Author Topic: monoshock 750  (Read 55791 times)
Offline sander
Re: monoshock 750
« Reply #25 on: November 11, 2009, 02:00:09 PM »
Cool!  Looking good my friend.  Might as well add some gussets and one of Gordon's (I think) frame mods while you're at it.  Almost forgot to ask, is that a 16 or 17 inch front wheel?
Thanks! It's a 16 inch front wheel.
Offline Alan F.
Re: monoshock 750
« Reply #26 on: November 12, 2009, 05:10:47 AM »
Looking good Sander.
-Alan
Offline sander
Re: monoshock 750
« Reply #27 on: November 25, 2009, 02:29:44 AM »
Oke i finally got some work done yesterday... I've made some brackets to mount the rearsets. Unfortunately my migwelder broke down so i had to do some stickwelding... great fun  ;D
As you can see the forks need to be shortened by an inch or so.
Sander
Offline J.Webster Designs
  • www.JWebsterDesigns.com
Re: monoshock 750
« Reply #28 on: November 25, 2009, 04:00:51 AM »
what is the overall length of that swing arm, Center of the pivot bolt to Center of the adjustment slots?
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline cdoggy81
Re: monoshock 750
« Reply #29 on: November 25, 2009, 06:37:29 AM »
Sander, very cool bike & ideas! I will be following this one!
(  midnight08, I should have known you would be too :)  )
Offline sander
Re: monoshock 750
« Reply #30 on: November 25, 2009, 09:04:52 AM »
The bike is at my parents place... next time i'm there i will measure it for you. Probably next week.
Offline sander
Re: monoshock 750
« Reply #31 on: December 02, 2009, 02:26:14 AM »
It's 52cm center to center... so 20,5 inch
Offline HedNut
  • Underwater Basket Weaving
Re: monoshock 750
« Reply #32 on: December 02, 2009, 04:47:11 AM »
NICE!! Mono-rear...that's bad-ass
Offline sander
Re: monoshock 750
« Reply #33 on: May 29, 2010, 04:11:46 AM »
Hi there!
It's been a while since i've done something on my bike. We bought a new house and had to do some extensive rebuilding to it...
Anyways, here are the pics...
I have mounted the engine and lined everything up to see how much offset i need on the front sprocket to clear the 180 tire. A nice 520 chain 17 tooth 9mm offset sprocket is on it's way! Right now i'm rebuilding the brake calipers and mastercylinder for a save ride.
By the way, the suspension has just the right sag with the weight of the engine included.
Sander
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
Re: monoshock 750
« Reply #34 on: May 29, 2010, 05:46:34 AM »
Coming along nicely. What's that black bike you've got hiding in the background?  ;)
Offline sander
Re: monoshock 750
« Reply #35 on: May 29, 2010, 10:10:04 AM »
Thanks! That's my previous project, a Honda VT700 Shadow. I cut out the original backbone to fit a sporty tank, home made exhaust and 2 in 1 carb manifold, suicide clutch, jockeyshift, etc...
Sander
Offline Alan F.
Re: monoshock 750
« Reply #36 on: May 30, 2010, 02:31:17 PM »
This is a very inspiring bike, thanks for the updates. I can't wait for the next update when your chain and sprockets have arrived.
-Alan F.
Re: monoshock 750
« Reply #37 on: May 30, 2010, 03:30:00 PM »
Curious to see how this bike handles, that rear arm looks to be around 4 inches {100mm} longer than standard....
Offline sander
Re: monoshock 750
« Reply #38 on: June 01, 2010, 12:35:38 PM »
Oh I can't wait to see how it handles! i don't know the stock length of the stock swingarm but this one is 20,5 inch (52cm).
Sander
Offline Alan F.
Re: monoshock 750
« Reply #39 on: June 03, 2010, 04:33:32 PM »
I'm not sure but that doesn't sound much longer, maybe a couple inches at most.
There's a thread around somewhere with pics of the various 750 swingarms with measurements.
Re: monoshock 750
« Reply #40 on: June 03, 2010, 04:59:12 PM »
Alan, have a look at a standard bike and look at the gap between the front of the rear wheel and the rear frame downtube, on this bike the gap looks to be around 4 inches bigger than stock.  Just an observation.
traveler
Re: monoshock 750
« Reply #41 on: June 03, 2010, 05:31:49 PM »
You should think about painting that swingarm black....it is out of proportion with the frame.  It makes the frame look puny.
~Joe
Offline Pinhead
  • 1979 CB652-ST
Re: monoshock 750
« Reply #42 on: June 03, 2010, 06:50:30 PM »
Very slick looking!
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline void909
Re: monoshock 750
« Reply #43 on: June 03, 2010, 08:25:34 PM »
very cool!!!
knock with no answer
Offline sander
Re: monoshock 750
« Reply #44 on: June 09, 2010, 06:27:41 AM »
Brakes are ready...
I'm almost done with the wiring, only thing left is the dyna ignition and the taillight. The seat is now black. I also installed the tacho from my shadow on the cb. It's pulse driven and looks a lot better than the original one. I was looking at some koso units, but they are way to expensive! Maybe later...
Offline jaguar
Re: monoshock 750
« Reply #45 on: June 09, 2010, 06:44:11 AM »
what pistons are those?
30 or 32 mm?
Offline sander
Re: monoshock 750
« Reply #46 on: June 09, 2010, 07:47:02 AM »
30mm pistons
Offline jaguar
Re: monoshock 750
« Reply #47 on: June 09, 2010, 02:26:43 PM »
dont look like oem pistons
Offline Tintop
Re: monoshock 750
« Reply #48 on: June 09, 2010, 05:55:38 PM »
This is a period mono shock that raced in Canada in the 70's.  This one has a 550, there was at least one built with a 750 that was raced.  It uses a TZ style arrangement with the shock laying horizontal over the engine.  Helps keep the wheel base very compact.
A 'continuation' frame / swingarm by the original builder (around my 78 550), is planned to start this fall.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
Re: monoshock 750
« Reply #49 on: June 09, 2010, 06:23:06 PM »
This is insane! Very cool build so far, can't wait to see her all done.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
