. (Displacement = Bore x Stroke)
I'll use the standard 750 Honda measurements for this as an example - (Actually 736cc)
Bore = 61mm
Stroke = 63mm
Bore diameter divided by 2 = radius                                                 eg. 61 divided by 2 = 30.5 (radius)
Multiply the radius by the radius                                                     eg. 30.5 x 30.5 = 930.25 (radius squared)
Multiply radius squared figure (930.25) by the stroke.                         eg. 930.25 x 63 = 58605.75
Multiply 58605.75 by 3.14 (pye)                                                      eg. 58605.75 x 3.14 = 184022.06
Multiply 184022.06 by no. of cylinders (4)                                         eg. 184022.06 x 4 = 736088.24
        736cc
Pye (3.14) is just a mathematical figure used to calculate this stuff.
Hope this helps
If I was you
I'd be worried about me.
Offline mick7504
« Reply #4 on: October 29, 2009, 07:37:14 PM »
:P
58.5 x 50.6 mm
new bore and stroke
59.5 x 50.6
= 141 ish
Fuzzy math = win
Sorry mate you beat me to it.  ;D
If I was you
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #5 on: October 29, 2009, 07:55:25 PM »
Offline Flying J
« Reply #6 on: October 29, 2009, 08:00:59 PM »
Thanks guy, for sorting me out on that. I appreciate you giving me the "fishing pole" and not just handing me a fish. I guess 20 CCs for $250 is not that bad. I may do it just to know i have a fresh set of pistons and cylinder walls.
Offline mick7504
If I was you
Offline Steve F
Offline mick7504
« Reply #9 on: October 30, 2009, 03:36:39 AM »
Pythagoras was a Greek philosopher who made important developments in mathematics, astronomy, and the theory of music.
The theorem now known as Pythagoras's theorem was known to the Babylonians 1000 years earlier but he may have been the first to prove it although he didn't know a thing about SOHC 750's so that means that we've got one on him!!!
 ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
If I was you
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: October 30, 2009, 05:27:34 AM »
pi r squared
Pi r not squared, Pi r round.  Cakes r squared!
sorry, had to be said  ;) ;D
mystic_1
- John Augustus Shedd
Offline Flying J
« Reply #11 on: October 30, 2009, 07:55:11 AM »
Now that i have all my baking options taken care of, is it worth the extra money to do a 1.00 bore? Will it make much of a differance compared to fresh stock rings?
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: October 30, 2009, 08:22:32 AM »
Sam. ;)
You'd be gaining 18.76cc, which is about a 3% increase over stock.  Unless you did other mods I don't think you'll notice it.
mystic_1
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #13 on: October 30, 2009, 08:35:18 AM »
The biggest thing you'll notice is because of the fresh rings and "fresh" cilinders. A good hone and a new set of rings will give you a similar "seat of the pants" gain. Unless of course you need to bore it out...I wouldn't unless you have to, that way if you DO have to later on because of some damage you have room left to actually bore it out.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
« Reply #14 on: October 30, 2009, 09:34:03 AM »
Weigh the price of bigbore kits versus the pistons you were thinking of.. unless the 1.0s are dirt cheap it aint worth it..
« Reply #15 on: October 30, 2009, 09:41:12 AM »
I'm not so good at math, pretty good at Google.   :D
http://www.nightrider.com/biketech/calc_displacement.htm
« Reply #16 on: October 30, 2009, 09:43:32 AM »
pi r squared
mystic_1
Or differentially...
C  M  puppies?
M  R  not puppies.
M  R  puppies
C  M  P?
Offline Flying J
« Reply #17 on: October 30, 2009, 09:50:32 AM »
the cylinders are the last thing im trying to sort out. I already have ported a spare head and intakes as well as have a 650 cam ready to drop in. All of which should give me some HP gains. Will that light port job and a 650 cam be enough to take advantage of a 1.00 over. The differance in price from stock rings to bigger pistons and rings is about $120.
Offline lone*X
« Reply #18 on: October 30, 2009, 01:57:47 PM »
Just curious, seems like a small gain when you factor in that you also will need to pay to get the cylinders line bored to be able to install the oversize pistons.  Are the cylinders scoured?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Flying J
« Reply #19 on: October 30, 2009, 04:26:02 PM »
Haven't pulled the engine apart yet. I believe Hondaman said just having the bore re aligned will increase HP. The low budget route is just swapping the ported head and gasket with 650 cam. But i want to weigh my options while i have it apart. I hate to go low budget and then have the lower gasket leak on me or waste the ported head and cam on a engien that will not benefit from it that much. Ill will check my compression before as well.
« Last Edit: October 30, 2009, 04:28:40 PM by ffjmoore »
Offline the technological J
  • deliciouso!
« Reply #20 on: October 31, 2009, 12:35:21 PM »
for the sake of discussion whats the biggest bore u can go on a 550? what size pistons and rings would need to be bought?
94 ST1100..Gone
72 750 K2 Stay tuned!
