Author Topic: What did you do to your bike today ?  (Read 3749539 times)
Offline MickB
« Reply #17775 on: June 11, 2014, 05:16:38 PM »
Over the last week new parts have arrived, cleaned bearing shells, checked out oil pump all ok, gear box bearings given the ok by my mechanic mate, commenced starter motor restore.
Offline MickB
« Reply #17776 on: June 11, 2014, 05:18:53 PM »
Over the last week new parts have arrived, cleaned bearing shells (Dave I'll send photos), checked out oil pump all ok, gear box bearings given the ok by my mechanic mate, commenced starter motor restore.
Offline maduncle
  • Don't confuse me with a
« Reply #17777 on: June 12, 2014, 05:16:36 AM »
Dropped off parts at the nickel platers.
Picked up parts from the powder coaters.
Ah yes - the circle of life.
CB750K2 (only slightly modified)
Offline Vicman
« Reply #17778 on: June 12, 2014, 06:54:24 AM »
Got the rear brakes working properly on my GS1000. Sitting for 25 years is pretty hard on some of that stuff.
Fluent in three languages, English, sarcasm, and profanity.
Offline Jo3f1sh
  • Still don't have a jacket, even though I'm a
« Reply #17779 on: June 12, 2014, 08:12:29 AM »
Touched up some rust spots on the frame. Fixed my mis-aligned speedo gear from the PO. Pulled the front fender struts for a cleaner look...we'll see how it holds up (fender is dented anyhow). Cleaned up more brake fluid leaking from the lines (and on my tank!  >:(). Stainless lines and new MC are next on the list.
1974 Honda CB350 Four
Build thread: http://forums.sohc4.net/index.php?topic=138848.0
Offline Jerilee
« Reply #17780 on: June 12, 2014, 11:55:59 AM »
Pulled the parts from the bath and wire wheeled. I was going to try doing the oil tank in the electrolysis, but halfway to the bucket I noticed the fittings were brass soldered. Not sure I should subject the brass to the process.
I might let the powder coaters blast that clean. I'm going to have to ask them to go over the nooks and crannies on a few parts anyway. Hopefully it won't be too expensive with me doing the bulk of the cleaning.
Anyway, I tossed the exhaust header in the bath next, the silencer needed a big helping of air chisel to come off. The header looks in OK shape, so if I can get it clean enough I'll probably have it chromed with a few other parts and just buy a new silencer that looks more stock.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline KirkBurner
« Reply #17781 on: June 12, 2014, 12:13:54 PM »
Broke down... and decided I need to overhaul the engine before I go on a new ride.. ANYWHERE
Offline Sgt.Pinback
« Reply #17782 on: June 12, 2014, 03:36:26 PM »
Finally found the baffles I was looking for.
Took off the HM341and mounted the correct HMCB750 pipes to the K0
I GOT THE SOUND !!
« Last Edit: June 12, 2014, 03:40:02 PM by Sgt.Pinback »
Doc, I love a motorcycle!
Offline Ichiban 4
  • "Ichi"
« Reply #17783 on: June 12, 2014, 03:49:26 PM »
___________________________________________________________________________________________________________________
Electrolytic cleaning or stripping of brazed joints won't hurt anything (as long as it's not left in the stripping bath too long.  But that would eat away the other metal anyway).  We used to do it all the time when cleaning parts prior to plating.  Also used electro-stripping on silver soldered joints for dental appliances.  However..if there is silver in the alloy..it will discolor the braze/solder metal..and has to be cleaned with either wire wheel or shell blasting...to get the discoloration off. If it's in an inconspicuous place tho..doesn't make much difference.
Ichi
Al Summers
Present: '77 550K
Offline Jerilee
« Reply #17784 on: June 12, 2014, 06:04:57 PM »
Oh good to know! I won't worry about putting it in for a few hours before I hit it with the wire wheel then. Thanks : )
Jeri~
77/78 cool 2 member
Offline jhalldorson
« Reply #17785 on: June 12, 2014, 06:29:50 PM »
Took my all winter project for a ride by the lake! I have been riding it for about a week now and loving it! Thanks to all of you that helped me! Especially pewe and Sean barney!
Sent from my EVO using Tapatalk 2
« Reply #17786 on: June 12, 2014, 07:36:07 PM »
outstanding j...bike looks great...hope it runs as good as it looks...enjoy it!
Offline billingstitan
« Reply #17787 on: June 12, 2014, 08:46:53 PM »
Rode my 77 550K into work all week - clear blue skies every morning; rain and thunderstorms every evening by the time I left.
Couldn't ride today because it was "drop off the grandson day" -- so of course, beautiful skies all day long.
Also got two tires changed on my other 77 550K rehab project - new strips, tubes, etc. - had a buddy help me get a frozen axle nut off of the front wheel - good enough progress for a work night, I'd say. Hoping to get to the forks, brakes and headlamp this weekend at least - and if things go well, maybe even the bearings.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline jhalldorson
« Reply #17788 on: June 12, 2014, 08:48:15 PM »
Thanks Sean. Not broke in yet but seems to run very good.
Offline rickman750
« Reply #17789 on: June 12, 2014, 10:31:29 PM »
Hoiked out the flair nipples in the F1 callipers on my K2.
Ordered from David Silver -
New seat
Seat pins
Seat lock
Ignition switch
Tank badge clips
Rear spokes
Daughter told me I'm going to be a ganddad for the first time.
Offline Vicman
« Reply #17790 on: June 13, 2014, 04:44:48 AM »
Thats an accomplishment, howd you do it? ;D
Offline Vicman
« Reply #17791 on: June 13, 2014, 01:33:06 PM »
replacing the stator on the Kz1000
« Reply #17792 on: June 13, 2014, 01:54:04 PM »
Changed cam from CX-7 to a more moderate Action Fours SS-1. I look forward to smooth driving with better response from low rpm.
@ 0 lash
IN: 21/53  lift 9.18mm (0.36142")  Lobe center 106*
EX 54/22  lift 9.18mm (0.36142")  Lobe center 106*
Valve lash
IN: 0.004"  (0.10mm)
EX: 0.006"  (0.15mm)
« Reply #17793 on: June 13, 2014, 03:19:11 PM »
My brakes turned up in the mail ... 8)  Just waiting on the swingarm now...
« Reply #17794 on: June 13, 2014, 03:32:39 PM »
Then assembly??
« Reply #17795 on: June 13, 2014, 03:36:42 PM »
Then assembly??
Almost, frame goes off to the frame specialist to check for straightness and to brace it, swingarm mods then as well, then I can start putting it back together..... Still have to get the engine built, have all the parts for that, just didn't want the engine sitting round for an unknown period of time before it went in a frame... Getting close mate... ;)
Offline Adam_F
« Reply #17796 on: June 13, 2014, 04:09:08 PM »
Took my wheels down to a local shop to have my new Metzler Lasertec tires installed and balanced.  Did some work while the wheels were off.  New front brake pads.  My old ones were only 6 months old and had installed them when I rebuilt the font brake (new calipers, piston, seals, SS lines, MC, etc).  For some reason, those off brand pads would squeal every now and then no matter what i did.  New Honda pads don't make a peep.  Also replaced the front sprocket.  Then got my wheels back and installed 'em.
The difference is AMAZING!!!  So much more responsive then my old tires.  Love em.  Went for my first longer ride since I finished my top end rebuild last weekend.  Bike feels brand spankin new  8)
« Last Edit: June 13, 2014, 04:10:43 PM by Adam_F »
'77 cb550F
Offline rickman750
« Reply #17797 on: June 13, 2014, 04:49:55 PM »
Ordered some Venhill hoses for the K7/F1 front end on my K2.
...    waiting   ...
Offline mcswny
« Reply #17798 on: June 13, 2014, 08:54:53 PM »
After buying the wrong center stand off flea bay, I finally got my correct center stand stand (THANKS BILL BENTON!!) and installed and was able to lube my chain WITHOUT my lift. And yes, it was niceeeeeee!
Sent from my iPad using Tapatalk
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline Paul Lowe
  • If you like then it is good...
« Reply #17799 on: June 13, 2014, 11:41:14 PM »
Split my CB750 crankcase to find it was all lovely inside with no surprises.
PO had left me a few up to this point!
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
