Author Topic: What did you do to your bike today ?  (Read 3757818 times)
Offline CycleRanger
  • No comment about being an
« Reply #12600 on: November 17, 2012, 05:42:03 PM »
Chained up and airboxed the CJ. Started installing the cables.
Realized, duh, I'll probably have to remove the battery box to hook up the throttle cables. ::)
Need to remember to refill the engine oil tomorrow...
« Last Edit: November 19, 2012, 06:31:03 AM by CycleRanger »
« Reply #12601 on: November 17, 2012, 07:33:00 PM »
Well I took my CX500 for a ride yesterday, and once it got near the 6K RPM mark (around 65 MPH in top gear) under load, it missed and farted and burped, so I turned around and came home again. I pulled the carbs and cleaned them for the second time in a week, even though they were spotlessly clean when I pulled them apart. Anyhoo, I put them back on, took it for a ride, and, it had made absolutely no difference.
This morning, while ratting through a box of old CB750 ignition parts I found a pair of coils with decent looking plug caps on them. Not CX500, but they looked (just) long enough. I pulled them apart and they still had the original resistors in them, and they looked nice and clean. I swapped them out and took my bike for a ride around the block, and voila! Problem (apparently) solved. The engine now revs stright thru to redline, (9750 RPM) with no hesitation and stalling at the 6K mark. Excellent. I think I better go for my first decent ride since I bought it. Cheers, Terry. ;D
Fun little bikes aren't they, Terry?   A bit  :P ::) underpowered though, I use a Silverwing GL500I as my daily rider-with all the bags and fairings it is even slower.  The 650 was the way to go...Larry
It's a fantastic little bike Larry, and handles surprisingly well, but I'm having a problem with it running lean at higher RPM. I've sent you a PM asking for some advice. Cheers, Terry. ;D
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #12602 on: November 18, 2012, 06:02:39 PM »
It didnt start today. Too cold. As I stood there fully geared up with helmet in hand. nothing. rug ga ga ga ga rug ga ga ga ga rug a ga ga ga gah......rug ga ga ga ga rug ga ga ga ga rug ga ga ga...rug. damn. a little sweet talk to the bike. "Its OK, I still love you...can we try again?" rug ga ga ga ga rug ga ga ga. damn. guess I will just go and rake leaves then.
Offline DJ_AX
« Reply #12603 on: November 18, 2012, 06:38:24 PM »
Wiped off the mornings fog.... and polished some of the shiny parts.
Also finally got around to putting some hinges on the old trunk.
Now all I need is a lock to hold it closed. :)
Offline drainge
« Reply #12604 on: November 18, 2012, 07:08:08 PM »
Stripped the tank. That aircraft stripper is nasty stuff...  :-\
Next is ordering some progressives for the rear and installing the tapered bearings in the headstock. Later will be new bushings (bearings? maybe?) for the swing arm. Then build it back to a rolling frame to adjust stance and figure out my seat situation (SS).
Offline gnarlycharlie4u
  • Far from being an
« Reply #12605 on: November 18, 2012, 07:35:48 PM »
That's a new thing.  I got pieces off of 78F2 - engine, wheels and front fork.  With the K3 frame, it is almost complete bike, right?  Just needs assembly.:)
Well if you need parts let me know. I've got a whole garage full and it's not going anywhere for a while.
My ability to assist you will be somewhat limited as I'm not allowed to do any moonlighting/side jobs since I work at Brooks' Cycle. But I can give you free advice all you want.
Offline Jerry E.
« Reply #12606 on: November 19, 2012, 02:11:00 AM »
Cleaned all the transmission parts, and the rods, to get ready for assembly of the bottom end. Hopefully, this week. Removed the ball bearings that plug the oil passages in the crankshaft, and drilled/tapped the holes for set screws. Then I cleaned the crankshaft & oil passages. All 4 passages were plugged solid, at least 1-1 1/2" in from the ball. I heard these should be removed/cleaned during a rebuild, now I know why. Took awhile to figure out how to get them out of the crank, though.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #12607 on: November 19, 2012, 02:54:38 AM »
That is good to know, thank you.  Would you have late swingarm - like K8 - I need it for the F2 wheel.
Offline mono
  • Definitely no
« Reply #12608 on: November 19, 2012, 05:51:15 PM »
Been polishing stuff all weekend.  Started this after work.  About 2.5 hours worth of work.  Still have to get in all the nooks and crannies, but its looking nice so far.   Got it to 600 grit.
Sent from my SPH-L710 using Tapatalk 2
Offline BuffaloBill
« Reply #12609 on: November 19, 2012, 07:06:32 PM »
Installed tapered steering bearings, painting the lower triple first.  Then polished the fork legs and brake caliper parts.  Tomorrow's agenda will be lacing a new rim on the front, new wheel bearings and tire.  Bike is a 76 750F.
Offline Dimitri13
  • 1974 CB550K
« Reply #12610 on: November 19, 2012, 10:23:15 PM »
Received my replacement clip-ons. They were out of chome so I got black instead. Good thing, because I wanted black in the first place. Powder coating looks great on it.
Offline DJ_AX
« Reply #12611 on: November 19, 2012, 10:32:32 PM »
... put some more miles on it ... and put a lock on the trunk ...
Offline JamesM
« Reply #12612 on: November 20, 2012, 11:21:13 AM »
Mocked up my 'new' DT80 tank.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline ncstatecamp
« Reply #12613 on: November 20, 2012, 06:44:46 PM »
Knocked in knee dents, sand blasted overspray from powdercoating off my rotor, lapped said rotor, glued up foam to make seat, cut frame ends and welded on hoop, a bit of sandblasting the tank (needs more), cleaned bondo'd and painted housing for gauges, and researched brake calipers.
« Reply #12614 on: November 20, 2012, 07:56:06 PM »
not me but my old mate danny,,hes 550k got stolen some months ago so hes slowly getting a bike back together,he asked me to give him a hand to mount the motor but he got it done himself!good on him!!,hes in hes late 60s and had these all hes life,he still has a 500 he bought new,its a parts bike now you can just see it to the left,he has a lot of parts!
Offline Tews19
  • I am no
« Reply #12615 on: November 20, 2012, 07:57:27 PM »
The wife took her first ride on Goldie tonight to watch the oldest boy's wrestling match in Brookfield. Ended up that he sprained his elbow. We had to go home right away to get the car and bring him to urgent care.
1970 Honda CB750 survivor.
« Reply #12616 on: November 20, 2012, 09:23:42 PM »
Dave, that looks like {from what i can see in that pic} an old Yoshi style pipe.... ;D
« Reply #12617 on: November 20, 2012, 11:48:31 PM »
yeah ive had a couple that look the same?he picked that up from some swap meet recently,he battles on,i feel sorry for him,,whod steal an old codgers bike?some sort of lowest life!
« Reply #12619 on: November 21, 2012, 11:19:06 PM »
I knew you always harbored a secret desire to own one of those seats..... ;D ;D
« Reply #12620 on: November 21, 2012, 11:27:43 PM »
hes going to make a dunny seat out of that one!
« Reply #12621 on: November 21, 2012, 11:49:18 PM »
That's right Dave, but I'm not taking it off the bike. For years, one of the things that's really annoyed me on long trips is stopping for a toilet break every couple of hours, so my new project will be building a toilet seat for a bike so that you can "do one's and two's, as you cruise".
I'm still at the "concept" phase, but considering that I'll be riding a water cooled bike, I'm sure I can modify the cooling system to allow a nice warm flush, and maybe a lovely jet of warm water to clean my privates? I'm guessing I can hide the cistern in the top box, and maybe convert those large panniers into water tanks, then just plumb the cooling hoses thru it to warm the water?
Oooer, I can just imagine it now, a combination of 2 of my favourite things, riding my bike, and taking a dump. Heaven........ ;D
« Reply #12622 on: November 21, 2012, 11:55:11 PM »
Now all you have to do is work out how to read the newspaper at the same time......Luxury.... ;D
« Reply #12623 on: November 21, 2012, 11:56:30 PM »
so it leaves a "james bond type road slick"once you flush?
« Reply #12624 on: November 21, 2012, 11:57:33 PM »
Or a rather smelly speed bump.... :o
